The autostart revert caused a bit of duplicated code as well as
code that was using images->autostart that needs to get removed so
we can build again.
routines
This patch updates architecture specific implementations of
do_bootm_linux() adding new uImage format handling for
operations like get kernel entry point address, get kernel
image data start address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
boot_get_ramdisk() and image_get_ramdisk() do not need all
cmdtp, flag, argc and argv arguments. Simplify routines definition.
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
Architecture specific do_bootm_linux() routines share common
ramdisk image processing code. Move this code to a common
helper routine.
Implementation of the do_bootm_linux() and other bootm helper routines is
architecture specific code. As such it resides in lib_<arch> directories
in files named <arch>_linux.c
This patch renames those files to a more clear and accurate
lib_<arch>/bootm.c form.
List of the renamed files:
lib_arm/armlinux.c -> lib_arm/bootm.c
lib_avr32/avr32_linux.c -> lib_avr32/bootm.c
lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c
lib_i386/i386_linux.c -> lib_i386/bootm.c
lib_m68k/m68k_linux.c -> lib_m68k/bootm.c
lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c
lib_mips/mips_linux.c -> lib_mips/bootm.c
lib_nios/nios_linux.c -> lib_nios/bootm.c
lib_nios2/nios_linux.c -> lib_nios2/bootm.c
lib_ppc/ppc_linux.c -> lib_ppc/bootm.c
lib_sh/sh_linux.c -> lib_sh/bootm.c
