path: root/lib_i386/Makefile
2009-03-20Implement SC520 timersGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rewrite i386 interrupt handlingGraeme Russ
Rewrite interrupt handling functionality for the i386 port. Separated functionality into separate CPU and Architecture components. It appears as if the i386 interrupt handler functionality was intended to allow multiple handlers to be installed for a given interrupt. Unfortunately, this functionality was not fully implemented and also had the problem that irq_free_handler() does not allow the passing of the handler function pointer and therefore could never be used to free specific handlers that had been installed for a given IRQ. There were also various issues with array bounds not being fully tested. I had two objectives in mind for the new implementation: 1) Keep the implementation as similar as possible to existing implementations. To that end, I have used the leon2/3 implementations as the reference 2) Seperate CPU and Architecture specific elements. All specific i386 interrupt functionality is now in cpu/i386/ with the high level API and architecture specific code in lib_i386. Functionality specific to the PC/AT architecture (i.e. cascaded i8259 PICs) has been further split out into an individual file to allow for the implementation of the PIC architecture of the SC520 CPU (supports more IRQs) Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
