path: root/lib_generic
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-25Use watchdog-aware functions when calculating hashes of images - take twoBartlomiej Sieka
Some files didn't get updated properly with the "Use watchdog-aware functions when calculating hashes of images" commit, this commit fixes this. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-25Use watchdog-aware functions when calculating hashes of imagesBartlomiej Sieka
2008-04-25lib_generic/crc32.c: add missing #include <watchdog.h>Wolfgang Denk
2008-04-25lib_generic/crc32.c: fix compile problemWolfgang Denk
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-13Rename include/md5.h to include/u-boot/md5.hAndy Fleming
Some systems have md5.h installed in /usr/include/. This isn't the desired file (we want the one in include/md5.h). This will avoid the conflict. This fixes the host tools building problem by creating a new directory for U-Boot specific header files. [Patch by Andy Fleming, modified to use separate directory by Wolfgang Denk] Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2008-03-14Add the MD5 algorithmBartlomiej Sieka
MD5 supoprt is turned on by defining CONFIG_MD5, the digest can be then calculated using the md5() function -- see include/md5.h for details. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-02-29[new uImage] Introduce lmb from linux kernel for memory mgmt of boot imagesKumar Gala
Introduce the LMB lib used on PPC in the kernel as a clean way to manage the memory spaces used by various boot images and structures. This code will allow us to simplify the code in bootm and its support functions. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-07[new uImage] Move gunzip() common code to common/gunzip.cMarian Balakowicz
Move gunzip(), zalloc() and zfree() to a separate file. Share zalloc() and zfree() with cramfs uncompress routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-01-12Fix 64-bit vsprintf.James Yang
There were some size and unsigned problems. Also add support for "ll" size modifier in format string like glibc Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-10Move 64bit division from avr32 to generic libDirk Behme
Move the 64bit division from lib_avr32 to lib_generic. With this, all boards can do_div/__div64_32 if needed, not only avr one. Code is put to lib_generic, so no larger memory footprint if not used. No code modifications. Thanks for proposal by HÃ¥vard Skinnemoen. Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-02-20[PATCH 3_9] Move buffer print code from md command to common functionGrant Likely
Printing a buffer is a darn useful thing. Move the buffer print code into print_buffer() in lib_generic/ Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-10-12Fix JFFS2 compilation problemStefan Roese
Patch by Stefan Roese, 12 Oct 2006
2006-10-11Cleanup of NAND update patch (remove changelog from cmd_nand.c)Stefan Roese
Patch by Guido Classen, 10 Oct 2006
2006-10-10* Several improvements to the new NAND subsystem:Stefan Roese
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006
2006-10-09Coding style cleanupWolfgang Denk
2006-05-03Scheduled for removal: strnicmp() which is unusedWolfgang Denk
2005-10-04Fix loop end test in lib_generic/string.c:strswab()Wolfgang Denk
Patch by Andrew Dyer, October 10, 2005 Signed-off-by: Andrew Dyer <amdyer@gmail.com>
2005-09-25Fix strswab() to reliably find end of stringWolfgang Denk
Patch by Andrew Dyer, 08 Feb 2005
2004-10-11* Patch by Pantelis Antoniou, 14 Sep 2004:wdenk
Fix early serial hang when CONFIG_SERIAL_MULTI is defined. * Patch by Pantelis Antoniou, 14 Sep 2004: Kick watchdog when bz-decompressing
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2003-08-29Patch by Yuli Barcohen, 14 Aug 2003:wdenk
add support for bzip2 uncompression
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2002-11-19* Patch by Daniel Engström, 18 Nov 2002:wdenk
Fixes for x86 port (mostly strings issues) * Patch by Ken Chou, 18 Nov 2002: Fix for natsemi NIC cards (DP83815) * Patch by Pierre Aubert, 19 Nov 2002: fix a bug for the MII configuration, and some warnings
2002-09-08Initial revisionwdenk
2002-08-30Initial revisionwdenk
2001-04-28Initial revisionwdenk
2000-07-19Initial revisionwdenk
