Commit dce3d79710 updated the zlib code to v0.95; this caused
conflicts when building for the "cradle" board, because the (pretty
generic) preprocessor variable "OFF" was used in multiple files.
Make sure to avoid further conflicts by #undef'ing it in zlib.c
before redefining it.
cc: Giuseppe Condorelli <giuseppe.condorelli@st.com>
cc: Angelo Castello <angelo.castello@st.com>
cc: Alessandro Rubini <rubini-list@gnudd.com>
The Linux kernel build system changed how it compresses things with LZMA
such that the header no longer contains the filesize (it is instead set to
all F's). So if we get a LZMA image that has -1 for the 64bit field,
let's just assume that the decompressed size is unknown and continue on.
circbuf could be used as a generic library and is only currently
needed when CONFIG_USB_TTY is defined.
If the destination is aligned, fill ulong values until possible.
Then fill remaining part by byte.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
If source and destination are aligned, this copies ulong values
until possible, trailing part is copied by byte. Thanks for the details
to Wolfgang Denk, Mike Frysinger, Peter Tyser, Chris Moore.
Removed stdio.h inclusion and moved trace macros to use printf avoiding to
write debug informations to standard error.
Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com>
This patch adds watchdog reset call to allow its invokation during decompression
phase. This control was present on old zlib version and here it is
backported for those relevant routines. This patch is sent as a zlib separate
one beacuse it was not tested due to specific board lack.
zlib patches will be unified just in one when this will be validated through
tests.
This patch updates zlib to the latest stable version.
Only relevant zlib parts were ported to u-boot tree, as already did for the
current zlib (0.95). New zlib guarantees a faster inflate performances
other then others improvements as explained at www.zlib.net.
It also includes Alessandro Rubini's patches to allow 0 as destination pointer
and to call watchdog reset if required by architecture.
Reviewed-by: Angelo Castello <angelo.castello@st.com>
Reviewed-by: Alessandro Rubini <rubini-list@gnudd.com>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Signed-off-by: rhabarber1848@web.de
Use do_div from div64.h for vsprintf in case of 64bit division.
For 32bit division, do_div from div64.h can't be used as it
needs a 64bit parameter.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
CC: Simon Kagstrom <simon.kagstrom@netinsight.net>
This reverts commit b201171f2b4d509f3ad510b214bee70ff902e3d6.
The commit caused problems for example when unpacking kernel images:
Uncompressing Kernel Image ... Error: inflate() returned -2
GUNZIP: uncompress, out-of-mem or overwrite error - must
RESET board to recover
include/u-boot/zlib.h
lib_generic/zlib.c
Only relevant zlib parts were ported to u-boot tree, as was done for
the previously used version of zlib (0.95). New zlib gives faster
inflate performance and other improvements, see www.zlib.net
Edited commit message
Shove a lot of the HOSTCC and related #ifdef checking crap into the new
compiler.h header so that we can keep all other headers nice and clean.
Also introduce custom uswap functions so we don't have to rely on the non
standard implementations that a host may (or may not in the case of OS X)
provide. This allows mkimage to finally build cleanly on an OS X system.
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
Separate gunzip in
gunzip: Find the end of the header and call zunzip.
zunzip: Inflate gunzip block without header.
UBI fs blocks can be compresed in lzo, zlib or no-compression. The
current implementation of u-boot supported all the compressions but
there was a bug in the implementation of the zlib blocks.
UBIFS's Zlib blocks do not have header but they were compressed using
gunzip, a function used to decompress gunzip files/sectors with a
header.
This patch adds a new function zunzip that uncompress a zlib block with
no header.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Some systems have zlib.h installed in /usr/include/. This isn't the
desired file for u-boot code - we want the one in include/zlib.h.
This rename will avoid the conflict.
This patch adds LZO decompression support to U-Boot. It is needed for
the upcoming UBIFS support, since UBIFS uses LZO as default compressor/
decompressor. Since we only support read-only in UBIFS, only the
decompressor is needed.
All this is copied with minor changes from the current Linux kernel
version (2.6.28-rc8).
This patch only implements this LZO decompressor support for PPC.
Other platforms using UBIFS will have to add the required
"include/asm/unaligned.h" as well. It should be fairly easy to copy this
from the Linux source tree as I have done it for PPC in this patch.
This brings in support for the %p modifier which allows us to easily print
out things like ip addresses, mac addresses, and pointers.
It also converts the rarely used 'q' length modifier to the common 'L'
modifier when dealing with quad types.
While this new code is a bit larger (~1k .text), most of it should be made
up by converting the existing ip/mac address code to use format modifiers.
U-Boot's gunzip() function does not handle the return code
of zlib's inflate() function correctly. gunzip() is implemented
to uncompress all input data in one run. So the correct return
code for the good case is Z_STREAM_END. In case of insufficient
output buffer memory inflate returns Z_OK. For gunzip() this
is an error.
It also makes sense to me to call inflateEnd() also in case
of an error.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Add a library that helps in translating between virtual and physical
addresses. This library can be useful as a simple means to implement
map_physmem() and virt_to_phys() for platforms that need functionality
beyond the simple 1:1 mapping.
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
Round clock frequencies for printing.
Many boards printed off clock frequencies like 399 MHz instead of the
exact 400 MHz because numberes were not rounded. This is fixed now.
Now it's used at UBI module. Of course other modules can use it.
If you want to use it, please define CONFIG_RBTREE
ARM, i386, m68k and ppc all have identical implementations of strmhz().
Other architectures don't provide this function at all.
This patch moves strmhz() into lib_generic, reducing code duplication
and providing a more unified API across architectures.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple
of casting problems in the bootm code that called the LMB functions.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Signed-off-by: Francesco Albanese <Francesco.Albanese@swisscom.com>
__lmb_alloc_base can underflow if it fails to find free space. This was fixed
in linux with commit d9024df02ffe74d723d97d552f86de3b34beb8cc. This patch
merely updates __lmb_alloc_base to resemble the current version in Linux.
lmb_free allows us to unreserve some memory so we can use lmb_alloc_base or
lmb_reserve to temporarily reserve some memory.
This commit:
commit 338cc038461a6c7709c5b86fd9a240209338a1ae
Author: Wolfgang Denk <wd@denx.de>
Date: Fri Jun 6 14:28:14 2008 +0200
tools/mkimage: fix compiler warnings on some systems.
Broke building on some systems, because the host's string.h was interfering
with u-boot's linux/string.h. It doesn't look like we need the u-boot one if
we're building for the host, so now we only include when building inside
u-boot.
This updates the lmb code to use phys_size_t
and phys_addr_t instead of unsigned long. Other code
which interacts with this code, like getenv_bootm_size()
is also updated.
Booted on MPC8641HPCN, build-tested ppc, arm, mips.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
In the current top-of-tree, 1.3.3.-rc2, the optional tool
'tools/env/fw_printenv' fails to compile for two reasons:
1) The header watchdog.h cannot be found.
2) The header zlib.h is picked up from the tool chain rather than the
project causing a prototype conflict for crc32.
This patch addresses both of these issues.
Platforms Tested On:
- AMCC "Kilauea"
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
