The sha1 code is currently compiled for everyone, but in reality, it's
only used by the FIT code. So make it optional just like MD5.
There are boards out there that do not have network support in
U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This
makes it desirable to be able to port network configuration (like
the IP address) to the Linux kernel.
We should not make the passing of the IP configuration to Linux
dependent on U-Boot features / settings.
For this, make getenv_IPaddr() global. This fixes build error
u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr'
on various architectures.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
lib_generic/zlib.c
Commit dce3d79710 updated the zlib code to v0.95; this caused
conflicts when building for the "cradle" board, because the (pretty
generic) preprocessor variable "OFF" was used in multiple files.
Make sure to avoid further conflicts by #undef'ing it in zlib.c
before redefining it.
cc: Giuseppe Condorelli <giuseppe.condorelli@st.com>
cc: Angelo Castello <angelo.castello@st.com>
cc: Alessandro Rubini <rubini-list@gnudd.com>
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
The Linux kernel build system changed how it compresses things with LZMA
such that the header no longer contains the filesize (it is instead set to
all F's). So if we get a LZMA image that has -1 for the 64bit field,
let's just assume that the decompressed size is unknown and continue on.
This patch optimizes the direct copy procedure.
Uses get_unaligned() but only in one place.
The copy loop just above this one can also use this
optimization, but I havn't done so as I have not tested if it
is a win there too.
On my MPC8321 this is about 17% faster on my JFFS2 root FS
than the original. No speed test has been performed in u-boot.
Size increase on ppc: 484 bytes
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Add lzop decompression support to the existing lzo bitstream handling
(think gzip versus zlib), and support it for uImage decompression if
CONFIG_LZO is enabled.
Lzop doesn't compress as good as gzip (~10% worse), but decompression
is very fast (~0.7s faster here on a slow ppc). The lzop decompression
code is based on Albin Tonnerre's recent ARM Linux lzo support patch.
Cc: albin.tonnerre@free-electrons.com
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
According to the PPC reference implementation the udelay() function is
responsible for resetting the watchdog timer as frequently as needed.
Most other architectures do not meet that requirement, so long-running
operations might result in a watchdog reset.
This patch adds a generic udelay() function which takes care of
resetting the watchdog before calling an architecture-specific
__udelay().
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Ported over the more efficient linux crc32() function.
A quick comparsion on ppc:
After changing the old crc32 to do 4 bytes in the
inner loop to be able to compare with new version one can note:
- old inner loop has 61 insn, new has 19 insn.
- new crc32 does one 32 bit load of data to crc while
the old does four 8 bits loads.
- size is bit bigger for the new crc32:
1392(old) 1416(new) of text. The is because the new version
shares code with crc32_no_comp() instead of duplicating code.
- about 33% faster on ppc:
New > crc 0 0xfffffff -> 39 secs
Old > crc 0 0xfffffff -> 60 secs
circbuf could be used as a generic library and is only currently
needed when CONFIG_USB_TTY is defined.
If the destination is aligned, fill ulong values until possible.
Then fill remaining part by byte.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
If source and destination are aligned, this copies ulong values
until possible, trailing part is copied by byte. Thanks for the details
to Wolfgang Denk, Mike Frysinger, Peter Tyser, Chris Moore.
Removed stdio.h inclusion and moved trace macros to use printf avoiding to
write debug informations to standard error.
Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com>
This patch adds watchdog reset call to allow its invokation during decompression
phase. This control was present on old zlib version and here it is
backported for those relevant routines. This patch is sent as a zlib separate
one beacuse it was not tested due to specific board lack.
zlib patches will be unified just in one when this will be validated through
tests.
This patch updates zlib to the latest stable version.
Only relevant zlib parts were ported to u-boot tree, as already did for the
current zlib (0.95). New zlib guarantees a faster inflate performances
other then others improvements as explained at www.zlib.net.
It also includes Alessandro Rubini's patches to allow 0 as destination pointer
and to call watchdog reset if required by architecture.
Reviewed-by: Angelo Castello <angelo.castello@st.com>
Reviewed-by: Alessandro Rubini <rubini-list@gnudd.com>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Signed-off-by: rhabarber1848@web.de
Use do_div from div64.h for vsprintf in case of 64bit division.
For 32bit division, do_div from div64.h can't be used as it
needs a 64bit parameter.
CC: Simon Kagstrom <simon.kagstrom@netinsight.net>
This reverts commit b201171f2b4d509f3ad510b214bee70ff902e3d6.
The commit caused problems for example when unpacking kernel images:
Uncompressing Kernel Image ... Error: inflate() returned -2
GUNZIP: uncompress, out-of-mem or overwrite error - must
RESET board to recover
include/u-boot/zlib.h
lib_generic/zlib.c
Only relevant zlib parts were ported to u-boot tree, as was done for
the previously used version of zlib (0.95). New zlib gives faster
inflate performance and other improvements, see www.zlib.net
Edited commit message
Shove a lot of the HOSTCC and related #ifdef checking crap into the new
compiler.h header so that we can keep all other headers nice and clean.
Also introduce custom uswap functions so we don't have to rely on the non
standard implementations that a host may (or may not in the case of OS X)
provide. This allows mkimage to finally build cleanly on an OS X system.
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
Separate gunzip in
gunzip: Find the end of the header and call zunzip.
zunzip: Inflate gunzip block without header.
UBI fs blocks can be compresed in lzo, zlib or no-compression. The
current implementation of u-boot supported all the compressions but
there was a bug in the implementation of the zlib blocks.
UBIFS's Zlib blocks do not have header but they were compressed using
gunzip, a function used to decompress gunzip files/sectors with a
header.
This patch adds a new function zunzip that uncompress a zlib block with
no header.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Some systems have zlib.h installed in /usr/include/. This isn't the
desired file for u-boot code - we want the one in include/zlib.h.
This rename will avoid the conflict.
This patch adds LZO decompression support to U-Boot. It is needed for
the upcoming UBIFS support, since UBIFS uses LZO as default compressor/
decompressor. Since we only support read-only in UBIFS, only the
decompressor is needed.
All this is copied with minor changes from the current Linux kernel
version (2.6.28-rc8).
This patch only implements this LZO decompressor support for PPC.
Other platforms using UBIFS will have to add the required
"include/asm/unaligned.h" as well. It should be fairly easy to copy this
from the Linux source tree as I have done it for PPC in this patch.
This brings in support for the %p modifier which allows us to easily print
out things like ip addresses, mac addresses, and pointers.
It also converts the rarely used 'q' length modifier to the common 'L'
modifier when dealing with quad types.
While this new code is a bit larger (~1k .text), most of it should be made
up by converting the existing ip/mac address code to use format modifiers.
U-Boot's gunzip() function does not handle the return code
of zlib's inflate() function correctly. gunzip() is implemented
to uncompress all input data in one run. So the correct return
code for the good case is Z_STREAM_END. In case of insufficient
output buffer memory inflate returns Z_OK. For gunzip() this
is an error.
It also makes sense to me to call inflateEnd() also in case
of an error.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Add a library that helps in translating between virtual and physical
addresses. This library can be useful as a simple means to implement
map_physmem() and virt_to_phys() for platforms that need functionality
beyond the simple 1:1 mapping.
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
Round clock frequencies for printing.
Many boards printed off clock frequencies like 399 MHz instead of the
exact 400 MHz because numberes were not rounded. This is fixed now.
Now it's used at UBI module. Of course other modules can use it.
If you want to use it, please define CONFIG_RBTREE
ARM, i386, m68k and ppc all have identical implementations of strmhz().
Other architectures don't provide this function at all.
This patch moves strmhz() into lib_generic, reducing code duplication
and providing a more unified API across architectures.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple
of casting problems in the bootm code that called the LMB functions.
Signed-off-by: Andy Fleming <afleming@freescale.com>
