path: root/lib_generic
2009-03-20vsprintf: pull updates from Linux kernelMike Frysinger
This brings in support for the %p modifier which allows us to easily print out things like ip addresses, mac addresses, and pointers. It also converts the rarely used 'q' length modifier to the common 'L' modifier when dealing with quad types. While this new code is a bit larger (~1k .text), most of it should be made up by converting the existing ip/mac address code to use format modifiers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-11bzip2: move ifdef handling to Makefile COBJS-$(...)Mike Frysinger
2009-01-27Fix gunzip in case of insufficient output bufferMatthias Fuchs
U-Boot's gunzip() function does not handle the return code of zlib's inflate() function correctly. gunzip() is implemented to uncompress all input data in one run. So the correct return code for the good case is Z_STREAM_END. In case of insufficient output buffer memory inflate returns Z_OK. For gunzip() this is an error. It also makes sense to me to call inflateEnd() also in case of an error. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-12-15Introduce addr_map libraryKumar Gala
Add a library that helps in translating between virtual and physical addresses. This library can be useful as a simple means to implement map_physmem() and virt_to_phys() for platforms that need functionality beyond the simple 1:1 mapping. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 6/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-22Fix strmhz(): avoid printing negative fractionsWolfgang Denk
2008-10-21strmhz(): Round numbers when printing clock frequenciesWolfgang Denk
Round clock frequencies for printing. Many boards printed off clock frequencies like 399 MHz instead of the exact 400 MHz because numberes were not rounded. This is fixed now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18Add Red Black Tree supportKyungmin Park
Now it's used at UBI module. Of course other modules can use it. If you want to use it, please define CONFIG_RBTREE Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-13Add support for LZMA uncompression algorithm.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-29crc16: move to lib_genericJean-Christophe PLAGNIOL-VILLARD
2008-08-29gunzip: move to lib_genericJean-Christophe PLAGNIOL-VILLARD
2008-08-21Consolidate strmhz() implementationHaavard Skinnemoen
ARM, i386, m68k and ppc all have identical implementations of strmhz(). Other architectures don't provide this function at all. This patch moves strmhz() into lib_generic, reducing code duplication and providing a more unified API across architectures. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-14vsprintf: add z and t optionsJean-Christophe PLAGNIOL-VILLARD
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-10Fix LMB type issuesAndy Fleming
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple of casting problems in the bootm code that called the LMB functions. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-09Allow print_size to print in GBBecky Bruce
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-30add SHA256 supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Francesco Albanese <Francesco.Albanese@swisscom.com>
2008-06-28Fix an underflow bug in __lmb_alloc_baseAndy Fleming
__lmb_alloc_base can underflow if it fails to find free space. This was fixed in linux with commit d9024df02ffe74d723d97d552f86de3b34beb8cc. This patch merely updates __lmb_alloc_base to resemble the current version in Linux. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-28Add lmb_freeAndy Fleming
lmb_free allows us to unreserve some memory so we can use lmb_alloc_base or lmb_reserve to temporarily reserve some memory. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-12Fix build issue with string.h and linux/string.hAndy Fleming
This commit: commit 338cc038461a6c7709c5b86fd9a240209338a1ae Author: Wolfgang Denk <wd@denx.de> Date: Fri Jun 6 14:28:14 2008 +0200 tools/mkimage: fix compiler warnings on some systems. Broke building on some systems, because the host's string.h was interfering with u-boot's linux/string.h. It doesn't look like we need the u-boot one if we're building for the host, so now we only include when building inside u-boot. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-12Change lmb to use phys_size_t/phys_addr_tBecky Bruce
This updates the lmb code to use phys_size_t and phys_addr_t instead of unsigned long. Other code which interacts with this code, like getenv_bootm_size() is also updated. Booted on MPC8641HPCN, build-tested ppc, arm, mips. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-12Change print_size to take phys_size_tBecky Bruce
2008-06-06tools/mkimage: fix compiler warnings on some systems.Wolfgang Denk
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-25Use watchdog-aware functions when calculating hashes of images - take twoBartlomiej Sieka
Some files didn't get updated properly with the "Use watchdog-aware functions when calculating hashes of images" commit, this commit fixes this. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-25Use watchdog-aware functions when calculating hashes of imagesBartlomiej Sieka
2008-04-25lib_generic/crc32.c: add missing #include <watchdog.h>Wolfgang Denk
2008-04-25lib_generic/crc32.c: fix compile problemWolfgang Denk
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-13Rename include/md5.h to include/u-boot/md5.hAndy Fleming
Some systems have md5.h installed in /usr/include/. This isn't the desired file (we want the one in include/md5.h). This will avoid the conflict. This fixes the host tools building problem by creating a new directory for U-Boot specific header files. [Patch by Andy Fleming, modified to use separate directory by Wolfgang Denk] Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2008-03-14Add the MD5 algorithmBartlomiej Sieka
MD5 supoprt is turned on by defining CONFIG_MD5, the digest can be then calculated using the md5() function -- see include/md5.h for details. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-02-29[new uImage] Introduce lmb from linux kernel for memory mgmt of boot imagesKumar Gala
Introduce the LMB lib used on PPC in the kernel as a clean way to manage the memory spaces used by various boot images and structures. This code will allow us to simplify the code in bootm and its support functions. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-07[new uImage] Move gunzip() common code to common/gunzip.cMarian Balakowicz
Move gunzip(), zalloc() and zfree() to a separate file. Share zalloc() and zfree() with cramfs uncompress routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-01-12Fix 64-bit vsprintf.James Yang
There were some size and unsigned problems. Also add support for "ll" size modifier in format string like glibc Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-10Move 64bit division from avr32 to generic libDirk Behme
Move the 64bit division from lib_avr32 to lib_generic. With this, all boards can do_div/__div64_32 if needed, not only avr one. Code is put to lib_generic, so no larger memory footprint if not used. No code modifications. Thanks for proposal by Håvard Skinnemoen. Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-02-20[PATCH 3_9] Move buffer print code from md command to common functionGrant Likely
Printing a buffer is a darn useful thing. Move the buffer print code into print_buffer() in lib_generic/ Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-10-12Fix JFFS2 compilation problemStefan Roese
Patch by Stefan Roese, 12 Oct 2006
