Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
If the destination is aligned, fill ulong values until possible.
Then fill remaining part by byte.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
If source and destination are aligned, this copies ulong values
until possible, trailing part is copied by byte. Thanks for the details
to Wolfgang Denk, Mike Frysinger, Peter Tyser, Chris Moore.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Patch by Andrew Dyer, October 10, 2005
Signed-off-by: Andrew Dyer <amdyer@gmail.com>
Patch by Andrew Dyer, 08 Feb 2005
Fix problems with GCC 3.3.x which changed handling of global
variables explicitly initialized to zero (now in .bss instead of
.data as before).
* Patch by Leon Kukovec, 02 Mar 2004:
add strswab() to fix IDE LBA capacity, firmware and model numbers
on little endian machines
* Patch by Masami Komiya, 02 Mar 2004:
- Remove get_ticks() from NFS code
- Add verification of RPC transaction ID
* Patch by Pierre Aubert, 02 Mar 2004:
cleanup for IDE and USB drivers for MPC5200
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Fixes for x86 port (mostly strings issues)
* Patch by Ken Chou, 18 Nov 2002:
Fix for natsemi NIC cards (DP83815)
* Patch by Pierre Aubert, 19 Nov 2002:
fix a bug for the MII configuration, and some warnings
