path: root/lib_generic/crc32.c
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-25Use watchdog-aware functions when calculating hashes of imagesBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-25lib_generic/crc32.c: add missing #include <watchdog.h>Wolfgang Denk
2008-04-25lib_generic/crc32.c: fix compile problemWolfgang Denk
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-10-12Fix JFFS2 compilation problemStefan Roese
Patch by Stefan Roese, 12 Oct 2006
2006-10-11Cleanup of NAND update patch (remove changelog from cmd_nand.c)Stefan Roese
Patch by Guido Classen, 10 Oct 2006
2006-10-10* Several improvements to the new NAND subsystem:Stefan Roese
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
