path: root/lib_blackfin
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-05[Blackfin][PATCH] Kill off a bunch of common local prototypesAubrey Li
2007-04-05[Blackfin][PATCH] Fix dynamic CPLB generation issueAubrey Li
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-04-05[Blackfin][PATCH] remove asm/page.h as we do not actually use/want any of ↵Aubrey Li
these definitions nor does any other arch include it
2007-03-22Code cleanup / re-insert previous Copyright entries.Wolfgang Denk
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
2006-03-12Coding Style cleanupWolfgang Denk
2006-03-12Add missing Blackfin files.Wolfgang Denk
