path: root/lib_blackfin/Makefile
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: add support for kgdbRobin Getz
Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: pull io funcs from linuxMike Frysinger
Some common code uses more of the io.h funcs than we currently provide, so pull in all of the ones from the linux kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23Blackfin: use common code to preprocess linker scriptMike Frysinger
Now that the common code preprocesses the linker script, the Blackfin code no longer needs to do it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-10Blackfin: add cache_dump commandsMike Frysinger
A few debug-type commands used to dump the raw icache/dcache data. Useful when trying to track down cache-related bugs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-02Blackfin: cache core/system clock valuesMike Frysinger
Calculating the clocks requires a bit of calls to gcc math functions, so cache the values after the first run since they'll most likely never change once U-Boot is up and running. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-02Blackfin: only build post code when CONFIG_POSTMike Frysinger
Save some time by using CONFIG_POST in the Makefile rather than C files. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: rename bootm.c to boot.cMike Frysinger
The boot file contains functions for more than just "bootm", so rename it accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: cleanup and overhaul common board init functionsMike Frysinger
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-22Code cleanup / re-insert previous Copyright entries.Wolfgang Denk
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
2006-03-12Add missing Blackfin files.Wolfgang Denk
