path: root/lib_avr32
2007-10-06AVR32: Initialize bi_flash* in board_init_rHaavard Skinnemoen
The ATSTK1000-specific flash driver intializes bi_flashstart, bi_flashsize and bi_flashoffset, but other flash drivers, like the CFI driver, don't. Initialize these in board_init_r instead so that things will still be set up correctly when we switch to the CFI driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-10Move 64bit division from avr32 to generic libDirk Behme
Move the 64bit division from lib_avr32 to lib_generic. With this, all boards can do_div/__div64_32 if needed, not only avr one. Code is put to lib_generic, so no larger memory footprint if not used. No code modifications. Thanks for proposal by Håvard Skinnemoen. Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-14AVR32: Enable networkingHaavard Skinnemoen
Implement MACB initialization for AVR32 and ATSTK1000, and turn everything on, including the MACB driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Implement simple DMA memory allocatorHaavard Skinnemoen
Implement dma_alloc_coherent() which returns cache-aligned uncacheable memory. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Use initdram() instead of board_init_memories()Haavard Skinnemoen
Conform to the "standard" interface and use initdram() instead of board_init_memories() on AVR32. This enables us to get rid of the sdram_size member of the global_data struct as well. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Relocate u-boot to SDRAMHaavard Skinnemoen
Relocate the u-boot image into SDRAM like everyone else does. This means that we can handle much larger .data and .bss than we used to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Resource management rewriteHaavard Skinnemoen
Rewrite the resource management code (i.e. I/O memory, clock gating, gpio) so it doesn't depend on any global state. This is necessary because this code is heavily used before relocation to RAM, so we can't write to any global variables. As an added bonus, this makes u-boot's memory footprint a bit smaller, although some functionality has been left out; all clocks are enabled all the time, and there's no checking for gpio line conflicts. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Split start_u_boot into board_init_f and board_init_rHaavard Skinnemoen
Split the avr32 initialization code into a function to run before relocation, board_init_f and a function to run after relocation, board_init_r. For now, board_init_f simply calls board_init_r at the end. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-27Fix "ar" flags in some Makefiles to allow for silent "make -s"Wolfgang Denk
2006-10-24Add AVR32 architecture supportWolfgang Denk
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200 This patch adds common infrastructure code for the Atmel AVR32 architecture. See doc/README.AVR32 for details. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
