path: root/lib_avr32
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-14AVR32: Enable networkingHaavard Skinnemoen
Implement MACB initialization for AVR32 and ATSTK1000, and turn everything on, including the MACB driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Implement simple DMA memory allocatorHaavard Skinnemoen
Implement dma_alloc_coherent() which returns cache-aligned uncacheable memory. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Use initdram() instead of board_init_memories()Haavard Skinnemoen
Conform to the "standard" interface and use initdram() instead of board_init_memories() on AVR32. This enables us to get rid of the sdram_size member of the global_data struct as well. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Relocate u-boot to SDRAMHaavard Skinnemoen
Relocate the u-boot image into SDRAM like everyone else does. This means that we can handle much larger .data and .bss than we used to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Resource management rewriteHaavard Skinnemoen
Rewrite the resource management code (i.e. I/O memory, clock gating, gpio) so it doesn't depend on any global state. This is necessary because this code is heavily used before relocation to RAM, so we can't write to any global variables. As an added bonus, this makes u-boot's memory footprint a bit smaller, although some functionality has been left out; all clocks are enabled all the time, and there's no checking for gpio line conflicts. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Split start_u_boot into board_init_f and board_init_rHaavard Skinnemoen
Split the avr32 initialization code into a function to run before relocation, board_init_f and a function to run after relocation, board_init_r. For now, board_init_f simply calls board_init_r at the end. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-27Fix "ar" flags in some Makefiles to allow for silent "make -s"Wolfgang Denk
2006-10-24Add AVR32 architecture supportWolfgang Denk
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200 This patch adds common infrastructure code for the Atmel AVR32 architecture. See doc/README.AVR32 for details. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
