path: root/lib_arm
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-05* Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120wdenk
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README.
2002-09-08Initial revisionwdenk
