path: root/lib_arm
2009-07-27arm: add _lshrdi3.SHeiko Schocher
2009-07-27Make linking against libgcc configurableWolfgang Denk
Many (especially ARM) tool chains seem to come with broken or otherwise unusable (for the purposes of builing U-Boot) run-time support libraries `libgcc.a'. By using the "USE_PRIVATE_LIBGCC" setting we allow to use alternative libraries instead. "USE_PRIVATE_LIBGCC" can either be set as an environment variable in the shell, or as a command line argument when running "make", i. e. $ make USE_PRIVATE_LIBGCC=yes or $ USE_PRIVATE_LIBGCC=yes $ export USE_PRIVATE_LIBGCC $ make The value of "USE_PRIVATE_LIBGCC" is the name of the directory which contains the alternative run-time support library `libgcc.a'. The special value "yes" selects the directory $(OBJTREE)/lib_$(ARCH) . Note that not all architectures provide an alternative `libgcc.a' in their lib_$(ARCH) directories - so far, only ARM does. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Stefan Roese <sr@denx.de>
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-21arm: add support for CONFIG_GENERIC_MMCIlya Yanok
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2009-06-12make MODEM SUPPORT generic instead of duplicate itJean-Christophe PLAGNIOL-VILLARD
and fix comment Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Adjusted Copyright message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arch_misc_init support for ARM architecturesPrafulla Wadaskar
This patch is required for Kirkwood support may be used by other ARM architectures Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-06-12arm: remove cpu_initJean-Christophe PLAGNIOL-VILLARD
move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: unify interrupt initJean-Christophe PLAGNIOL-VILLARD
all arm init the IRQ stack the same way so unify it in lib_arm/interrupts.c and then call arch specific interrupt init Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12ARM Add blue colour LED to status_led.Tom Rix
There is exiting support for red,yellow,green but no blue. The main LED on the zoom2 is a blue LED. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12lib_arch/board.c: Move malloc initialization before flash_init()Stefan Roese
This patch moves the malloc initialization before calling flash_init(). Upcoming changes to the NOR FLASH common CFI driver with optional MTD infrastructure and MTD concatenation support will call malloc(). And nothing really speaks against enabling malloc just a little earlier in the boot stage. Some architectures already enable malloc before calling flash_init() so they don't need any changes here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: John Rigby <jcrigby@gmail.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-26lib_arm/board.c: remove misleading "test-only" comment.Wolfgang Denk
For a long time, the print_cpuinfo() declaration in lib_arm/board.c had been marked as "test-only", which is plain wrong considering current usage. Delete this misleading comment. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05arm: unify reset commandJean-Christophe PLAGNIOL-VILLARD
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20arm: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Some warts are remaining and should be killed off (by moving the func to the appropriate board init code): - davinci_eth_set_mac_addr - cs8900_get_enetaddr - smc_set_mac_addr Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22arm: add uart dcc supportJean-Christophe PLAGNIOL-VILLARD
Serial driver via the EmbeddedICE macrocell's DCC channel using co-processor 14. It does include a timeout to ensure that the system does not totally freeze when there is nothing connected to read. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-18API: Provide syscall entry point for the ARM architecture.Rafal Jaworowski
Signed-off-by: Rafal Czubak <rcz@semihalf.com> Acked-by: Rafal Jaworowski <raj@semihalf.com>
2009-02-06ARM: remove unused variableGuennadi Liakhovetski
The "size" variable in start_armboot() in lib_arm/board.c is only really used in "#ifndef CONFIG_SYS_NO_FLASH" case, and even there it can be eliminated (thanks to Jean-Christophe PLAGNIOL-VILLARD for a suggestion.) Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2009-01-31ixp: move pci init in arm/board instead of cpuJean-Christophe PLAGNIOL-VILLARD
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-21lib_arm: do_bootm_linux() - correct a small mistakeIlko Iliev
This patch corrects a small bug in the "if" condition: the parameter "flag" is 0 and the "if" condition is always true. The result is - the boom command doesn't start the kernel. Affected targets: all arm based. Signed-off-by: Ilko Iliev <iliev@ronetix.at>
2008-10-29bootm: Add subcommandsKumar Gala
Add the ability to break the steps of the bootm command into several subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go. This allows us to do things like manipulate device trees before they are passed to a booting kernel or setup memory for a secondary core in multicore situations. Not all OS types support all subcommands (currently only start, loados, ramdisk, fdt, and go are supported). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-08Fix bug: in arch-arm, env_get_char dose not work finegnusercn
due to the arm implementation which supposed that U-Boot is in RAM when we jump to start_armboot Signed-off-by: gnusercn <gnusercn@gmail.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-30Revert "ARM: set GD_FLG_RELOC for boards skipping relocation to RAM"Jean-Christophe PLAGNIOL-VILLARD
we need this due to the arm implementation which supposed that U-Boot is in RAM when we jump to start_armboot This reverts commit f96b44cef897bd372beb86dde1b33637c119d84d. in order to do it for all arm board Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-08lib_arm/bootm.c: fix compile warningsWolfgang Denk
bootm.c:128: warning: label 'error' defined but not used bootm.c:65: warning: unused variable 'ret' Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-31ARM DaVinci: Changing function names for EMAC driverSandeep Paulraj
DM644x is just one of a series of DaVinci chips that use the EMAC driver. By replacing all the function names that start with dm644x_* to davinci_* we make these function more portable. I have tested this change on my EVM. DM6467 is another DaVinci SOC which uses the EMAC driver and i will be sending patches that add DaVinci DM6467 support to the list soon. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor ramdisk locating codeKumar Gala
Move determing if we have a ramdisk and where its located into the common code. Keep track of the ramdisk start and end in the bootm_headers_t image struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21Consolidate strmhz() implementationHaavard Skinnemoen
ARM, i386, m68k and ppc all have identical implementations of strmhz(). Other architectures don't provide this function at all. This patch moves strmhz() into lib_generic, reducing code duplication and providing a more unified API across architectures. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-30ARM: set GD_FLG_RELOC for boards skipping relocation to RAMRemy Bohmer
If CONFIG_SKIP_RELOCATE_UBOOT is set the flag GD_FLG_RELOC is usually never set, because relocation to RAM is actually never done by U-boot itself. However, several pieces of code check if this flag is set at some time. So, to make sure this flag is set on boards skipping relocation, this is added to the initialisation of U-boot at a moment where it is safe to do so. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-07-20Remove unused code from lib_arm/bootm.cGururaja Hebbar K R
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-05-28Remove prototypes of nand_init() in favor of including nand.h.Scott Wood
Likewise with onenand_init(). Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add ATMEL LCD driverStelian Pop
This patch adds support for the ATMEL LCDC driver which is used on some AT91 and AVR platforms. Is has been tested with the AT91CAP9ADK, AT91SAM9261EK, AT91SAM9263EK and AT91SAM9RLEK boards. Adaptation for AVR32 should probably be easy. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-03Fix implicit declaration build warningsMarcel Ziswiler
- warning: implicit declaration of function ‘serial_initialize’ Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
