path: root/lib_arm
2006-04-25cosmetic: print amount of NAND flash aligned with the other values such asMarkus Klotzbuecher
DRAM
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-10Changed gcc-4.0 global data pointer fix to conform with the fix for this onMarkus Klotzbücher
other platforms (see c75eba3b4140187cd0d9bd8049f5df4c49b6889b)
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2006-01-29Cleanup U-Boot boot messages on ARM.Wolfgang Denk
To match the U-Boot user interface on ARM platforms to the U-Boot standard (as on PPC platforms), some messages with debug character are removed from the default U-Boot build. Enable DEBUG for lib_arm/board.c to enable debug messages. New CONFIG_DISPLAY_CPUINFO and CONFIG_DISPLAY_BOARDINFO options. Patch by Stefan Roese, 24 Jan 2006
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-08-19Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2Wolfgang Denk
Patch by Martin Krause, 08 Jun 2005
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-07-11* Patch by Philippe Robin, 01 Jul 2004:wdenk
Add initialization for Integrator and versatile board files. * Patch by Hinko Kocevar, 01 Jun 2004: Fix VFD FB allocation, add LCD FB allocation on ARM
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-06Patch by Dave Peverley, 29 Apr 2004:wdenk
add MAC address detection to smc91111 driver
2004-04-18* Patch by Matthew S. McClintock, 14 Apr 2004:wdenk
fix initdram function for utx8245 board * Patch by Markus Pietrek, 14 Apr 2004: use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag * Patch by Reinhard Meyer, 18 Apr 2004: provide the IDE Reset Function for EMK 5200 boards * Patch by Masami Komiya, 12 Apr 2004: fix pci_hose_write_config_{byte,word}_via_dword problems
2004-03-23* Patch by Phillippe Robin, 16 Mar 2004:wdenk
avoid dereferencing NULL pointer in lib_arm/armlinux.c * Patch by Stephen Williams, 15 Mar 2004: Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation * Patch by Tolunay Orkun, 15 Mar 2004: Initialize bi_opbfreq to real OPB frequency via get_OPB_freq() * Patch by Travis Sawyer, 15 Mar 2004: Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
2004-01-02* Patch by Denis Peter, 8 Dec 2003wdenk
- add support for the PATI board (MPC555) - add SPI support for the MPC5xx * Patch by Anders Larsen, 08 Dec 2003: add configuration options CONFIG_SERIAL_TAG and CONFIG_REVISION_TAG to pass ATAG_SERIAL and ATAG_REVISION, resp., to the ARM target; cleanup some redundand #defines
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-12-07* Patch by Xue Ligong (Joe), 13 Nov 2003:wdenk
add Realtek 8019 ethernet driver * Patch by Yuli Barcohen, 13 Nov 2003: MPC826xADS/PQ2FADS cleanup * Patch by Anders Larsen, 12 Nov 2003: Update README to mark the PORTIO commands non-standard
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-09-17Support new configuration of TRAB board with more memorywdenk
Minor cleanup of comments
2003-09-17Add auto-update code for TRAB board using USB memory stickswdenk
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-06-22* Patch by Rune Torgersen, 4 Jun 2003:wdenk
add large memory support for MPC8266ADS board * Patch by Richard Woodruff, 19 June 03: - Enabled standard u-boot device abstraction for ARM - Enabled console device for ARM - Initilized bi_baudrate for ARM * Patch by Bill Hargen, 23 Apr 2003: fix byte order for 824x I2C addresses (write op)
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
