path: root/lib_arm
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-21Merge branch 'master' of /home/git/u-bootMarian Balakowicz
2008-02-15Merge branch '080208_dupint' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14ARM: make the machid configurable via the environmentUwe Kleine-König
If the variable "machid" exists, let do_bootm_linux use that instead of bd->bi_arch_number. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
2008-02-14ARM: cleanup duplicated exception handlingcodeAndreas Engel
Move duplicated exception handling code into lib_arm. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
2008-02-07[new uImage] Factor out common image_get_ramdisk() routineMarian Balakowicz
Architecture specific do_bootm_linux() routines share common ramdisk image processing code. Move this code to a common helper routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Cleanup image header pointer use in bootm codeMarian Balakowicz
- use single image header pointer instead of a set of auxilliary variables. - add multi component image helper routines: get component size/data address Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-04ARM: add I2C init function call in lib_arm/board.cHebbar
Adds I2C init func call to init sequence for ARM boards. This is present in ppc,blackfin and other processor init sequence. Signed-off-by: K R Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-01-09ARM: support board-specific ethernet PHY initJean-Christophe PLAGNIOL-VILLARD
Add until the new phylib will be arrived Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-10-13Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2007-10-13Coding Style cleanup.Wolfgang Denk
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-09-07Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-04Add coloured led interface for ARM boards.Peter Pearse
Use it in cpu/arm920t/start.S to indicate U-Boot code has been entered.
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-05-30Minor cleanup.Wolfgang Denk
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2006-04-25cosmetic: print amount of NAND flash aligned with the other values such asMarkus Klotzbuecher
DRAM
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-10Changed gcc-4.0 global data pointer fix to conform with the fix for this onMarkus Klotzbücher
other platforms (see c75eba3b4140187cd0d9bd8049f5df4c49b6889b)
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2006-01-29Cleanup U-Boot boot messages on ARM.Wolfgang Denk
To match the U-Boot user interface on ARM platforms to the U-Boot standard (as on PPC platforms), some messages with debug character are removed from the default U-Boot build. Enable DEBUG for lib_arm/board.c to enable debug messages. New CONFIG_DISPLAY_CPUINFO and CONFIG_DISPLAY_BOARDINFO options. Patch by Stefan Roese, 24 Jan 2006
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-08-19Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2Wolfgang Denk
Patch by Martin Krause, 08 Jun 2005
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
