path: root/lib_arm
2008-02-04ARM: add I2C init function call in lib_arm/board.cHebbar
Adds I2C init func call to init sequence for ARM boards. This is present in ppc,blackfin and other processor init sequence. Signed-off-by: K R Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-01-09ARM: support board-specific ethernet PHY initJean-Christophe PLAGNIOL-VILLARD
Add until the new phylib will be arrived Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-10-13Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2007-10-13Coding Style cleanup.Wolfgang Denk
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-09-07Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-04Add coloured led interface for ARM boards.Peter Pearse
Use it in cpu/arm920t/start.S to indicate U-Boot code has been entered.
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-05-30Minor cleanup.Wolfgang Denk
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2006-04-25cosmetic: print amount of NAND flash aligned with the other values such asMarkus Klotzbuecher
DRAM
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-10Changed gcc-4.0 global data pointer fix to conform with the fix for this onMarkus Klotzbücher
other platforms (see c75eba3b4140187cd0d9bd8049f5df4c49b6889b)
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2006-01-29Cleanup U-Boot boot messages on ARM.Wolfgang Denk
To match the U-Boot user interface on ARM platforms to the U-Boot standard (as on PPC platforms), some messages with debug character are removed from the default U-Boot build. Enable DEBUG for lib_arm/board.c to enable debug messages. New CONFIG_DISPLAY_CPUINFO and CONFIG_DISPLAY_BOARDINFO options. Patch by Stefan Roese, 24 Jan 2006
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-08-19Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2Wolfgang Denk
Patch by Martin Krause, 08 Jun 2005
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-07-11* Patch by Philippe Robin, 01 Jul 2004:wdenk
Add initialization for Integrator and versatile board files. * Patch by Hinko Kocevar, 01 Jun 2004: Fix VFD FB allocation, add LCD FB allocation on ARM
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-06Patch by Dave Peverley, 29 Apr 2004:wdenk
add MAC address detection to smc91111 driver
2004-04-18* Patch by Matthew S. McClintock, 14 Apr 2004:wdenk
fix initdram function for utx8245 board * Patch by Markus Pietrek, 14 Apr 2004: use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag * Patch by Reinhard Meyer, 18 Apr 2004: provide the IDE Reset Function for EMK 5200 boards * Patch by Masami Komiya, 12 Apr 2004: fix pci_hose_write_config_{byte,word}_via_dword problems
2004-03-23* Patch by Phillippe Robin, 16 Mar 2004:wdenk
avoid dereferencing NULL pointer in lib_arm/armlinux.c * Patch by Stephen Williams, 15 Mar 2004: Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation * Patch by Tolunay Orkun, 15 Mar 2004: Initialize bi_opbfreq to real OPB frequency via get_OPB_freq() * Patch by Travis Sawyer, 15 Mar 2004: Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
