path: root/lib_arm
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05arm: unify reset commandJean-Christophe PLAGNIOL-VILLARD
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20arm: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Some warts are remaining and should be killed off (by moving the func to the appropriate board init code): - davinci_eth_set_mac_addr - cs8900_get_enetaddr - smc_set_mac_addr Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22arm: add uart dcc supportJean-Christophe PLAGNIOL-VILLARD
Serial driver via the EmbeddedICE macrocell's DCC channel using co-processor 14. It does include a timeout to ensure that the system does not totally freeze when there is nothing connected to read. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-18API: Provide syscall entry point for the ARM architecture.Rafal Jaworowski
Signed-off-by: Rafal Czubak <rcz@semihalf.com> Acked-by: Rafal Jaworowski <raj@semihalf.com>
2009-02-06ARM: remove unused variableGuennadi Liakhovetski
The "size" variable in start_armboot() in lib_arm/board.c is only really used in "#ifndef CONFIG_SYS_NO_FLASH" case, and even there it can be eliminated (thanks to Jean-Christophe PLAGNIOL-VILLARD for a suggestion.) Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2009-01-31ixp: move pci init in arm/board instead of cpuJean-Christophe PLAGNIOL-VILLARD
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-21lib_arm: do_bootm_linux() - correct a small mistakeIlko Iliev
This patch corrects a small bug in the "if" condition: the parameter "flag" is 0 and the "if" condition is always true. The result is - the boom command doesn't start the kernel. Affected targets: all arm based. Signed-off-by: Ilko Iliev <iliev@ronetix.at>
2008-10-29bootm: Add subcommandsKumar Gala
Add the ability to break the steps of the bootm command into several subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go. This allows us to do things like manipulate device trees before they are passed to a booting kernel or setup memory for a secondary core in multicore situations. Not all OS types support all subcommands (currently only start, loados, ramdisk, fdt, and go are supported). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-08Fix bug: in arch-arm, env_get_char dose not work finegnusercn
due to the arm implementation which supposed that U-Boot is in RAM when we jump to start_armboot Signed-off-by: gnusercn <gnusercn@gmail.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-30Revert "ARM: set GD_FLG_RELOC for boards skipping relocation to RAM"Jean-Christophe PLAGNIOL-VILLARD
we need this due to the arm implementation which supposed that U-Boot is in RAM when we jump to start_armboot This reverts commit f96b44cef897bd372beb86dde1b33637c119d84d. in order to do it for all arm board Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-08lib_arm/bootm.c: fix compile warningsWolfgang Denk
bootm.c:128: warning: label 'error' defined but not used bootm.c:65: warning: unused variable 'ret' Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-31ARM DaVinci: Changing function names for EMAC driverSandeep Paulraj
DM644x is just one of a series of DaVinci chips that use the EMAC driver. By replacing all the function names that start with dm644x_* to davinci_* we make these function more portable. I have tested this change on my EVM. DM6467 is another DaVinci SOC which uses the EMAC driver and i will be sending patches that add DaVinci DM6467 support to the list soon. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor ramdisk locating codeKumar Gala
Move determing if we have a ramdisk and where its located into the common code. Keep track of the ramdisk start and end in the bootm_headers_t image struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21Consolidate strmhz() implementationHaavard Skinnemoen
ARM, i386, m68k and ppc all have identical implementations of strmhz(). Other architectures don't provide this function at all. This patch moves strmhz() into lib_generic, reducing code duplication and providing a more unified API across architectures. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-30ARM: set GD_FLG_RELOC for boards skipping relocation to RAMRemy Bohmer
If CONFIG_SKIP_RELOCATE_UBOOT is set the flag GD_FLG_RELOC is usually never set, because relocation to RAM is actually never done by U-boot itself. However, several pieces of code check if this flag is set at some time. So, to make sure this flag is set on boards skipping relocation, this is added to the initialisation of U-boot at a moment where it is safe to do so. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-07-20Remove unused code from lib_arm/bootm.cGururaja Hebbar K R
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-05-28Remove prototypes of nand_init() in favor of including nand.h.Scott Wood
Likewise with onenand_init(). Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add ATMEL LCD driverStelian Pop
This patch adds support for the ATMEL LCDC driver which is used on some AT91 and AVR platforms. Is has been tested with the AT91CAP9ADK, AT91SAM9261EK, AT91SAM9263EK and AT91SAM9RLEK boards. Adaptation for AVR32 should probably be easy. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-03Fix implicit declaration build warningsMarcel Ziswiler
- warning: implicit declaration of function ‘serial_initialize’ Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-21Merge branch 'master' of /home/git/u-bootMarian Balakowicz
2008-02-15Merge branch '080208_dupint' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14ARM: make the machid configurable via the environmentUwe Kleine-König
If the variable "machid" exists, let do_bootm_linux use that instead of bd->bi_arch_number. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
2008-02-14ARM: cleanup duplicated exception handlingcodeAndreas Engel
Move duplicated exception handling code into lib_arm. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
2008-02-07[new uImage] Factor out common image_get_ramdisk() routineMarian Balakowicz
Architecture specific do_bootm_linux() routines share common ramdisk image processing code. Move this code to a common helper routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Cleanup image header pointer use in bootm codeMarian Balakowicz
- use single image header pointer instead of a set of auxilliary variables. - add multi component image helper routines: get component size/data address Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
