Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
The esdhc controller in the mx51 processor is quite
the same as the one in some powerpc processors
(MPC83xx, MPC85xx). This patches adapts the driver
to support the arm mx51.
GCC 4.4 complains about this now.
Signed-off-by: Ron Lee <ron@debian.org>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
This lays the groundwork to allow architectures to share a common
mem_malloc_init().
Note that the x86 implementation was not modified as it did not fit the
mold of all other architectures.
All in-tree boards that use this controller have CONFIG_NET_MULTI added
Also:
- changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900
- changed CS8900_BASE to CONFIG_CS8900_BASE
- changed CS8900_BUS?? to CONFIG_CS8900_BUS??
- cleaned up line lengths
- modified VCMA9 command function that accesses the device
- removed MAC address initialization from lib_arm/board.c
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
and fix comment
Adjusted Copyright message.
This patch is required for Kirkwood support
may be used by other ARM architectures
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it
There is exiting support for red,yellow,green but no blue.
The main LED on the zoom2 is a blue LED.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
actually the timer init use the interrupt_init as init callback
which make the interrupt and timer implementation difficult to follow
so now rename it as int timer_init(void) and use interrupt_init for interrupt
btw also remane the corresponding file to the functionnality implemented
as ixp arch implement two timer - one based on interrupt - so all the timer
related code is moved to timer.c
This patch moves the malloc initialization before calling flash_init().
Upcoming changes to the NOR FLASH common CFI driver with optional
MTD infrastructure and MTD concatenation support will call malloc().
And nothing really speaks against enabling malloc just a little earlier
in the boot stage. Some architectures already enable malloc before
calling flash_init() so they don't need any changes here.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Scott McNutt <smcnutt@psyent.com>
Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: John Rigby <jcrigby@gmail.com>
For a long time, the print_cpuinfo() declaration in lib_arm/board.c
had been marked as "test-only", which is plain wrong considering
current usage. Delete this misleading comment.
calculate dynamically the clock rate and pllb setting for usb
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to
handle this board specially in common ARM code.
CC: Ben Warren <biggerbadderben@gmail.com>
Some warts are remaining and should be killed off (by moving the func to
the appropriate board init code):
- davinci_eth_set_mac_addr
- cs8900_get_enetaddr
- smc_set_mac_addr
Serial driver via the EmbeddedICE macrocell's DCC channel using
co-processor 14.
It does include a timeout to ensure that the system does not
totally freeze when there is nothing connected to read.
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
Acked-by: Rafal Jaworowski <raj@semihalf.com>
The "size" variable in start_armboot() in lib_arm/board.c is only really
used in "#ifndef CONFIG_SYS_NO_FLASH" case, and even there it can be
eliminated (thanks to Jean-Christophe PLAGNIOL-VILLARD for a suggestion.)
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
due to the arm implementation which supposed that U-Boot is in RAM
when we jump to start_armboot
Signed-off-by: gnusercn <gnusercn@gmail.com>
we need this due to the arm implementation which supposed that U-Boot
is in RAM when we jump to start_armboot
This reverts commit f96b44cef897bd372beb86dde1b33637c119d84d.
in order to do it for all arm board
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
ARM, i386, m68k and ppc all have identical implementations of strmhz().
Other architectures don't provide this function at all.
This patch moves strmhz() into lib_generic, reducing code duplication
and providing a more unified API across architectures.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Likewise with onenand_init().
This patch adds support for the ATMEL LCDC driver which is used on some
AT91 and AVR platforms.
Is has been tested with the AT91CAP9ADK, AT91SAM9261EK, AT91SAM9263EK and
AT91SAM9RLEK boards. Adaptation for AVR32 should probably be easy.
Signed-off-by: Stelian Pop <stelian@popies.net>
- warning: implicit declaration of function ‘serial_initialize’
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Adds I2C init func call to init sequence for ARM boards. This is
present in ppc,blackfin and other processor init sequence.
Signed-off-by: K R Gururaja Hebbar <gururajakr@sanyo.co.in>
Add until the new phylib will be arrived
[PATCH 3/3] OneNAND support (take #2)
OneNAND support at U-Boot
This patch adds support for multiple serial ports to the PXA target.
FFUART, BTUART and STUART are supported.
Use it in cpu/arm920t/start.S to indicate U-Boot code has been entered.
Add support for the following DaVinci boards:
- DV_EVM
- SCHMOOGIE
- SONATA
Changes:
- Split into separate board directories
- Removed changes to MTD_DEBUG (or whatever it's called)
- New CONFIG_CMD party line followed
- Some cosmetic fixes, cleanup etc.
- Patches against the latest U-Boot tree as of now.
- Fixed CONFIG_CMD_NET in net files.
- Fixed CONFIG_CMD_EEPROM for schmoogie.
- Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and
DV_EVM. Can't check if it works on SONATA, don't have a board any more,
but it at least compiles.
Here is an excerpt from session log on SCHMOOGIE...
U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17)
DRAM: 128 MB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 297MHz
DDR Clock : 162MHz
ETH PHY : DP83848 @ 0x01
U-Boot > iprobe
Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F
U-Boot > ping 192.168.253.10
host 192.168.253.10 is alive
U-Boot >
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
CONFIG_COMMANDS
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
DRAM
