path: root/lib_arm/board.c
2006-04-25cosmetic: print amount of NAND flash aligned with the other values such asMarkus Klotzbuecher
DRAM
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-10Changed gcc-4.0 global data pointer fix to conform with the fix for this onMarkus Klotzbücher
other platforms (see c75eba3b4140187cd0d9bd8049f5df4c49b6889b)
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2006-01-29Cleanup U-Boot boot messages on ARM.Wolfgang Denk
To match the U-Boot user interface on ARM platforms to the U-Boot standard (as on PPC platforms), some messages with debug character are removed from the default U-Boot build. Enable DEBUG for lib_arm/board.c to enable debug messages. New CONFIG_DISPLAY_CPUINFO and CONFIG_DISPLAY_BOARDINFO options. Patch by Stefan Roese, 24 Jan 2006
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-08-19Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2Wolfgang Denk
Patch by Martin Krause, 08 Jun 2005
2005-04-01Patch by Martin Krause, 01 Apr 2005:wdenk
Add automatic HW detection for CMC_PU2 and CMC_BASIC
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11* Patch by Philippe Robin, 01 Jul 2004:wdenk
Add initialization for Integrator and versatile board files. * Patch by Hinko Kocevar, 01 Jun 2004: Fix VFD FB allocation, add LCD FB allocation on ARM
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-06-17* Fix flash parameters passed to Linux for PPChameleon boardwdenk
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-06Patch by Dave Peverley, 29 Apr 2004:wdenk
add MAC address detection to smc91111 driver
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2004-02-06* Patch by Wolter Kamphuis, 15 Dec 2003:wdenk
made CONFIG_SILENT_CONSOLE usable on all architectures * Disable date command on TQM866M - there is no RTC on MPC866
2003-12-07* Patch by Xue Ligong (Joe), 13 Nov 2003:wdenk
add Realtek 8019 ethernet driver * Patch by Yuli Barcohen, 13 Nov 2003: MPC826xADS/PQ2FADS cleanup * Patch by Anders Larsen, 12 Nov 2003: Update README to mark the PORTIO commands non-standard
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-09-17Support new configuration of TRAB board with more memorywdenk
Minor cleanup of comments
2003-09-17Add auto-update code for TRAB board using USB memory stickswdenk
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-06-22* Patch by Rune Torgersen, 4 Jun 2003:wdenk
add large memory support for MPC8266ADS board * Patch by Richard Woodruff, 19 June 03: - Enabled standard u-boot device abstraction for ARM - Enabled console device for ARM - Initilized bi_baudrate for ARM * Patch by Bill Hargen, 23 Apr 2003: fix byte order for 824x I2C addresses (write op)
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README.
