ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
made CONFIG_SILENT_CONSOLE usable on all architectures
* Disable date command on TQM866M - there is no RTC on MPC866
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
add Realtek 8019 ethernet driver
* Patch by Yuli Barcohen, 13 Nov 2003:
MPC826xADS/PQ2FADS cleanup
* Patch by Anders Larsen, 12 Nov 2003:
Update README to mark the PORTIO commands non-standard
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
* Fix problems in memory test on some boards (which was not
non-destructive as intended)
* Patch by Gary Jennejohn, 28 Oct 2003:
Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack
to prevent stack overflow on ARM systems
for more information
Minor cleanup of comments
- allow for longer timeouts for USB mass storage devices
* Patch by Denis Peter, 11 Sep 2003:
- fix USB data pointer assignment for bulk only transfer.
- prevent to display erased directories in FAT filesystem.
* Change output format for NAND flash - make it look like for other
memory, too
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
add large memory support for MPC8266ADS board
* Patch by Richard Woodruff, 19 June 03:
- Enabled standard u-boot device abstraction for ARM
- Enabled console device for ARM
- Initilized bi_baudrate for ARM
* Patch by Bill Hargen, 23 Apr 2003:
fix byte order for 824x I2C addresses (write op)
- rewrite of the S3C24X0 register definitions stuff
- "driver" for the built-in S3C24X0 RTC
* Patches by Yuli Barcohen, 12 Jun 2003:
- Add MII support and Ethernet PHY initialization for MPC8260ADS board
- Fix incorrect SIUMCR initialisation caused by wrong Hard Reset
configuration word supplied by FPGA on some MPC8260ADS boards
* Patch by Pantelis Antoniou, 10 Jun 2003:
Unify status LED interface
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
Add IDMA example code (tested on 8260 only)
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
* Start adding MIPS support files
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
seconds instead of ms.
* Patch by Robert Schwebel, 1 Nov 2002:
XScale related cleanup (affects all ARM boards)
* Cleanup of names, warnings and README.
