path: root/lib
2011-12-07Include common.h in qsort.c to fix build warningSimon Glass
exports.h no longer includes common.h, which contains assert(). qsort.c needs to be updated. This fixes this warning: qsort.c: In function 'qsort': qsort.c:30:3: warning: implicit declaration of function 'assert' [-Wimplicit-function-declaration] Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Tested-by: Heiko Schocher <hs@denx.de>
2011-11-22sandbox: Fix warnings in hashtable.cSimon Glass
This fixes a few printf() strings for size_t which are missing the 'z' modifier. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-08env: allow to export only selected variablesWolfgang Denk
New syntax: env export [-t | -b | -c] [-s size] addr [var ...] With this change it is possible to provide a list of variables names that shall be exported. Whenno arguments are given, the whole environment gets exported. NOTE: The new handling of the "size" argument means a change to the user API. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-28zlib: Fix integer cast of pointerSimon Glass
Fix to cast an integer to a pointer using uintptr_t. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27GCC4.6: Squash warnings in LzmaTools.cMarek Vasut
LzmaTools.c: In function 'lzmaBuffToBuffDecompress': LzmaTools.c:70:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'unsigned char *' LzmaTools.c:71:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'unsigned char *' LzmaTools.c:72:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'unsigned char *' LzmaTools.c:73:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'unsigned char *' LzmaTools.c:74:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'unsigned char *' LzmaTools.c:110:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'SizeT' LzmaTools.c:111:5: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'SizeT' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-26fdt: add decode helper librarySimon Glass
This library provides useful functions to drivers which want to use the fdt to control their operation. Functions are provided to: - look up and enumerate a device type (for example assigning i2c bus 0, i2c bus 1, etc.) - decode basic types from the fdt, like addresses and integers While this library is not strictly necessary, it helps to minimise the changes to a driver, in order to make it work under fdt control. Less code is required, and so the barrier to switch drivers over is lower. Additional functions to read arrays and GPIOs could be made available here also. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17lib: add uuid_str_to_bin for use with bootp and PXE uuidJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17zlib: handle overflow while calculating available stream input sizeAnatolij Gustschin
If compressed data is located in sectors at the end of the flash and it's offset + input stream size > 0xFFFFFFFF, the uncompressing time is very long, since processing of the stream is done bytewise (and not blockwise) due to overflow in inflate_fast() while calculation and checking for enough input available. Check for this overflow condition and limit the available stream input size to the actually max. possible input size. This fixes the problem. The issue is easily reproduceable by placing a gziped bitmap in flash, e.g. at FFF80000, and running 'bmp' commands like 'bmp info FFF80000' or 'bmp display FFF80000'. The uncompressing can take up to 3 sec. whereas it should normaly take a fraction of a second. If the 'splashimage' environment variable points to this address, the booting time also increases significantly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-01GCC4.6: Squash warning in lzo1x_decompress.cMarek Vasut
lzo1x_decompress.c: In function ‘parse_header’: lzo1x_decompress.c:35:5: warning: variable ‘level’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-10Add assert() for debug assertionsSimon Glass
assert() is like BUG_ON() but compiles to nothing unless DEBUG is defined. This is useful when a condition is an error but a board reset is unlikely to fix it, so it is better to soldier on in hope. Assertion failures should be caught during development/test. It turns out that assert() is defined separately in a few places in U-Boot with various meanings. This patch cleans up some of these. Build errors exposed by this change (and defining DEBUG) are also fixed in this patch. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-30Constify getenv(), setenv() and hash code functionsWolfgang Denk
This is needed to get rid of build warnings like main.c:311: warning: passing argument 2 of 'setenv' discards qualifiers from pointer target type which result from commit 09c2e90 "unify version_string". Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-28panic: remove warning "'noreturn' function does return"Heiko Schocher
since commit commit d2e8b911c0a0661d395ccac72156040702ac842d Author: Mike Frysinger <vapier@gentoo.org> Date: Wed Jun 29 11:58:04 2011 +0000 panic: add noreturn attribute I see the following warnings: vsprintf.c: In function 'panic': vsprintf.c:730: warning: 'noreturn' function does return for nearly all boards. This patch fixes this warning. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Mike Frysinger <vapier@gentoo.org>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26scaled down version of generic libraries for SPLAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-26memcpy/memmove: Do not copy to same addressMatthias Weisser
In some cases (e.g. bootm with a elf payload which is already at the right position) there is a in place copy of data to the same address. Catching this saves some ms while booting. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14libfdt: Implement property iteration functionsDavid Gibson
For ages, we've been talking about adding functions to libfdt to allow iteration through properties. So, finally, here are some. I got bogged down on this for a long time because I didn't want to expose offsets directly to properties to the callers. But without that, attempting to make reasonable iteration functions just became horrible. So eventually, I settled on an interface which does now expose property offsets. fdt_first_property_offset() and fdt_next_property_offset() are used to step through the offsets of the properties starting from a particularly node offset. The details of the property at each offset can then be retrieved with either fdt_get_property_by_offset() or fdt_getprop_by_offset() which have interfaces similar to fdt_get_property() and fdt_getprop() respectively. No explicit testcases are included, but we do use the new functions to reimplement the existing fdt_get_property() function. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: 73dca9ae0b9abe6924ba640164ecce9f8df69c5a Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2011-07-14Support ePAPR compliant phandle propertiesDavid Gibson
Currently, the Linux kernel, libfdt and dtc, when using flattened device trees encode a node's phandle into a property named "linux,phandle". The ePAPR specification, however - aiming as it is to not be a Linux specific spec - requires that phandles be encoded in a property named simply "phandle". This patch adds support for this newer approach to dtc and libfdt. Specifically: - fdt_get_phandle() will now return the correct phandle if it is supplied in either of these properties - fdt_node_offset_by_phandle() will correctly find a node with the given phandle encoded in either property. - By default, when auto-generating phandles, dtc will encode it into both properties for maximum compatibility. A new -H option allows either only old-style or only new-style properties to be generated. - If phandle properties are explicitly supplied in the dts file, dtc will not auto-generate ones in the alternate format. - If both properties are supplied, dtc will check that they have the same value. - Some existing testcases are updated to use a mix of old and new-style phandles, partially testing the changes. - A new phandle_format test further tests the libfdt support, and the -H option. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: d75b33af676d0beac8398651a7f09037555a550b Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2011-05-12lib, vsprintf: introduce strict_strtoulHeiko Schocher
as checkpatch proposes to use strict_strtoul instead of simple_strtoul, introduce it. Ported this function from Linux 2.6.38 commit ID: 521cb40b0c44418a4fd36dc633f575813d59a43d Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-12zlib: fix DEBUG buildMike Frysinger
The previous commit imported a little too much from upstream. We need to disable stdio.h when using U-Boot. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-28common: add a grepenv commandKim Phillips
u-boot environments, esp. when boards are shared across multiple users, can get pretty large and time consuming to visually parse. The grepenv command this patch adds can be used in lieu of printenv to facilitate searching. grepenv works like printenv but limits its output only to environment strings (variable name and value pairs) that match the user specified substring. the following examples are on a board with a 5313 byte environment that spans multiple screen pages: Example 1: summarize ethernet configuration: => grepenv eth TSEC etact=FM1@DTSEC2 eth=FM1@DTSEC4 ethact=FM1@DTSEC2 eth1addr=00:E0:0C:00:8b:01 eth2addr=00:E0:0C:00:8b:02 eth3addr=00:E0:0C:00:8b:03 eth4addr=00:E0:0C:00:8b:04 eth5addr=00:E0:0C:00:8b:05 eth6addr=00:E0:0C:00:8b:06 eth7addr=00:E0:0C:00:8b:07 eth8addr=00:E0:0C:00:8b:08 eth9addr=00:E0:0C:00:8b:09 ethaddr=00:E0:0C:00:8b:00 netdev=eth0 uprcw=setenv ethact $eth;setenv filename p4080ds/R_PPSXX_0xe/rcw_0xe_2sgmii_rev2_high.bin;setenv start 0xe8000000;protect off all;run upimage;protect on all upuboot=setenv ethact $eth;setenv filename u-boot.bin;setenv start eff80000;protect off all;run upimage;protect on all upucode=setenv ethact $eth;setenv filename fsl_fman_ucode_P4080_101_6.bin;setenv start 0xef000000;protect off all;run upimage;protect on all usdboot=setenv ethact $eth;tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/initramfs.cpio.gz.uboot;tftp c00000 $dir/p4080ds-usdpaa.dtb;setenv bootargs root=/dev/ram rw console=ttyS0,115200 $othbootargs;bootm 1000000 2000000 c00000; => Example 2: detect unused env vars: => grepenv etact etact=FM1@DTSEC2 => Example 3: reveal hardcoded variables; e.g., for fdtaddr: => grepenv fdtaddr fdtaddr=c00000 nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr => grep $fdtaddr fdtaddr=c00000 my_boot=bootm 0x40000000 0x41000000 0x00c00000 my_dtb=tftp 0x00c00000 $prefix/p4080ds.dtb nohvboot=tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/$ramdiskfile;tftp c00000 $dir/$fdtfile;setenv bootargs root=/dev/ram rw ramdisk_size=0x10000000 console=ttyS0,115200;bootm 1000000 2000000 c00000; => This patch also enables the grepenv command by default on corenet_ds based boards (and repositions the DHCP command entry to keep the list sorted). Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2011-04-28env: fix env var autocompletionKim Phillips
commit 560d424b6d7cd4205b062ad95f1b104bd4f8bcc3 "env: re-add support for auto-completion" fell short of its description - the 'used' logic in hmatch_r was reversed - 'used' is 0 if the hash table entry is not used, or -1 if deleted. This patch makes hmatch_r actually match on valid ('used') entries, instead of skipping them and failing to match anything. typing 'printenv tft' and hitting 'tab' now displays valid choices for variable names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Mike Frysinger <vapier@gentoo.org>
2011-04-12Fix gunzip to work for any gziped uImage sizeCatalin Radu
Signed-off-by: Catalin Radu <Catalin@VirtualMetrix.com>
2011-03-22strmhz: Make hz unsigned to support greater than 2146 MHz clockEd Swarthout
For example, an input of 0x80000000 should print: 2147.484 instead of -2147.-483. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-22Fix hash table deletion to prevent lost entriesPeter Barada
Use negative used value to mark deleted entry. Search keeps probing past deleted entries. Adding an entry uses first deleted entry when it hits end of probe chain. Initially found that "ramdiskimage" and "preboot" collide modulus 347, causing "preboot" to be inserted at idx 190, "ramdiskimage" at idx 191. Previous to this fix when "preboot" is deleted, "ramdiskimage" is orphaned. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Tested-by: Wolfgang Denk <wd@denx.de>
2011-01-18lib: add crc7 from LinuxThomas Chou
Crc7 is used to compute mmc spi command packet checksum. Copy from linux-2.6 lib/crc7.c include/linux/crc7.h commit ad241528c4919505afccb022acbab3eeb0db4d80 Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-01-17Small coding style fix in lib/asm-offsets.cStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Michal Simek <monstr@monstr.eu>
2011-01-09asm-offsets: generate bd_t sizeMike Frysinger
Some ports set up the board info structure at the same time as the global data structure, and largely keep them together. So generate a define for the board info struct too. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-09env: re-add support for auto-completionMike Frysinger
Currently, only basic completion is supported (no globs), but this is what we had previously. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28ctype: constify lookup tableMike Frysinger
2010-11-28string_to_ip: constify "s" argMike Frysinger
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-12zlib: Add further watchdog reset callsStefan Roese
Patch 253cb831 [zlib: add watchdog reset call] added already a few watchdog reset calls to the new zlib U-Boot port. But on some boards this is not enough. Additional calls are needed on boards with short watchdog timeouts. This was detected and tested on the lwmon5 board with a very short watchdog timeout. Without this patch, the board resets during Linux kernel decompression. With it, the decompression succeeds. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-10-12zlib/gunzip: Use WATCHDOG_RESET macroStefan Roese
As usually done in U-Boot, the watchdog_reset code is called via a macro (WATCHDOG_RESET). In zlib.c this was done differently, by using a function pointer which is initialized with WATCHDOG_RESET upon watchdog usage or with NULL otherwise. This patch now uses the plain WATCHDOG_RESET macros to call the function resulting in slightly smaller U-Boot images and simpler code. U-Boot code size reduction: PowerPC board with watchdog support (lwmon5): -> 80 bytes smaller image size PowerPC board without watchdog support (sequoia): -> 112 bytes smaller image size Signed-off-by: Stefan Roese <sr@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-10-06lib/hashtable.c: add CONFIG_ENV_MIN_ENTRIESAndreas Bießmann
This patch adds a new config parameter for adjusting the calculation of hash table size when importing a buffer. When importing a extremely small buffer (e.g. the default_environment) the old calculation generated a hash table which could hold at most the buffer content but no more entires. The new calculation add a fixed number of entries to the result to fit better for small import buffers. This amount may be configured by the user in board file to adjust the behaviour. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Add hash table support as base for new environment codeWolfgang Denk
This implementation is based on code from uClibc-0.9.30.3 but was modified and extended for use within U-Boot. Major modifications and extensions: * hsearch() [modified / extended]: - While the standard version does not make any assumptions about the type of the stored data objects at all, this implementation works with NUL terminated strings only. - Instead of storing just pointers to the original objects, we create local copies so the caller does not need to care about the data any more. - The standard implementation does not provide a way to update an existing entry. This version will create a new entry or update an existing one when both "action == ENTER" and "item.data != NULL". - hsearch_r(): Instead of returning 1 on success, we return the index into the internal hash table, which is also guaranteed to be positive. This allows us direct access to the found hash table slot for example for functions like hdelete(). * hdelete() [added]: - The standard implementation of hsearch(3) does not provide any way to delete any entries from the hash table. We extend the code to do that. * hexport() [added]: - Export the data stored in the hash table in linearized form: Entries are exported as "name=value" strings, separated by an arbitrary (non-NUL, of course) separator character. This allows to use this function both when formatting the U-Boot environment for external storage (using '\0' as separator), but also when using it for the "printenv" command to print all variables, simply by using as '\n" as separator. This can also be used for new features like exporting the environment data as text file, including the option for later re-import. - The entries in the result list will be sorted by ascending key values. * himport() [added]: - Import linearized data into hash table. This is the inverse function to hexport(): it takes a linear list of "name=value" pairs and creates hash table entries from it. - Entries without "value", i. e. consisting of only "name" or "name=", will cause this entry to be deleted from the hash table. - The "flag" argument can be used to control the behaviour: when the H_NOCLEAR bit is set, then an existing hash table will kept, i. e. new data will be added to an existing hash table; otherwise, old data will be discarded and a new hash table will be created. - The separator character for the "name=value" pairs can be selected, so we both support importing from externally stored environment data (separated by NUL characters) and from plain text files (entries separated by newline characters). - To allow for nicely formatted text input, leading white space (sequences of SPACE and TAB chars) is ignored, and entries starting (after removal of any leading white space) with a '#' character are considered comments and ignored. - NOTE: this means that a variable name cannot start with a '#' character. - When using a non-NUL separator character, backslash is used as escape character in the value part, allowing for example fo multi-line values. - In theory, arbitrary separator characters can be used, but only '\0' and '\n' have really been tested. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Add qsort - add support for sorting data arraysWolfgang Denk
Code adapted from uClibc-0.9.30.3 Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Add basic errno support.Wolfgang Denk
Needed for hash table support; probably useful in a lot of other places as well. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-13display_buffer: fix misaligned bufferReinhard Meyer
use a union to cause necessary alignment per architecture Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-09print_buffer: optimize & shrinkMike Frysinger
Applying a little creative format string allows us to shrink the initial data read & display loop by only calling printf once. Re-using the local data buffer to generate the string we want to display then allows us to output everything with just one printf call instead of multiple calls to the putc function. The local stack buffer needs increasing by 1 byte, but the resulting code shrink and speed up is worth it I think. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
