If a variable already exists, efi_set_variable() should not change
the variable's attributes. This patch enforces it.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
The current efi_st_variable() doesn't support EFI_VARIABLE_APPEND_WRITE
attiribute for now, and so should return an error.
Fix typos is commit message.
Add TODO comment.
The error here should be marked *todo*.
According to the FAT32 specification 0x7f (DEL) is not a legal character
for file names.
Since commit 226cddbe32f0 ("efi_loader: check device path in
InstallMultipleProtocolInterfaces") iPXE fails to access the network.
LocateDevicePath() returns EFI_SUCCESS even if a shorter path is found as a
partial match. It returns the remaining path. So to be sure that we found a
complete match we need to check that the remaining path refers to an end
node.
Provide debug output if a device path has already been installed.
Fixes: 226cddbe32f0 ("efi_loader: check device path in
According to the UEFI spec 2.8 the GetTime() runtime service should return
EFI_UNSUPPORTED if the real time clock is not available.
Implement the SetTime() runtime service.
Extend the real time clock selftest to check setting the clock.
U-Boot already defines the {upper,lower}_32_bits() macros that have the
same purpose. Use the existing macros instead of defining new APIs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Check the parameters against NULL.
KeyToggleState is a pointer according to UEFI spec 2.8.
Do not write to address indicated by NULL pointer.
UEFI SCT II 2.6 (2017), 3.6.5 GetNextMonotonicCount(), 5.1.5.5.1
Not checking the parameters may lead reading or writing from NULL.
Implement the parameter checks prescribed in the UEFI spec.
According to the UEFI spec InstallMultipleProtocolInterfaces() must check
if a device path has already been installed. In this case it must return
EFI_ALREADY_STARTED.
Cf. UEFI SCT II 2.6 A (2017),
3.3.16 InstallMultipleProtocolInterfaces(), 5.1.3.16.1.
In EFI 1.10 a version of the Unicode collation protocol using ISO 639-2
language codes existed. This protocol is not part of the UEFI specification
any longer. Unfortunately it is required to run the UEFI Self Certification
Test (SCT) II, version 2.6, 2017. So we implement it here for the sole
purpose of running the SCT. It can be removed once a compliant SCT is
available.
The configuration option defaults to no.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Most of Rob's original patch is already merged. Only the deprecated
protocol is missing. Rebase it and make it configurable.
Rename variables to make it clear they refer to the Unicode collation
protocol identified by the EFI_UNICODE_PROTOCOL2_GUID.
In the implementation of the device path to text protocol join adjacent
sprintf() statements.
Check buffer pointers are not NULL as required by the UEFI 2.7 spec.
Return EFI_UNSUPPORTED instead of EFI_INVALID_PARAMETER when trying to
transmit with non-zero header_size.
UEFI spec 2.7 erratum A leaves it undefined if Attributes should be set if
GetVariable() returns EFI_BUFFER_TOO_SMALL.
UEFI spec 2.8 defines that Attributes should be set if the return value is
either EFI_SUCCESS or EFI_BUFFER_TOO_SMALL.
Set Attributes if the return value is EFI_BUFFER_TOO_SMALL.
The device path to text protocol renders ACPI device nodes incorrectly.
Use capital hexadecimal numbers as shown in the UEFI spec examples.
Always output the optional UID. This matches what UEFI SCT expects and
saves us an `if`.
UEFI SCT uses this call sequence to determine the current TPL level inside
notification functions:
OldTpl = BS->RaiseTPL(TPL_HIGH_LEVEL);
BS->RestoreTPL(OldTpl);
In RestoreTPL() we trigger the notification function of queued events. If
we do not mark the event as non-queued before calling the notification
function, this results in an infinite recursive call sequence.
Mark the event as non-queued before entering the notification function.
Replace unnecessary control structures by using return statements.
If AllocatePages() is called with AllocateAddress, the UEFI spec requires
to return EFI_NOT_FOUND in case the memory page does not exist.
The UEFI SCT II 2017 spec additionally requires to return EFI_NOT_FOUND if
the page is already allocated.
Check that *Memory refers to an unallocated page.
UEFI SCT II (2017): AllocatePages(), 5.1.2.1.9 - 5.1.2.1.10
According to the UEFI AllocatePages() has to return EFI_OUT_OF_RESOURCES if
sufficient memory is not available.
Change the return value.
UEFI SCT II (2017): 3.2.1 AllocatePages(), 5.1.2.1.8
When we call FreePages() we essentially add memory to our memory map. We
shouldn't do this for memory that does not exit.
Check if the memory that is to be freed via FreePages() or FreePool() is in
our memory map and is not EFI_CONVENTIONAL_MEMORY.
This check is mandated by the UEFI specification.
Cf. UEFI SCT II (2017), 3.2.2 FreePages(), 5.1.2.1 - 5.1.2.2
According to the UEFI specification UninstallProtocolInteface() has to
return EFI_NOT_FOUND if the interface is not found.
Correct the return value.
Cf. UEFI SCT II spec (2017), 3.3.2 UninstallProtocolInterface(), 5.1.3.2.4
efi_search_protocol() already checks that the GUID matches. Don't check
a second time.
A parameter check in LocateDevicePath() does not match the requirements of
the UEFI spec.
If device is NULL, only return EFI_INVALID_PARAMETER if a matching handle
is found.
Cf. UEFI SCT II specification (2017)3.3.7 LocateDevicePath(), 5.1.3.7.3
%s/not buffer/no buffer/
The device path to text protocol is not needed for EBBR compliance. So
let's make it a customizable option.
The Unicode collation protocol is not needed for EBBR compliance. So let's
The Unicode capitalization table is only needed by this protocol. So let it
depend on the Unicode collation protocol.
No need to mention U-Boot in brief description.
Fix several typos, mention iPXE.
Use if/endif for dependencies to give structure to the configuration menu.
Sort important settings to the top.
Abbreviate the short description of EFI_LOADER_HII.
If EFI_LOADER_HII is not set, do not unnecessarily compile files for HII
protocols.
Consistently use efi_uintn_t as type of memory keys.
Reviewed-by: Alexander Graf <graf@amazon.com>
If the size of the source buffer is 0, return EFI_LOAD_ERROR.
(UEFI SCT II 2017: 3.4.1 LoadImage() - 5.1.4.1.6)
If the parent image handle does not refer to a loaded image return
EFI_INVALID_PARAMETER.
(UEFI SCT II 2017: 3.4.1 LoadImage() - 5.1.4.1.1)
Mark our root node as a loaded image to avoid an error when using it as
parent image.
HandleProtocol() and OpenProtocol() have to return EFI_UNSUPPORTED if the
protocol is not installed on the handle.
For correct indentation of messages in the UEFI API implementation use
EFI_PRINT() instead of debug().
Return EFI_INVALID_PARAMETER from CloseProtcol() if the agent handle is not
valid.
Return EFI_INVALID_PARAMETER if the optional controller handle is not
valid.
Return immediately from efi_search_obj if the handle is NULL.
Provide a unit test for the RegisterProtocolNotify() boot service.
The RegisterProtocolNotify() boot service registers an event to be
notified upon the installation of a protocol interface with the
specified GUID.
Add the missing implementation.
The notification function of events of type EVT_NOTIFY_SIGNAL should always
be queued when SignalEvent() is called.
Function memcmp() is available in efi_freestanding.c. So we do not remove a
further implementation.
Replace all usages of efi_st_memcmp() by memcmp().
Implement unloading of images in the Exit() boot services:
* unload images that are not yet started,
* unload started applications,
* unload drivers returning an error.
Implement the UnloadImage() boot service
Move efi_unload_image() down in source to avoid forward declaration in
follwing page.
In UnloadImage() we need to know if an image is already started.
Add a field to the handle structure identifying loaded and started images.
If LocateHandle() does not find an entry EFI_NOT_FOUND has to be returned
even if BufferSize is NULL.
CreateEventEx() does not allow the following event types:
* EVT_SIGNAL_EXIT_BOOT_SERVICES
* EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE
This check is needed to pass the UEFI SCT conformance test.
Reviewed-by: Alexander Graf <agraf@csgraf.de>
allow_unaligned(), switch_to_non_secure_mode(), and efi_init_obj_list() are
called in sequence in multiple places.
Move calls to allow_unaligned() and switch_to_non_secure_mode() to
efi_init_obj_list().
Remove unused includes.
