When copying a string with must allocate a byte for the terminating '\0' in
the target buffer.
Fixes: fbe4c7df0087 ("efi_loader: enable file SetInfo()")
Add missing newline to log messages in efi_rng_register() otherwise
something like below would be shown
Scanning disk virtio-blk#31...
Found 2 disks
Missing RNG device for EFI_RNG_PROTOCOLNo EFI system partition
Signed-off-by: Paulo Alcantara (SUSE) <pc@cjr.nz>
When calling ExitBootServices during out unit tests we should not detach
devices as we need console output for runtime tests.
Fixes: 529441ca89b1 ("efi_loader: Disable devices before handing over control")
For implementing the EFI_TCG2_PROTOCOL we need the count field returned by
the TPM when reading capabilities via tpm2_get_capability().
Adjust the implementation of the 'tpm2 get_capability' command accordingly.
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
For validating the fixed up device tree we need a tool to need to save it
to a file.
dtbdump.efi copies the configuration table with the device tree to a file
on the same partition from which dtbdump.efi was invoked. The file name can
be entered on the console.
When deleting a non-volatile variable it was deleted from memory but the
deletion was not persisted to the file system.
SetVariable() may be called with attributes == 0 to delete a variable. To
determine if the deletion shall be persisted we have to consider the
non-volatile flag in the attributes of the deleted variable and not the
value passed in the call parameter.
patman status subcommand to collect tags from Patchwork
patman showing email replies from Patchwork
sandbox poweroff command
minor fixes in binman, tests
Now that we can use devicetree to specify this information, drop the old
CONFIG options.
Some boards want to specify the manufacturer or product name but do not
need to have their own sysinfo driver.
Add a default driver which provides a way to specify this SMBIOS
information in the devicetree, without needing any board-specific
functionality.
The current tables only support a subset of the available fields defined
by the SMBIOS spec. Add a few more.
We could use CONFIG_SYS_CPU or CONFIG_SYS_SOC as a default for family, but
the meaning of that value relates more to the whole system rather than
just the SoC.
Support a way to put SMBIOS properties in the device tree. These can be
placed in a 'board' device in an 'smbios' subnode.
As a first step to obtaining SMBIOS information from the devicetree, add
an ofnode parameter to the writing functions.
If there is no reset line, this still emits ACPI code for the reset GPIO.
Fix it by updating the check.
At present all tables are placed starting at address f0000 in memory, and
can be up to 64KB in size. If the tables are very large, this may not
provide enough space.
Also if the tables point to other tables (such as console log or a ramoops
area) then we must allocate other memory anyway.
The bloblist is a nice place to put these tables since it is contiguous,
which makes it easy to reserve this memory for linux using the 820 tables.
Add an option to put some of the tables in the bloblist. For SMBIOS and
ACPI, create suitable pointers from the f0000 region to the new location
of the tables.
[bmeng: squashed in http://patchwork.ozlabs.org/project/uboot/patch/
20201105062407.1.I8091ad931cbbb5e3b6f6ababdf3f8d5db0d17bb9@changeid/]
There is prepared function for filing rom_offset. That's why use it instead
of copying content of it.
Add a very simple API to be able to access SMBIOS strings
like vendor, model and bios version.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2021-01-rc2 (2)
The series contains the following enhancements
* preparatory patches for UEFI capsule updates
* initialization of the emulated RTC using an environment variable
and a bug fix
* If DisconnectController() is called for a child controller that is the
only child of the driver, the driver must be disconnected.
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
of-platdata and dtoc improvements
sandbox SPL tests
binman support for compressed sections
Some commands can get very unweildy if they have too many positional
arguments. Adding options makes them easier to read, remember, and
understand.
This implementation of getopt has been taken from barebox, which has had
option support for quite a while. I have made a few modifications to their
version, such as the removal of opterr in favor of a separate getopt_silent
function. In addition, I have moved all global variables into struct
getopt_context.
The getopt from barebox also re-orders the arguments passed to it so that
non-options are placed last. This allows users to specify options anywhere.
For example, `ls -l foo/ -R` would be re-ordered to `ls -l -R foo/` as
getopt parsed the options. However, this feature conflicts with the const
argv in cmd_tbl->cmd. This was originally added in 54841ab50c ("Make sure
that argv[] argument pointers are not modified."). The reason stated in
that commit is that hush requires argv to stay unmodified. Has this
situation changed? Barebox also uses hush, and does not have this problem.
Perhaps we could use their fix?
I have assigned maintenance of getopt to Simon Glass, as it is currently
only used by the log command. I would also be fine maintaining it.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
This function will be used from several places in UEFI subsystem
to generate some specific form of utf-16 variable name.
For example, L"Capsule0001"
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Move function to separate module.
Use char * as argument instead of u16 *.
If this option, CONFIG_EFI_SETUP_EARLY, is enabled, the initialisation
of UEFI subsystem will be done as part of U-Boot initialisation.
Please note that this option won't be enabled explicitly by users,
instead, should be enabled implicitly by other configuration options.
Specifically, this feature will be utilised in implementing capsule-on-disk
feature.
If ChildHandle indicates the sole child of the driver, disconnect the
driver.
This fixes the test results for UEFI SCT 2.6 A
sub-tests 5.1.3.12.43, 5.1.3.12.44, 5.1.3.12.45.
Add support for multiple images, since these are used on x86 now. Select
the first image for now, since that is generally the correct one. At some
point we can add a way to determine which image is currently running.
Provide a function to read the ROM offset so that we can store the value
in one place and clients don't need to store it themselves after calling
binman_set_rom_offset().
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.01-v2
common:
- Add support for 64bit loadables from SPL
xilinx:
- Update documentation and record ownership
- Enable eeprom board detection based legacy and fru formats
- Add support for FRU format
microblaze:
- Optimize low level ASM code
- Enable SPI/I2C
- Enable distro boot
zynq:
- Add support for Zturn V5
zynqmp:
- Improve silicon detection code
- Enable several kconfig options
- Align DT with the latest state
- Enabling security commands
- Enable and support FPGA loading from SPL
- Optimize xilinx_pm_request() calling
versal:
- Some DTs/Kconfig/defconfig alignments
- Add binding header for clock and power
zynq-sdhci:
- Add support for tap delay programming
zynq-spi/zynq-qspi:
- Use clock framework for getting clocks
xilinx-spi:
- Fix some code issues (unused variables)
serial:
- Check return value from clock functions in pl01x
Adjust the SetTime() and GetTime() runtime services to correctly convert
the daylight saving time information when communicating with the RTC.
U-Boot Driver Model is supposed to remove devices with either
DM_REMOVE_ACTIVE_DMA or DM_REMOVE_OS_PREPARE flags set, before exiting.
Our bootm command does that by explicitly calling calling
"dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL);" and we also disable any
USB devices.
The EFI equivalent is doing none of those at the moment. As a result
probing an fTPM driver now renders it unusable in Linux. During our
(*probe) callback we open a session with OP-TEE, which is supposed to
close with our (*remove) callback. Since the (*remove) is never called,
once we boot into Linux and try to probe the device again we are getting
a busy error response. Moreover all uclass (*preremove) functions won't
run.
So let's fix this by mimicking what bootm does and disconnect devices
when efi_exit_boot_services() is called.
Order header files according to https://www.denx.de/wiki/U-Boot/CodingStyle
An UEFI application may change the value of the register that gd lives in.
But some of our functions like get_ticks() access this register. So we
have to set the gd register to the U-Boot value when entering a trace
point and set it back to the application value when exiting the trace
point.
Change parameter type to avoid compilation error:
In file included from ./tools/../lib/rsa/rsa-verify.c:23:0,
from tools/lib/rsa/rsa-verify.c:1:
include/u-boot/rsa-mod-exp.h:69:18: error: unknown type name ‘u32’; did you mean ‘__u32’?
int zynq_pow_mod(u32 *keyptr, u32 *inout);
__u32
include/u-boot/rsa-mod-exp.h:69:31: error: unknown type name ‘u32’; did you mean ‘__u32’?
__u32
Fixes: 37e3a36a5475 ("xilinx: zynq: Add support to secure images")
In the International System of Units (SI) the prefix kilo is abbreviated as
'k' not 'K'. 'K' is the symbol for Kelvin.
The sandbox is built with the SDL2 library with invokes the X11 library
which in turn calls getc(). But getc() in glibc is defined as
int getc(FILE *)
This does not match our definition.
int getc(void)
The sandbox crashes when called with parameter -l.
Rename our library symbol getc() to getchar().
With DM enabled the ethernet code will receive a packet, call
the push method that's set by the EFI network implementation
and then free the packet. Unfortunately the push methods only
sets a flag that the packet needs to be handled, but the code
that provides the packet to an EFI application runs after the
packet has already been freed.
To rectify this issue, adjust the push method to accept the packet
and store it in a temporary buffer. The EFI application then gets
the data copied from that buffer. This way the packet is cached
until is is needed.
The DM Ethernet stack tries to receive 32 packets at once, thus
we better allocate as many buffers as the stack.
Signed-off-by: Patrick Wildt <patrick@blueri.se>
get_ticks does not always succeed. Sometimes it can be called before the
timer has been initialized. If it does, it returns a negative errno.
This causes the timer to appear non-monotonic, because the value will
become much smaller after the timer is initialized.
No users of get_ticks which I checked handle errors of this kind. Further,
functions like tick_to_time mangle the result of get_ticks, making it very
unlikely that one could check for an error without suggesting a patch such
as this one.
This patch panics if we ever get an error. There are two cases in which
this can occur. The first is if we couldn't find/probe the timer for some
reason. One reason for this is if the timer is not available so early. This
likely indicates misconfiguration. Another reason is that the timer has an
invalid/missing device tree binding. In this case, panicing is also
correct. The second case covers errors calling get_count. This can only
occur if the timer is missing a get_count function (or on RISC-V, but that
should be fixed soon).
Fixes: c8a7ba9e6a5
Remove initialization of ret with unused value.
Commit fdf0819afb (rsa: fix alignment issue when getting public
exponent) changed the logic to avoid doing an 8-byte access to a
possibly-not-8-byte-aligned address.
However, using rsa_convert_big_endian is wrong: That function converts
an array of big-endian (32-bit) words with the most significant word
first (aka a BE byte array) to an array of cpu-endian words with the
least significant word first. While the exponent is indeed _stored_ as
a big-endian 64-bit word (two BE words with MSW first), we want to
extract it as a cpu-endian 64 bit word. On a little-endian host,
swapping the words and byte-swapping each 32-bit word works, because
that's the same as byte-swapping the whole 64 bit word. But on a
big-endian host, the fdt32_to_cpu are no-ops, but
rsa_convert_big_endian() still does the word-swapping, breaking
verified boot.
To fix that, while still ensuring we don't do unaligned accesses, add
a little helper that first memcpy's the bytes to a local fdt64_t, then
applies fdt64_to_cpu(). [The name is chosen based on the
[bl]eXX_to_cpup in linux/byteorder/generic.h].
Fixes: fdf0819afb ("rsa: fix alignment issue when getting public exponent")
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
The algo name should match between the FIT's signature node and the
U-Boot's control FDT.
If we do not check it, U-Boot's control FDT can expect sha512 hash but
nothing will prevent to accept image with sha1 hash if the signature is correct.
Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
Binaries may be encrypted in a FIT image with AES. This
algo needs a key and an IV (Initialization Vector). The
IV is provided in a file (pointer by iv-name-hint in the
ITS file) when building the ITB file.
This commits adds provide an alternative way to manage
the IV. If the property iv-name-hint is not provided in
the ITS file, the tool mkimage will generate an random
IV and store it in the FIT image.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
We assign first_deleted = 0. There is no need to check its value without
any further assignment in between.
It is sometimes useful to output hex dumps in SPL. Add a config option to
allow this.
bloblist enhancement for alignment
Update ofnode/dev_read phandle function
sandbox keyboard enhancements and fixes
The result of fdt_node_offset_by_phandle is negative for error,
so this patch corrects the check of this result in
fdtdec_parse_phandle_with_args.
This patch allows to have the same behavior with or without OF_LIVE
for the function dev_read_phandle_with_args with cell_name = NULL and
with invalid phandle.
CONFIG_EFI_GRUB_ARM32 is only needed for architectures with caches that are
not managed via CP15 (or for some outdated buggy versions of GRUB). It
makes more sense to disable the setting per architecture than per defconfig.
Move QEMU's CONFIG_EFI_GRUB_ARM32_WORKAROUND=n from defconfig to Kconfig.
There is an extra space.
When we do not execute a test requiring ExitBootServices do not reset the
system after testing.
Print the CRC32 loaded via the EFI_LOAD_FILE2_PROTOCOL as a hexadecimal
number.
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Add code to use %x in efi_st_print().
strsep() changes the address that its first argument points to.
We cannot use the changed address as argument of free().
U-Boot offers a EFI_LOAD_FILE2_PROTOCOL which the Linux EFI stub can use to
load an initial RAM disk. Update the function comments of the
implementation.
Bring in the assorted changes that have been staged in the 'next' branch
prior to release.
