This function is generally useful and shouldn't hide away in hush. It
has been moved as is.
(cherry picked from commit 3cce8a5496452285e1828984ad3945417205cfc3)
Change-Id: I014f58e901e6b035b5eeb694c62e6e881a7b75c2
Reviewed-on: https://gerrit.chromium.org/gerrit/11791
Reviewed-by: Doug Anderson <dianders@chromium.org>
Commit-Ready: Simon Glass <sjg@chromium.org>
On X86 systems the hardware maps the bootprom SPI flash chip into the
top of memory address range. This could be used for accessing all
information in the SPI flash.
The vboot-reference code requires access to FMAP sections containing
cryptographic information, and as of today, u-boot reads the whole
sections, which are 64 KB in size, even though the actual areas
accessed by vboot-reference are much smaller.
A much faster way of accessing this information would be just passing
around pointers to the appropriate memory areas. This would eliminate
one copy, and also would make sure that only the areas actually
accessed get fetched from SPI flash.
This patch provides this ability trying to keep code changes to a
minimum.
New feature is enabled by defining CONFIG_HARDWARE_MAPPED_SPI. The
firmware storage API for file reads changes when the new configuration
option is set: a pointer to pointer to buffer is passed to the
read_spi() function instead of a pointer to buffer. When the new
feature is enabled the read_spi() function sets the pointer value to
point to the requested data instead of copying the data into the
buffer.
A new data type is introduced (read_buf_type), which is set to be a
(void *) if the new feature is not enabled, or (void **) otherwise.
This type is used as the buffer pointer in the spi_read() function.
Code allocating/freeing buffers used to keep data read from SPI flash
is now conditionally compiled.
Call sites for the spi_read() function are modified to adjust the
buffer pointer parameter (pass the address of the parameter instead of
the parameter, when the new feature is enabled).
gbb field access functions can be aliased to gbb_init(), as they all
in fact do the same - read a certain section of the gbb area.
This change does not benefit the ARM implementations, and makes the
code more complicated that it should be. Some u-boot rearchitecture
along with vboot_reference API enhancements could address this. A
tracking issue
(http://code.google.com/p/chromium-os/issues/detail?id=22528) has been
opened for that.
BUG=chrome-os-partner:6585, chromium-os:22528
TEST=manual
. build a new stumpy firmware image
. boot the stumpy, observe it start up chromeos.
. assess the boot timing using the cbmem.py utility (this
modification shaves in excess of 100ms off the boot time).
. disable the new feature, build a stumpy image, observe that is
still boots chromeOs.
. run emerge-terga2_kaen chromeos-u-boot to confirem that ARM
version builds cleanly.
Change-Id: I4e6ab530d24f5771b5a86a48d3f3135101b469a6
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/11152
All memory operations (except the "safe ones") live in the firmware
so the fast operations can be used. Except Memset. This CL changes that
problem.
There is another CL for this issue (removing the function from
vboot_reference)
BUG=chrome-os-partner:6313
TEST=run coreboot/u-boot on Stumpy
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Change-Id: Ic2ee5970d2ee9df64a9eda261a4348341cb4b31a
Reviewed-on: https://gerrit.chromium.org/gerrit/10992
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Reviewed-by: Bill Richardson <wfrichar@chromium.org>
Reviewed-by: Randall Spangler <rspangler@chromium.org>
But let coreboot pre-fill that field instead.
BUG=chrome-os-partner:6212
TEST=boot coreboot+u-boot on Lumpy, see EC firmware reported as RW in
crossystem.
Change-Id: Icc4ac474e19dc72b61040faafbe1a184738564d0
Reviewed-on: http://gerrit.chromium.org/gerrit/10266
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
This CL simplifies how cros gpios are handled by moving the required logic out
of cros_gpio.c and into the application logic. This means that cros_gpio.c
assumes that none of the gpios are required, and just returns an error when
fetch is called. It's up to the caller of fetch to determine whether or not they
should ignore the error or act upon it.
BUG=chromium-os:21700
TEST=Tested on asymptote, ensured gpio access worked as expected.
Change-Id: Ief3f1915026bfe981d345b9cc4709fef19edc7bf
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/10174
Add code to retrieve the location of the MRC cache from the FMAP
device tree definition.
fdt_decode.c should be refactored (fmap_offset could be determined
just once and used throughout without passing it as a parameter), will
leave this for another day.
BUG=chrome-os-partner:5808
TEST=manual
. see test description in the second patch commit message.
Change-Id: Ic4003d685609beb61d1dea324bd804a2838e471c
Reviewed-on: http://gerrit.chromium.org/gerrit/9961
Reviewed-by: Stefan Reinauer <reinauer@google.com>
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
The memory wipe infrastructure in u-boot makes some assumptions about how
memory is arranged that make it not quite fit with x86. Specifically, it
assumes that there is a single region of memory, and with certain exceptions
that's what should be wiped. In x86, specifically in the e820 map, there are
multiple regions of RAM, possibly multiple regions to exclued from that that
may completely, partially, or not overlap with the others, and then u-boot
related regions.
This is addressed by making the memory wipe infrastructure a little more
generic. Now, areas can be added and subtracted arbitrarily, and will
accumulate in the order they're encountered. In the x86 use case, we can add
the e820 regions marked as RAM, subtract the areas marked as anything else, and
subtract the u-boot related regions.
Rather than tracking the actual regions of the address space, this
implementation tracks the boundaries between the regions using a linked list.
The code itself is short and relatively simple, and I tried to ensure that it
was as clear as possible to make any memory (or other) bugs easier to see and
fix.
BUG=chrome-os-partner:6195
BUG=chrome-os-partner:6194
TEST=Built and booted on kaen using the A-A cable. Ran vboot_test memwipe, and
a modified version that took advantage of the new API.
Change-Id: I122fbf499ef473350afa27b612cb0e565366b1ad
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/9715
Verified boot requires writing to GPT attributes (success / tries), so we need
to implement *_write.
"scsi write" command is also added to console for testing.
BUG=chrome-os-partner:6258
TEST=(1) Modified GPT to trigger VBOOT updating GPT, and verified
GPT changed successfully (by firmware) after reboot
(2) ext2load usb 1:1 10000000 /part2.bin # load kernel partition dump
scsi write 10000000 5000 5000 # write into kernel partition in #2
Change-Id: I8027b6075cdabf8df81ea1ba620ca0dcd3d33232
Signed-off-by: Hung-Te Lin <hungte@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/8841
This reverts commit 8e93aec313c2807704b14fbd21123a9ffc86a087.
The bios-base setting has been deprecated.
BUG=None
TEST=Built and booted on Stumpy.
Change-Id: I792761ac44763b06bf1d3abb4db8e9e1a3f113c5
Reviewed-on: http://gerrit.chromium.org/gerrit/8823
This file needs to depend on both CONFIG_CHROMEOS and CONFIG_OF_CONTROL.
BUG=chromium-os:19353
TEST=build with CONFIG_OF_CONTROL, but without CONFIG_CHROMEOS;
see that it now succeeds
Change-Id: I94b2616b6bcb10619b00c5fe93adf2e36d459fb0
Reviewed-on: http://gerrit.chromium.org/gerrit/8682
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
Instead of using a hardcoded value, set this field of the table used by the
crossystem ACPI driver to whatever is stored in VDAT.
BUG=chrome-os-partner:5944
BUG=chrome-os-partner:5961
BUG=chrome-os-partner:5962
TEST=Booted on Alex. Verified that corrupting firmware A made crossystem change
mainfw_act to B instead of A.
Change-Id: I01b26508fede3d15e78b584b638e1393c5b03501
Reviewed-on: http://gerrit.chromium.org/gerrit/8189
Reviewed-by: Hung-Te Lin <hungte@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
Commit-Ready: Gabe Black <gabeblack@chromium.org>
Signed-off-by: Bill Richardson <wfrichar@google.com>
BUG=none
TEST=none
Change-Id: I636eee76069d9f6ae0679135b87f0006d59c2723
Reviewed-on: http://gerrit.chromium.org/gerrit/8242
Tested-by: Bill Richardson <wfrichar@chromium.org>
This change sets up basic vboot data for use by crossystem. The pieces of
information and what they're set to are below. I assumed that the constants
defined in the coreboot version of this code describe all of the available
settings for each option.
Boot reason: BOOT_REASON_OTHER
The choices here are BOOT_REASON_OTHER and BOOT_REASON_S3DIAG. I don't know
what BOOT_REASON_S3DIAG is for or how to detect which to use. I believe S3
resume happens without going through u-boot, so hardcoding this to
BOOT_REASON_OTHER seems reasonable for now at least.
Active main firmware: ACTIVE_MAINFW_RW_A
The choices are ACTIVE_MAINFW_RECOVERY, ACTIVE_MAINFW_RW_A and
ACTIVE_MAINFW_RW_B. This information isn't stored in the crossystem_data_t
structure. For now it's hard coded to ACTIVE_MAINFW_RW_A which is going to
frequently be wrong. I suspect we also need to add a value which indicates that
the read only firmware was used by itself.
Active EC firmware: cdata->active_ec_firmware
A direct match with data already gathered by u-boot/vboot.
CHSW: Translation from booleans to bitfields.
The cdata boot_write_protect_switch, boot_recovery_switch, and
boot_developer_switch boolean fields are translated into the
CHSW_FIRMWARE_WP_DIS, CHSW_RECOVERY_X86 and CHSW_DEVELOPER_SWITCH bitfields.
The CHSW_RECOVER_EC bitfield is ignored since there's no obviously
corresponding field in crossystem_data_t.
HWID: cdata->hardware_id
FWID: cdata->firmware_id
FRID: cdata->readonly_firmware_id
Active main firmware type: cdata->firmware_type
Recovery reason: RECOVERY_REASON_NONE
The choices are RECOVERY_REASON_NONE and RECOVERY_REASON_ME. Since u-boot has
no information about the ME, this is hardcoded to RECOVERY_REASON_NONE.
FMAP base address: cdata->fmap_offset
An assumed direct match with data already gathered by u-boot/vboot. There is a
little ambiguity as far as what this is the offset of and from.
TEST=Booted successfully on both stumpy and alex. Used crossystem to verify
that information like the firmware ID was extracted successfully. The GPIOs,
which are not sent with this mechanism, seem to work sometimes but not always.
Change-Id: If7ea2a6470d8edf7122f87f289c19d4464775e8c
Reviewed-on: http://gerrit.chromium.org/gerrit/7977
This moves the last remaining hard-coded CONFIG to the fdt.
BUG=chromium-os:17062
TEST=build for Seaboard
Change-Id: Ic152ce12a0f87211e4cc98eef15601f0703137b1
Reviewed-on: http://gerrit.chromium.org/gerrit/7642
Reviewed-by: Anton Staaf <robotboy@chromium.org>
This just changes to standard 'blob' naming, and fixes a code style error.
TEST=build and boot on Seaboard
Change-Id: Ib79d526ef612a181091ef15a5dd427ea73c53330
Reviewed-on: http://gerrit.chromium.org/gerrit/7681
This setting specifies where the bios image described by the "flash" section
starts in the ROM. When the device tree is consumed by u-boot, this value is
added to the given offset of accesses to the flash so that it ends up in the
right place in the ROM. The binary fmap will reflect that address directly so
that tools like flashrom can use it without modification. By not modifying the
locations of the sections in the "flash" node of the device tree directly, we
can continue to share definitions between boards that have the same layout for
the BIOS image itself but who may be offset differently in the ROM. If not
present, a default value of 0 is used. Unmodified device trees will continue
to behave like they always have.
The name bios-base isn't perfect since on ARM there is no bios. Another
alternative firmware-base is also flawed because there are multiple firmwares
in the ROM on x86. Yet another option, flashmap-base, doesn't quite work either
because flashmap already has a very similarly named field which describes where
the image described by the flashmap appears in the physical address space.
Because bios-base fits the best on x86 and x86 is currently the only place it's
used, that's the name I went with.
BUG=chrome-os-partner:5844
TEST=Used this and other changes to compensate for the image offset and vboot
on stumpy. Vbooted on x86-alex. Built with vboot_test and vbexport_test built
in to verify that they still compile.
Change-Id: Ie727fc2db27f7d0db8ebf7ed2b98bc97052b4923
Reviewed-on: http://gerrit.chromium.org/gerrit/7239
Copy device_ide.c into device_scsi.c, editing as appropriate
along the way. Ensure that the new file is included if
CONFIG_AHCI_SCSI is defined fro the platform.
BUG=chromium-os:19837
TEST=manual
. program updated image (including AHCI fixes and configuration
changes) on an Alex.
. restart the machine and enter `vboot_twostop' at u-boot prompt.
Observe it boot up all the way to ChromeOs login screen.
Change-Id: I146591c53f61722cc33f7261a1921aa07e861ee3
Reviewed-on: http://gerrit.chromium.org/gerrit/7234
It was noticed that the system fails to come up while running the
latest u-boot from the 2011.06 branch. Further investigation has
discovered that the problem is due to the fact that the
initialization of the verified boot wrapper was not handled
properly and that the IDE index reported by the IDE discovery
routine was wrong.
BUG=chromium-os:19599
TEST=manual
. build and install the new firmware image on an Alex with a
valid ChromeOS image
. enter vboot_two at u-boot prompt
observe the machine to bring up the ChromeOs login screen.
Change-Id: Icc78d682d5c81d6f08d31896c32c8cd48d0a4f2d
Reviewed-on: http://gerrit.chromium.org/gerrit/7030
Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
Now that we have MMC, USB and IDE, with some enabled for only some platforms,
the code has become ugly. This refactors the code to separate out each device
into its own file, with a generic start/scan interface.
This also fixes the problem with indexing of devices, where it could not cope
with MMC and IDE active at the same time.
BUG=chromium-os:19518
TEST=build on Seaboard; vbexport_test diskinfo
See that all boot devices are found with SD and USB inserted
Change-Id: I4844f7b33885ec01e922686a17c90afdf0a55a9d
Reviewed-on: http://gerrit.chromium.org/gerrit/6254
Reviewed-on: http://gerrit.chromium.org/gerrit/6918
boot_kernel sets up pointer to crossystem data for embedding into kernel
device tree unconditionally regarding CONFIG_OF_UPDATE_FDT_BEFORE_BOOT.
This patch guards boot_kernel codes that are specific to kernel device
tree with the config flag.
Note: x86 boards might use a mechanism other than device tree to deliver
crossystem data to kernel.
BUG=none
TEST=emerge-{tegra2_aebl,x86-alex} chromeos-u-boot
Change-Id: Ifd04af1681d72c918c838ba3713ddecaca0ff18a
Reviewed-on: http://gerrit.chromium.org/gerrit/6466
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
We need to register available boot devices. It seems reasonable that this
library should be initialized before use.
Change-Id: I17a535dc85b5aaee669ea67b439632bafb19c806
Reviewed-on: http://gerrit.chromium.org/gerrit/6501
BUG=chrome-os-partner:4552
TEST=vboot_twostop does not fail with an error after loading the kernel.
Change-Id: I16016239716c8030ea63c7da6bd99a2f03b0e40d
Reviewed-on: http://gerrit.chromium.org/gerrit/5549
Tested-by: Stefan Reinauer <reinauer@google.com>
From http://gerrit.chromium.org/gerrit/#change,6253
BUG=none
TEST=none
Change-Id: I3145aa84a8426506d8dc44d094da4884f079b3b4
Reviewed-on: http://gerrit.chromium.org/gerrit/6355
This is a rewrite of http://gerrit.chromium.org/gerrit/#change,5547
which tries to integrate more transparently into vbexport's code
and at the same time removes some (false) assumptions about always
booting from MMC.
BUG=none
TEST=none
Change-Id: I18f3b91f307b16622de9ced97ab00454c29941fe
Reviewed-on: http://gerrit.chromium.org/gerrit/6232
Change-Id: Iba1da73cdd5a8e3972240e939a40ee4a32e83786
Reviewed-on: http://gerrit.chromium.org/gerrit/6252
The vboot_api.h interface has changed, so we need to adapt. VbExDecompress()
now allows the vboot library access to native decompression routines. The
signature of VbExDisplayImage() has changed, so we now only need to support
uncompressed native-format bitmaps.
BUG=chromium-os:19134
TEST=manual
I tested by modifying the U-Boot build so I could get into the U-Boot prompt
and run "vbexport_test display". The GBB screens rendered correctly.
Change-Id: Iec605dee0af46e7d9eecc89b826e260f8a5930a4
Reviewed-on: http://gerrit.chromium.org/gerrit/6131
Change-Id: I1e1cc76214cdb45399cec090677d3164ca2d33eb
Reviewed-on: http://gerrit.chromium.org/gerrit/6065
Reviewed-by: Mike Frysinger <vapier@chromium.org>
The removed codes are belong to an earlier prototype of integrating
vboot wrapper API, which is not compiled/used anymore. Besieds, the
prototype has a known vulnerability of buffer overflow when reading
key blocks. So there is no many referential value for keeping the
prototype codes in the codebase. And keeping the prototype also adds
costs to new patches, which have to changes two implementations. All
in all, I think it is time we retire this prototype.
This patch also fixes coreboot build failure due to the removal.
BUG=chromium-os:16542
TEST=emerge-{x86-alex,tegra2_aebl} chromeos-u-boot
Change-Id: Ib6be9457f2dbc2daa3213c3d9c80bcdc56c520c4
Reviewed-on: http://gerrit.chromium.org/gerrit/5874
The timer_get_us function which is called by the existing implementation of
VbExGetTimer isn't trivial to implement on x86. The vboot source says that the
TSC is an appropriate time source to return from this function. This change
makes the VbExGetTimer function per board so that it can use rdtsc instead of
timer_get_us.
TEST=Built and booted on x86-alex, and built on tegra2_kaen.
Change-Id: I335d5ae98949cd05c42dc3f30c52931bdf63a623
Reviewed-on: http://gerrit.chromium.org/gerrit/5544
Reviewed-by: Gabe Black <gabeblack@chromium.org>
This code is used on x86 platforms to control a standard LPC
based TPM device. The actual driver implementation is based on
the article "Writing a TPM Device Driver" published on
http://ptgmedia.pearsoncmg.com and the submission by Stefan
Berger on Qemu-devel mailing list.
One substantial difference is that in the simplest configuration
(the case of the Alex device under coreboot/u-boot control) the
other than 0 TPM localities do not get mapped by some devices
(for instance, by Infineon slb9635), so this driver provides
access to locality 0 only.
BUG=chrome-os-partner:4547
TEST=manual
Booted an Alex with this code, tried accessing TPM. Access
routines do not fail, even though it is not yet possible to write
data into a TPM location and read it back. This could be related
to the fact that the CLI command does not intialize the TPM
properly.
boot > tpm
generic_lpc_tpm.c:155 found TPM SLB9635 TT 1.2 by Infineon
boot > tpm r 0x1008 10
boot > tpm w 0x1008 1 2 3 4
boot > tpm r 0x1008 4
Change-Id: Id8d23e9bb24ba2bcd999135c99e7612f9010f384
Reviewed-on: http://gerrit.chromium.org/gerrit/5492
Tested-by: Vadim Bendebury <vbendeb@chromium.org>
* video_clear()
Clear the video framebuffer.
* cold_reboot()
Do a hard reset through the chipset's reset control register. This
register is available on all x86 systems (at least those built in
the last 10ys)
* power_off()
Power down the machine by using the power management sleep control
of the chipset. This will currently only work on Intel chipsets.
However, adapting it to new chipsets is fairly simple. You will
have to find the IO address of the power management register block
in your southbridge, and look up the appropriate SLP_TYP_S5 value
from your southbridge's data sheet.
BUG=chrome-os-partner:3912
TEST=Run vboot_twostage and see vboot first clear the screen and later cold boot.
Run poweroff and coldboot command in uboot console.
Change-Id: I59f49a41e8807b2ec3ebb3d083d2a06ced9553a0
Reviewed-on: http://gerrit.chromium.org/gerrit/5361
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
The x86 u-boot does not enable the CONFIG_OF_CONTROL flag yet,
and as such should not compile in the FDT related functions. This
change takes care of this arrangement and also removes the
remaining common code using fdt unconditionally.
BUG=chrome-os-partner:4993
TEST=manual
. build u-boot for Kaen, verify that the system still comes up
as expected.
. build coreboot image for Alex, verify that the system still
can be started manually.
Change-Id: I5416f9fd0a6cc9f86aef9051b1f7b6d9b252964e
Reviewed-on: http://gerrit.chromium.org/gerrit/5362
This change makes the FMAP configuration decoding function board specific so
that it can, for instance, use CBFS to store the FMAP on x86. The ARM
implementation uses fdt_decode_twostop_fmap in its implementation and should
behave the same. The new more generic interace is called decode_twostop_fmap.
BUG=chrome-os-partner:5248
TEST=Built, installed and booted on Kaen, built and installed on Alex, ran
vboot_twostop and saw new "unimplemented" message.
Change-Id: I07f6f8f7c8a62c5998ec4919d4609a7ac84783da
Reviewed-on: http://gerrit.chromium.org/gerrit/5233
This change removes the device tree from one of the vboot support APIs so
that they fit better with coreboot u-boot. Specifically this is
cros_gpio_fetch which is for getting GPIO values. Coreboot will read these and
provide the values through its coreboot tables. The device tree pointer is
global data so it doesn't need to be passed around as a parameter to be
accessible.
This change also removes the device tree from other interfaces in
cmd_vboot_twostop.c so the structure of the code is more consistent. This way
people can expect the device tree to always be the one pointed at by the
global data and not sometimes one and sometimes the other, even though as
written those will be equivalent. This change also takes the opportunity to
mark the local functions in that file static, which is most of them.
TEST=Built for x86-alex and tegra2_kaen. Installed and booted to chromeos
login on Kaen.
Change-Id: I084e774d97025d9ec71abe09c92fab8a7827892f
Reviewed-on: http://gerrit.chromium.org/gerrit/5232
This change separates out the FMAP data structures from the FDT decode
functions and renames them to more neutral names. These structures don't
intrinsically have to be loaded from the FDT, and their new names and location
remove the implied dependency.
TEST=Built for x86-alex and tegra2_kaen. Installed on Kaen and booted to
chromeos login.
Change-Id: I5680a3f3aaa52efe44c2060d0b6db9ad47a547ec
Reviewed-on: http://gerrit.chromium.org/gerrit/5231
This patch only moves code around.
TEST=build okay
Change-Id: Idc908fd2e652c114ae8029c120386fb44e63b4f9
Reviewed-on: http://gerrit.chromium.org/gerrit/5204
The U-Boot printf() implementation has an output buffer limitation on
output, and so cannot be used for very long output. Instead, puts() has
no such limitation.
BUG=chromium-os:18351
TEST=run on Aebl
Change-Id: I3f3e3b81968f5169a2fe1f581924fa19c3dc1a43
Reviewed-on: http://gerrit.chromium.org/gerrit/4990
It was observed that the sleep recovery fails when Kaen is in dev
mode. Further investigation has shown that the LP0 vector space
is set to all zeros when the system is in dev mode, which clearly
prevents it from resuming operations properly. Then it turned out
that the recently introduced memory u-boot wipeout fails to
exclude the LP0 vector space, so it gets erased.
For some reason u-boot does this in two different places in the
code, so the fix adds exclusion of the LP0 vector space in those
spaces.
BUG=chrome-os-partner:5152
TEST=manual
Build a new u-boot image, install it on a kaen. Then bring up the
kaen in normal and developer mode, login, close the lid and open
it back a few times.
Before the fix the machine would hang every single attempt at
closing the lid when in dev mode, after the fix it enters and
exits sleep state seamlessly in both dev and normal modes.
Change-Id: I9ec31495bca41abed68de8559560f0b1fcdd4969
Reviewed-on: http://gerrit.chromium.org/gerrit/5193
Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
Although we should not pass any command-line that causes update_cmdline
to buffer overflow, it is good to check and avoid this.
BUG=chromium-os:18139
TEST=unit tests on user space
Change-Id: Ifc481068c30aa5c141d6e3d36f3affd5e3d95ffb
Reviewed-on: http://gerrit.chromium.org/gerrit/4914
BUG=none
TEST=none
Change-Id: I3b83f2df71df0227aa71dba8300e641944eb4c8b
Reviewed-on: http://gerrit.chromium.org/gerrit/4909
Reviewed-by: Micah Catlin <micahc@chromium.org>
This change fills up the stubs in lib/vbexport/display.c to
provide support on both ARM (where LCD driver is used) and
X86 (where the CFB driver is used) platforms.
TEST=manual
On X86 (alex with a Dediprog programmer connected to it), run the
following commands:
. emerge-x86-alex vboot_reference-firmware chromeos-u-boot chromeos-coreboot
dd if=/build/x86-alex/coreboot/coreboot.rom of=/tmp/coreboot seek=3584 bs=1K
sudo flashrom -p dediprog -w /tmp/coreboot
. Reboot the machine, observe it come up to boot> prompt, start
ChromeOS (using the `boot' cli command).
On ARM (tegra2_kaen)
. emerge-tegra2_kaen vboot_reference-firmware chromeos-u-boot chromeos-bootimage
. program the resulting image into Kaen, restart it, observe the
machine come up.
. install the new OS image on the machine, restart it, observe
the machine come up.
. request recovery reboot using crossystem, restart the machine,
observe it come up in recovery request mode.
This test case actually failed: the system did show the
recovery request screen, but then proceeded to boot from the
plugged in USB stick (it was supposed to wait for the stick to
be removed/reinserted)
Change-Id: I75310de3f93464645cc9e61237f65d7d19b71873
Reviewed-on: http://gerrit.chromium.org/gerrit/4886
BUG=none
TEST=emerge-{ARM board, x86 board} chromeos-u-boot
Change-Id: Ib6c267d6624cebf2b83cb1996ae8135b9cb0e436
Reviewed-on: http://gerrit.chromium.org/gerrit/4911
These were incompletely renamed to CHROMEOS_KERNEL_* this change cleans up the
remaining use of the old name and gets rid of the old option from the coreboot
configuration.
TEST=Built for coreboot, aebl, and kaen.
Change-Id: I267932ab1d2f4a148357e7c95f15a104422ba687
Reviewed-on: http://gerrit.chromium.org/gerrit/4889
main_entry.c uses the TPM_SUCCESS constant but wasn't including the file that
defines it. This was breaking the build for u-boot/coreboot.
TEST=Built for coreboot.
Change-Id: I684c4272fcc67403eaf70e2b063dbe3db2b6eb88
Reviewed-on: http://gerrit.chromium.org/gerrit/4848
The wipe_unused_memory function in bootstub_entry.c in the vboot library which
depends on being able to call fdt_decode_memory which only compiled in with
CONFIG_OF_CONTROL. That setting breaks booting u-boot with coreboot right now.
This change conditionally compiles in the existing implementation if the
right support is available and compiles in a warning message if it isn't.
TEST=Built on x86.
Change-Id: I6404eb12b25c19eb21eb65ad16a5031a5e3d0ad7
Reviewed-on: http://gerrit.chromium.org/gerrit/4843
There are a few functions in display.c in the vbexport library which depend
on being able to call functions provided by the LCD driver. If that support
isn't turned on then compilation will fail. It can't always be turned on
because it's not always the right driver to use.
right support is available and compiles in a warning message and a failing
return code if it isn't.
TEST=Built on x86.
Change-Id: I70695f06bb1b55063d035307e0420f8fc58b1efa
Reviewed-on: http://gerrit.chromium.org/gerrit/4768
This patch is cherry-picked from commit 1d01c6b. You may gain 142ms in
boot time.
TEST=boot normal/developer/recovery on Aebl
Change-Id: I983e2dec32205dd586a2d7f267409eaafefb267f
Reviewed-on: http://gerrit.chromium.org/gerrit/4806
The headers are merged and split into the board-independent header
chromeos.h and a board-dependent header, e.g., chromeos_tegra2_twostop.h.
The board-independent header defines/enables all features that a
verified boot firmware must have, and is included by a board-dependent
header.
Moreover, the CONFIG_CHROMEOS_* flags are reduced into a single flag
CONFIG_CHROMEOS.
BUG=none
TEST=make chromeos_tegra2_twostop_config && make
Change-Id: I2ec9092ed898c640175095e86cfcb100efbefb3a
Reviewed-on: http://gerrit.chromium.org/gerrit/4731
Some scripts, like those in factory process, detect whether Chrome OS is
booted from a verified boot or a legacy boot by overloading crossystem.
If crossystem returns a valid hardware id, the scripts believe that
Chrome OS is booted from a verified boot.
Although this trick works, it does not sound right. This patch adds
"cros_vboot" and "cros_legacy" to kernel command line of verified boot
firmware and legacy firmware so that the scripts can grep the value, or
the crossystem may do the grep.
This patch also fixes unsafe use of strncpy.
BUG=chromium-os:15700,chromium-os:18139
TEST=verified boot and grep cros_vboot /proc/cmdline
TEST=boot from legacy and grep cros_legacy /proc/cmdline
Change-Id: Id5182c2f4e05fc566a17b1e50f9157f96c50f866
Reviewed-on: http://gerrit.chromium.org/gerrit/4645
This patch also eliminates duplications of decoding fmap from the
device tree.
TEST=make chromeos_seaboard_vboot_config && make
Change-Id: I0af75335be10823b8644c94f6fc9aac0304a2633
Reviewed-on: http://gerrit.chromium.org/gerrit/4745
