CAAM do not work in imx8.
disable FASTBOOT_ENCRYPT_LOCK for lock&unlock and return 0
for fsl avb call back on imx8 device.
Change-Id: I79e2de2571a922ae22c2a52f0beb661762e11dd5
Signed-off-by: zhang sanshan <sanshan.zhang@nxp.com>
The lib provided ql-tipc communication channel with
Trusty OS.
Also the AVB, Keymaster and SecureStorage service
tipc client implement in this lib.
Change-Id: I0ab1ec9ee1b6f272b960c2e944008283c2c9249a
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Remove the underscore prefix of current slot.
Change-Id: I07a0513dfcfbf395087d57e3680c8d662ec827aa
Signed-off-by: ji.luo <ji.luo@nxp.com>
Change-Id: I6ab29f86df748d173954400d534f1fb3c990f5b9
This patch did:
1.Hard code the permanent attribute into u-boot.
2.Store first 112 bits of sha256(permanent attribute) hash into fuse.
(CONFIG_AVB_FUSE was removed because it's an irreversible operation)
3.Implement platform-specific operations defined in avb_atx_ops.h.
Change-Id: I65de9860e7c5ca1f7ebfbd87300faee0ccacaac3
Use hard code public key instead of reading it from RPMB.
Read RPMB key from last block of BOOT1 instead of fuse.
Change-Id: Icddd0bc45af8f9a9b222d54e16a7dfc6efa6c8b2
Change-Id: I052314f2304a93a79fa912125c555cae173d8749
RPMB keyblob stored in the last block of boot1
partition of MMC1. It will be load into
CAAM SEC_RAM and format into "keyslot" package.
This is enabled on pico7d and iopb6ul.
Change-Id: I5d9ab12e7d14945ebd8f926e20bed19b02e65009
Change-Id: I6a187dfa40b3d7a1dcc92c0d774956ac30679225
support below commands:
fastboot getvar has-slot:oem gapps vbmeta.
Change-Id: I2b7ed6efa4675cf5cfa64e5982cb3987bee6f28a
* add board support for android and android things.
mx6ul_nxpu_iopb, pico-6ul, pico-imx7d, aquila-6ul
reorganize the Kconfig, and fix the redefine issue.
* add android configure into configure-while
* add a common file mx_android_common.h
it will be included by android and android things.
defconfig only include ANDROID_THINGS_SUPPORT or ANDROID_SUPPORT
* move partition_table_valid into f_fastboot.c.
it's a common code.
* add invalidate_dcache_range in fixed order.
It will have salt invalid issue if we do not add it in order
* add display for pico-7d.
Change-Id: I6f8a4876c2f8bbd098034d1e3f53033109300bca
Fix issue for API changed from v2017.
porting below patch from v2016.
commit 44834fd12f60a090e3d10ab6f84a75460894d49d
Change-Id: Ifaf0b86dd29648f9150646f00f54502676df9013
We should use unsigned long rather than u32 for addresses. Update this so
that the table-generation code builds correctly on 64-bit machines.
This patch adds a function to the TPM library, which allows U-Boot to
flush resources, e.g. keys, from the TPM.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Add support for signing with the pkcs11 engine. This allows FIT images
to be signed with keys securely stored on a smartcard, hardware security
module, etc without exposing the keys.
Support for other engines can be added in the future by modifying
rsa_engine_get_pub_key() and rsa_engine_get_priv_key() to construct
correct key_id strings.
Signed-off-by: George McCollister <george.mccollister@gmail.com>
Ensure '.' is used to separate octets. If another character is seen
reject the string outright and return 0.0.0.0.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Previously values greater than 255 were implicitly truncated. Add some
stricter checking to reject addresses with components >255.
With the input "1234192.168.1.1" the old behaviour would truncate the
address to 192.168.1.1. New behaviour rejects the string outright and
returns 0.0.0.0, which for the purposes of IP addresses can be
considered an error.
Currently, mdelay() and udelay() are declared in include/common.h,
while ndelay() in include/linux/compat.h. It would be nice to
collect them into include/linux/delay.h like Linux.
While we are here, fix the ndelay() implementation; I used the
DIV_ROUND_UP() instead of (x)/1000 because it must wait *longer*
than the given period of time.
without symbols
The fdt_overlay_apply() function purports to support the edge cases where
an overlay has no fixups to be applied, or a base tree which has no
symbols (the latter can only work if the former is also true). However it
gets it wrong in a couple of small ways:
* In the no fixups case, it doesn't fail immediately, but will attempt
fdt_for_each_property_offset() giving -FDT_ERR_NOTFOUND as the node
offset, which will fail. Instead it should succeed immediately, since
there's nothing to do.
* In the case of no symbols, it again doesn't fail immediately. However
if there is an actual fixup it will fail with an unexpected error,
because -FDT_ERR_NOTFOUND is passed to fdt_getprop() when attempting to
look up the symbols. We should instead return -FDT_ERR_NOTFOUND
directly.
Both of these errors lead to the code returning misleading error codes in
failing cases.
[ DTC commit: 7d8ef6e1db9794f72805a0855f4f7f12fadd03d3 ]
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
tiny-printf does not know about the "-" modifier, which aligns numbers.
This is used by some SPL code, but as it's purely cosmetical, we just
ignore this modifier here to avoid changing correct printf strings.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
tiny-printf does not know about the "l" modifier so far, which breaks
the crash dump on AArch64, because it uses %lx to print the registers.
Add an easy way of handling longs correctly.
Using a relatively decent compiler (GCC 5.3.0) this does _not_ increase
the code size of tiny-printf.o for 32-bit builds (where long and int
are actually the same), actually it looses three (ARM Thumb2) instructions
from the actual SPL (numbers for orangepi_plus_defconfig):
758 0 0 758 2f6 spl/lib/tiny-printf.o before
18839 488 232 19559 4c67 spl/u-boot-spl before
758 0 0 758 2f6 spl/lib/tiny-printf.o after
18833 488 232 19553 4c61 spl/u-boot-spl after
This adds some substantial amount of code to a 64-bit build, though:
(taken after a later commit, which enables the ARM64 SPL build for sunxi)
1542 0 0 1542 606 spl/lib/tiny-printf.o before
25830 392 360 26582 67d6 spl/u-boot-spl before
1758 0 0 1758 6de spl/lib/tiny-printf.o after
26040 392 360 26792 68a8 spl/u-boot-spl after
Add two functions for use by board implementations to decode the memory
banks of the /memory node so as to populate the global data with
ram_size and board info for memory banks.
The fdtdec_setup_memory_size() function decodes the first memory bank
and sets up the gd->ram_size with the size of the memory bank. This
function should be called from the boards dram_init().
The fdtdec_setup_memory_banksize() function decode the memory banks
(up to the CONFIG_NR_DRAM_BANKS) and populates the base address and size
into the gd->bd->bi_dram array of banks. This function should be called
from the boards dram_init_banksize().
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Today we can compile a self-contained hello world efi test binary that
allows us to quickly verify whether the EFI loader framwork works.
We can use that binary outside of the self-contained test case though,
by providing it to a to-be-tested system via tftp.
This patch separates compilation of the helloworld.efi file from
including it in the u-boot binary for "bootefi hello". It also modifies
the efi_loader test case to enable travis to pick up the compiled file.
Because we're now no longer bloating the resulting u-boot binary, we
can enable compilation always, giving us good travis test coverage.
Remove the need to explicitly add SHA/RSA pairings. Invalid SHA/RSA
pairings will still fail on verify operations when the hash length is
longer than the key length.
Follow the same naming scheme "checksum,crytpo" without explicitly
defining the string.
Indirectly adds support for "sha1,rsa4096" signing/verification.
Signed-off-by: Andrew Duda <aduda@meraki.com>
Signed-off-by: aduda <aduda@meraki.com>
Cut down on the repetition of algorithm information by defining separate
checksum and crypto structs. image_sig_algos are now simply pairs of
unique checksum and crypto algos.
Padding verification was done against static SHA/RSA pair arrays which
take up a lot of static memory, are mostly 0xff, and cannot be reused
for additional SHA/RSA pairings. The padding can be easily computed
according to PKCS#1v2.1 as:
EM = 0x00 || 0x01 || PS || 0x00 || T
where PS is (emLen - tLen - 3) octets of 0xff and T is DER encoding
of the hash.
Store DER prefix in checksum_algo and create rsa_verify_padding
function to handle verification of a message for any SHA/RSA pairing.
checksum_algo's pad_len field isn't actually used to store the length of
the padding but the total length of the RSA key (msg_len + pad_len)
On ls2080 we have a separate network fabric component which we need to
shut down before we enter Linux (or any other OS). Along with that also
comes configuration of the fabric using a description file.
Today we always stop and configure the fabric in the boot script and
(again) exit it on device tree generation. This works ok for the normal
booti case, but with bootefi the payload we're running may still want to
access the network.
So let's add a new fsl_mc command that defers configuration and stopping
the hardware to when we actually exit U-Boot, so that we can still use
the fabric from an EFI payload.
For existing boot scripts, nothing should change with this patch.
Reviewed-by: York Sun <york.sun@nxp.com>
[agraf: Fix x86 build]
Enable this so that EFI applications (notably grub) can be run under U-Boot
on x86 platforms.
At present the 'hello world' EFI application is not supported for the
qemu-x86_efi_payload64 board. That board builds a payload consisting of a
64-bit header and a 32-bit U-Boot, which is incompatible with the way the
EFI loader builds its EFI application. The following error is obtained:
x86_64-linux-ld.bfd: i386 architecture of input file
`lib/efi_loader/helloworld.o' is incompatible with i386:x86-64 output
This could be corrected with additional Makefile rules. For now, this
feature is disabled for that board.
[agraf: drop hello kconfig bits]
It is useful to have a basic sanity check for EFI loader support. Add a
'bootefi hello' command which loads HelloWord.efi and runs it under U-Boot.
[agraf: Fix documentation, add unfulfilled kconfig dep]
At present we use a CONFIG option in efi.h to determine whether we are
building the EFI stub or not. This means that the same header cannot be
used for EFI_LOADER support. The CONFIG option will be enabled for the
whole build, even when not building the stub.
Use a different define instead, set up just for the files that make up the
stub.
Make sure that the cache flushes correctly by ensuring that the end
address is correctly aligned.
Add support for EFI console modes.
Mode 0 is always 80x25 and present by EFI specification.
Mode 1 is always 80x50 and not mandatory.
Mode 2 and above is freely usable.
If the terminal can handle mode 1, we mark it as supported.
If the terminal size is greater than mode 0 and different than mode 1,
we install it as mode 2.
Modes can be switch with cout_set_mode.
Changes in V5:
Correctly detect mode before enabling mode 2.
Changes in V4:
Reset cursor positon on mode switch
Use local variables in console query code
Changes in V3:
Valid mode are 0 to EFIMode-1
Fix style
Changes in V2:
Add mode switch
Report only the modes that we support
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
When adding network interface node use Messaging device path with
subtype MAC Address and device's MAC address as a value instead
of Media Device path type with subtype File Path and path "Net"
Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com>
This line is shown as
depends on (ARM64 ||\302\240ARM) && OF_LIBFDT
on my Emacs. Use ASCII characters only.
Assuming it is (ARM64 || ARM), remove the redundancy.
Unlike Linux, CONFIG_ARM includes CONFIG_ARM64 in U-Boot.
If fdt_getprop() fails, negative error code should be returned.
[ DTC commit: daa75e8fa5942caa8e97931aed3a1ee0b7edd74b ]
[ DTC commit: e28eff5b787adb3f461d1653598818b2f1f25a73 ]
Now that the overlay code has been merge upstream, update our copy to
what's been merged, since a significant number of issues have been fixed
during the merge process.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Compiler attributes are more commonly __foo style tags rather than big
upper case eye sores like EFI_RUNTIME_TEXT.
Simon Glass felt quite strongly about this, so this patch converts our
existing defines over to more eye friendly ones.
Add the required pieces to support the EFI loader on x86.
Since U-Boot only builds for 32-bit on x86, only a 32-bit EFI application
is supported. If a 64-bit kernel must be booted, U-Boot supports this
directly using FIT (see doc/uImage.FIT/kernel.its). U-Boot can act as a
payload for both 32-bit and 64-bit EFI.
These are missing in some functions. Add them to keep things consistent.
Reviewed-by: Alexander Graf <agraf@suse.de>
If the system has a valid "serial#" environment variable set (which boards that
can find it out programatically set automatically), use that as input for the
serial number and UUID fields in the SMBIOS tables.
So far we were only installing the FDT table and didn't have space
to store any other. Hence nobody realized that our efi table allocation
was broken in that it didn't set the indicator for the number of tables
plus one.
This patch fixes it, allowing code to allocate new efi tables.
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This
patch adds enablement for that case.
While at it, we also enable SMBIOS generation for ARM systems, since they support
EFI_LOADER.
The type 4 table generation code is very x86 centric today. Refactor things
out into the device model cpu class to allow the tables to get generated for
other architectures as well.
The SMBIOS generation code passes pointers as u32. That causes the compiler
to warn on casts to pointers. This patch moves all address pointers to
uintptr_t instead.
Technically u32 would be enough for the current SMBIOS2 style tables, but
we may want to extend the code to SMBIOS3 in the future which is 64bit
address capable.
We want to be able to add configuration table entries from our own code as
well as from EFI payload code. Export the boot service function internally
too, so that we can reuse it.
