path: root/lib
2018-05-29efi_loader: Use EFI_CACHELINE_SIZE in the image loader tooAlexander Graf
We were using our EFI_CACHELINE_SIZE define only in the runtime service code, but left the image loader to use plain CONFIG_SYS_CACHELINE_SIZE. This patch moves EFI_CACHELINE_SIZE into efi_loader.h and converts the image loader to use it. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-05-25tpm: add PCR authentication commands supportMiquel Raynal
Add support for the TPM2_PCR_SetAuthPolicy and TPM2_PCR_SetAuthValue commands. Change the command file and the help accordingly. Note: These commands could not be tested because the TPMs available do not support them, however they could be useful for someone else. The user is warned by the command help. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_HierarchyChangeAuth command supportMiquel Raynal
Add support for the TPM2_HierarchyChangeAuth command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add dictionary attack mitigation commands supportMiquel Raynal
Add support for the TPM2_DictionaryAttackParameters and TPM2_DictionaryAttackLockReset commands. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_GetCapability command supportMiquel Raynal
Add support for the TPM2_GetCapability command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_PCR_Read command supportMiquel Raynal
Add support for the TPM2_PCR_Read command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_PCR_Extend command supportMiquel Raynal
Add support for the TPM2_PCR_Extend command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_Clear command supportMiquel Raynal
Add support for the TPM2_Clear command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_SelfTest command supportMiquel Raynal
Add support for the TPM2_Selftest command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_Startup command supportMiquel Raynal
Add support for the TPM2_Startup command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: report driver error code to upper layerMiquel Raynal
Instead of returning a generic 'library' error, report back the actual error code so it can be displayed to the user by the regular error path. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add possible traces to analyze buffers returned by the TPMMiquel Raynal
When debugging, it is welcome to get more information about what the TPM returns. Add the possibility to print the packets received to show their exact content. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add macros to enhance TPM commands readabilityMiquel Raynal
TPM commands are much easier to read/write with these macros that will transform words or integers into byte strings. This way, there is no need to call pack_byte_string() while all variable length in a command are known (and at must 4 bytes, which is a lot of them). Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: prepare support for TPMv2.x commandsMiquel Raynal
Choice between v1 and v2 compliant functions is done with the configuration. Create the various files that will receive TPMv2-only code on the same scheme as for the TPMv1 code. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: disociate TPMv1.x specific and generic codeMiquel Raynal
There are no changes in this commit but a new organization of the code as follow. * cmd/ directory: > move existing code from cmd/tpm.c in cmd/tpm-common.c > move specific code in cmd/tpm-v1.c > create a specific header file with generic definitions for commands only called cmd/tpm-user-utils.h * lib/ directory: > move existing code from lib/tpm.c in lib/tpm-common.c > move specific code in lib/tpm-v1.c > create a specific header file with generic definitions for the library itself called lib/tpm-utils.h * include/ directory: > move existing code from include/tpm.h in include/tpm-common.h > move specific code in include/tpm-v1.h Code designated as 'common' is compiled if TPM are used. Code designated as 'specific' is compiled only if the right specification has been selected. All files include tpm-common.h. Files in cmd/ include tpm-user-utils.h. Files in lib/ include tpm-utils.h. Depending on the specification, files may include either (not both) tpm-v1.h or tpm-v2.h. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: prepare introduction of TPMv2.x support in KconfigMiquel Raynal
Because both major revisions are not compatible at all, let's make them mutually exclusive in Kconfig. This way we will be sure, when using a command or a library function that it is supported by the right revision. Current drivers are currently prefixed by "tpm_", we will prefix TPMv2.x files by "tpm2_" to make the distinction without moving everything. The Kconfig menu about TPM drivers is now divided into two sections, one for each specification. Compliant drivers with one specification will only show up if this specification _only_ has been selected, otherwise a comment is displayed. Once a driver is selected by the user, it selects automatically a boolean value, that is needed in order to activate the TPM commands. Selecting the TPM commands will automatically select the right command/library files. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework deps as TPM_V1 and TPM_V2 depend on TPM, drop TPM_DRIVER_SELECTED] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add extra blank lines between declarations and codeMiquel Raynal
Fix following checkpatch.pl issue in TPM-related code: WARNING: Missing a blank line after declarations Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: fix spellingMiquel Raynal
Fix following checkpatch.pl issues in TPM-related code: CHECK: '<x>' may be misspelled - perhaps '<y>'? Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: align arguments with open parenthesisMiquel Raynal
Fix following checkpatch.pl issue in TPM-related code: CHECK: Alignment should match open parenthesis Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: substitute deprecated uint<x>_t types with their u<x> equivalentMiquel Raynal
Fix following checkpatch.pl issues in TPM-related code: CHECK: Prefer kernel type 'u8' over 'uint8_t' CHECK: Prefer kernel type 'u16' over 'uint16_t' CHECK: Prefer kernel type 'u32' over 'uint32_t' Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: remove extra spaces between a function and its opening bracketMiquel Raynal
Fix following checkpatch.pl issue in TPM-related code: WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: remove redundant blank lineMiquel Raynal
Fix following checkpatch.pl issue in TPM-related code: CHECK: Please don't use multiple blank lines Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-18fdt: Add another Altera Arria10 clock init compatibleMarek Vasut
The DT bindings for the Arria10 clock init have changed, add another compatible to make them work with U-Boot until a proper clock driver gets written. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-05-10SPDX: Convert a few files that were missed beforeTom Rini
As part of the main conversion a few files were missed. These files had additional whitespace after the '*' and before the SPDX tag and my previous regex was too strict. This time I did a grep for all SPDX tags and then filtered out anything that matched the correct styles. Fixes: 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-08Merge git://git.denx.de/u-boot-mmcTom Rini
2018-05-08lib/Kconfig: Mark OF_LIBFDT_OVERLAY as depending on OF_LIBFDTTom Rini
The overlay code is only useful when OF_LIBFDT is set, so mark it as depending on that first. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-08configs: TI: Enable FIT Library overlay supportPraneeth Bajjuri
Enable the FDT library overlay support for all TI SOC family. Without this option, when Loading fdt from FIT image, the following warning is seen. "config with overlays but CONFIG_OF_LIBFDT_OVERLAY not set". Signed-off-by: Praneeth Bajjuri <praneeth@ti.com> Suggested-by: Andrew F.Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
2018-05-08lib: fdtdec: drop the old compatible about max77686Jaehoon Chung
Drop the old compatible about max77686. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-28Consolidate __assert_failed into one implementationAlex Kiernan
We had two implementations of __assert_failed which were almost identical, combine them into one. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-28spl: Disable printf if not requiredAlex Kiernan
Now we have a guard for printf, disable it in the build if it's not selected. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-28spl: Split sprintf, strto* from SPL serial in KconfigAlex Kiernan
When SPL serial is disabled, callers who need sprintf or strtoul fail because their inclusion is guarded by CONFIG_SPL_SERIAL_SUPPORT/ CONFIG_TPL_SERIAL_SUPPORT. Split printf, sprintf and strto into their own entries and then select all of them if SERIAL_SUPPORT is enabled to match the current behaviour. Include panic.o unconditionally as it can be called from anywhere which uses BUG_ON(). Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-28lib/rsa: Kconfig: Remove superfluous 'depends on RSA'Eugeniu Rosca
RSA_SOFTWARE_EXP and RSA_FREESCALE_EXP are wrapped inside: if RSA ... endif So, remove the redundant "depends on RSA" from their depends expression. In addition, move SPL_RSA into the same "if RSA ... endif" block, since its only direct dependeny is CONFIG_RSA. This tidies up and simplifies reading of lib/rsa/Kconfig. No functional change intended. Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-23efi_selftest: test EFI_DEVICE_PATH_UTILITIES_PROTOCOLHeinrich Schuchardt
Provide unit tests for the EFI_DEVICE_PATH_UTILITIES_PROTOCOL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: complete EFI_DEVICE_PATH_UTILITIES_PROTOCOLHeinrich Schuchardt
The missing services of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL are implemented. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: correcty determine total device path lengthHeinrich Schuchardt
Device paths may consist of multiple instances. Up to now we have only considered the size of the first instance. For the services of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL in most cases the total length of the device path is relevant. So let's rename efi_dp_size() to efi_dp_instance_size() and create a new function efi_dp_size() that calculates the total device path length. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: correctly determine length of empty device pathHeinrich Schuchardt
efi_dp_size() is meant to return the device path length without the end node. The length of a device path containing only an end node was incorrectly reported as 4. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: fix AppendDevicePathHeinrich Schuchardt
The logic of the AppendDevicePath service of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL is incorrectly implemented: * if both paths are NULL an end node has to be returned * if both paths are not NULL the end node of the second device path has to be kept Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: implement CreateDeviceNodeHeinrich Schuchardt
Implement the CreateDeviceNode service of the device path utility protocol. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_selftest: fix typo in efi_selftest_devicepath.cHeinrich Schuchardt
%s/provice/provide/ Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_selftest: do not execute test if setup failedHeinrich Schuchardt
Executing a test after failed setup may lead to unexpected behavior like an illegal memory access. So after a setup failure we should skip to teardown. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: no support for ARMV7_NONSEC=yHeinrich Schuchardt
We do not support bootefi booting ARMv7 in non-secure mode. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-13Revert "Kconfig: cmd: Make networking command dependent on NET"Joe Hershberger
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c where it changed the EFI dependency on NET. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-09Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-04-09 Highlights this time around: - Lots of minor spec compliance fixes - Support full range of GOP BLT commands - More fine grained error checking - Network fixes (init, DP) - Lots of other bug fixes...
2018-04-06efi_loader: Check machine type in the image headerIvan Gorinov
Check FileHeader.Machine to make sure the EFI executable image is built for the same architecture. For example, 32-bit U-Boot on x86 will print an error message instead of loading an x86_64 image and crashing. Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-05efi_loader: completely initialize networkHeinrich Schuchardt
Add missing network initialization code. Before the patch the network was only usable if a network command like dhcp or tftp had beed executed. This was visible when interrupting the console countdown and executing bootefi selftest for vexpress_ca15_tc2_defconfig. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-05efi_loader: new functions to print loaded image informationHeinrich Schuchardt
Introduce functions to print information about loaded images. If we want to analyze an exception in an EFI image we need the offset between the PC and the start of the loaded image. With efi_print_image_info() we can print the necessary information for a single image, e.g. UEFI image [0xbffe6000:0xbffe631f] pc=0x138 '/\snp.efi' efi_print_image_infos() provides output for all loaded images. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-05efi_selftest: test getinfo(EFI_FILE_SYSTEM_INFO)Heinrich Schuchardt
Check that the getinfo() service of the file protocol correctly returns the partion label. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
