Currently, only basic completion is supported (no globs), but this is
what we had previously.
The non-reentrant versions of the hashtable functions operate on a single
shared hashtable. So if two different people try using these funcs for
two different purposes, they'll cause problems for the other.
Avoid this by converting all existing hashtable consumers over to the
reentrant versions and then punting the non-reentrant ones.
The duplication of the do_reset prototype has gotten out of hand,
and they're not all in sync. Unify them all in command.h.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
Patch 253cb831 [zlib: add watchdog reset call] added already a few
watchdog reset calls to the new zlib U-Boot port. But on some boards
this is not enough. Additional calls are needed on boards with
short watchdog timeouts.
This was detected and tested on the lwmon5 board with a very short
watchdog timeout. Without this patch, the board resets during Linux
kernel decompression. With it, the decompression succeeds.
Cc: Detlev Zundel <dzu@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
As usually done in U-Boot, the watchdog_reset code is called via a
macro (WATCHDOG_RESET). In zlib.c this was done differently, by using
a function pointer which is initialized with WATCHDOG_RESET upon watchdog
usage or with NULL otherwise. This patch now uses the plain
WATCHDOG_RESET macros to call the function resulting in slightly smaller
U-Boot images and simpler code.
U-Boot code size reduction:
PowerPC board with watchdog support (lwmon5):
-> 80 bytes smaller image size
PowerPC board without watchdog support (sequoia):
-> 112 bytes smaller image size
This patch adds a new config parameter for adjusting the calculation of
hash table size when importing a buffer.
When importing a extremely small buffer (e.g. the default_environment)
the old calculation generated a hash table which could hold at most the
buffer content but no more entires.
The new calculation add a fixed number of entries to the result to fit
better for small import buffers. This amount may be configured by the
user in board file to adjust the behaviour.
Motivation:
* Old environment code used a pessimizing implementation:
- variable lookup used linear search => slow
- changed/added variables were added at the end, i. e. most
frequently used variables had the slowest access times => slow
- each setenv() would calculate the CRC32 checksum over the whole
environment block => slow
* "redundant" envrionment was locked down to two copies
* No easy way to implement features like "reset to factory defaults",
or to select one out of several pre-defined (previously saved) sets
of environment settings ("profiles")
* No easy way to import or export environment settings
API Changes:
- Variable names starting with '#' are no longer allowed
I didn't find any such variable names being used; it is highly
recommended to follow standard conventions and start variable names
with an alphanumeric character
- "printenv" will now print a backslash at the end of all but the last
lines of a multi-line variable value.
Multi-line variables have never been formally defined, allthough
there is no reason not to use them. Now we define rules how to deal
with them, allowing for import and export.
- Function forceenv() and the related code in saveenv() was removed.
At the moment this is causing build problems for the only user of
this code (schmoogie - which has no entry in MAINTAINERS); may be
fixed later by implementing the "env set -f" feature.
Inconsistencies:
- "printenv" will '\\'-escape the '\n' in multi-line variables, while
"printenv var" will not do that.
Advantages:
- "printenv" output much better readable (sorted)
- faster!
- extendable (additional variable properties can be added)
- new, powerful features like "factory reset" or easy switching
between several different environment settings ("profiles")
Disadvantages:
- Image size grows by typically 5...7 KiB (might shrink a bit again on
systems with redundant environment with a following patch series)
Implemented:
- env command with subcommands:
- env print [arg ...]
same as "printenv": print environment
- env set [-f] name [arg ...]
same as "setenv": set (and delete) environment variables
["-f" - force setting even for read-only variables - not
implemented yet.]
- end delete [-f] name
not implemented yet
["-f" - force delete even for read-only variables]
- env save
same as "saveenv": save environment
- env export [-t | -b | -c] addr [size]
export internal representation (hash table) in formats usable for
persistent storage or processing:
-t: export as text format; if size is given, data will be
padded with '\0' bytes; if not, one terminating '\0'
will be added (which is included in the "filesize"
setting so you can for exmple copy this to flash and
keep the termination).
-b: export as binary format (name=value pairs separated by
'\0', list end marked by double "\0\0")
-c: export as checksum protected environment format as
used for example by "saveenv" command
addr: memory address where environment gets stored
size: size of output buffer
With "-c" and size is NOT given, then the export command will
format the data as currently used for the persistent storage,
i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and
prepend a valid CRC32 checksum and, in case of resundant
environment, a "current" redundancy flag. If size is given, this
value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32
checksum and redundancy flag will be inserted.
With "-b" and "-t", always only the real data (including a
terminating '\0' byte) will be written; here the optional size
argument will be used to make sure not to overflow the user
provided buffer; the command will abort if the size is not
sufficient. Any remainign space will be '\0' padded.
On successful return, the variable "filesize" will be set.
Note that filesize includes the trailing/terminating '\0'
byte(s).
Usage szenario: create a text snapshot/backup of the current
settings:
=> env export -t 100000
=> era ${backup_addr} +${filesize}
=> cp.b 100000 ${backup_addr} ${filesize}
Re-import this snapshot, deleting all other settings:
=> env import -d -t ${backup_addr}
- env import [-d] [-t | -b | -c] addr [size]
import external format (text or binary) into hash table,
optionally deleting existing values:
-d: delete existing environment before importing;
otherwise overwrite / append to existion definitions
-t: assume text format; either "size" must be given or the
text data must be '\0' terminated
-b: assume binary format ('\0' separated, "\0\0" terminated)
-c: assume checksum protected environment format
addr: memory address to read from
size: length of input data; if missing, proper '\0'
termination is mandatory
- env default -f
reset default environment: drop all environment settings and load
default environment
- env ask name [message] [size]
same as "askenv": ask for environment variable
- env edit name
same as "editenv": edit environment variable
- env run
same as "run": run commands in an environment variable
TODO:
- drop default env as implemented now; provide a text file based
initialization instead (eventually using several text files to
incrementally build it from common blocks) and a tool to convert it
into a binary blob / object file.
- It would be nice if we could add wildcard support for environment
variables; this is needed for variable name auto-completion,
but it would also be nice to be able to say "printenv ip*" or
"printenv *addr*"
- Some boards don't link any more due to the grown code size:
DU405, canyonlands, sequoia, socrates.
=> cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Stefan Roese <sr@denx.de>,
Heiko Schocher <hs@denx.de>
- Dropping forceenv() causes build problems on schmoogie
=> cc: Sergey Kubushyn <ksi@koi8.net>
- Build tested on PPC and ARM only; runtime tested with NOR and NAND
flash only => needs testing!!
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Cc: Stefan Roese <sr@denx.de>,
Cc: Sergey Kubushyn <ksi@koi8.net>
This implementation is based on code from uClibc-0.9.30.3 but was
modified and extended for use within U-Boot.
Major modifications and extensions:
* hsearch() [modified / extended]:
- While the standard version does not make any assumptions about
the type of the stored data objects at all, this implementation
works with NUL terminated strings only.
- Instead of storing just pointers to the original objects, we
create local copies so the caller does not need to care about the
data any more.
- The standard implementation does not provide a way to update an
existing entry. This version will create a new entry or update an
existing one when both "action == ENTER" and "item.data != NULL".
- hsearch_r(): Instead of returning 1 on success, we return the
index into the internal hash table, which is also guaranteed to be
positive. This allows us direct access to the found hash table
slot for example for functions like hdelete().
* hdelete() [added]:
- The standard implementation of hsearch(3) does not provide any way
to delete any entries from the hash table. We extend the code to
do that.
* hexport() [added]:
- Export the data stored in the hash table in linearized form:
Entries are exported as "name=value" strings, separated by an
arbitrary (non-NUL, of course) separator character. This allows to
use this function both when formatting the U-Boot environment for
external storage (using '\0' as separator), but also when using it
for the "printenv" command to print all variables, simply by using
as '\n" as separator. This can also be used for new features like
exporting the environment data as text file, including the option
for later re-import.
- The entries in the result list will be sorted by ascending key
values.
* himport() [added]:
- Import linearized data into hash table. This is the inverse
function to hexport(): it takes a linear list of "name=value"
pairs and creates hash table entries from it.
- Entries without "value", i. e. consisting of only "name" or
"name=", will cause this entry to be deleted from the hash table.
- The "flag" argument can be used to control the behaviour: when
the H_NOCLEAR bit is set, then an existing hash table will kept,
i. e. new data will be added to an existing hash table;
otherwise, old data will be discarded and a new hash table will
be created.
- The separator character for the "name=value" pairs can be
selected, so we both support importing from externally stored
environment data (separated by NUL characters) and from plain text
files (entries separated by newline characters).
- To allow for nicely formatted text input, leading white space
(sequences of SPACE and TAB chars) is ignored, and entries
starting (after removal of any leading white space) with a '#'
character are considered comments and ignored.
- NOTE: this means that a variable name cannot start with a '#'
character.
- When using a non-NUL separator character, backslash is used as
escape character in the value part, allowing for example fo
multi-line values.
- In theory, arbitrary separator characters can be used, but only
'\0' and '\n' have really been tested.
Code adapted from uClibc-0.9.30.3
Needed for hash table support; probably useful in a lot of other
places as well.
use a union to cause necessary alignment per architecture
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Applying a little creative format string allows us to shrink the initial
data read & display loop by only calling printf once. Re-using the local
data buffer to generate the string we want to display then allows us to
output everything with just one printf call instead of multiple calls to
the putc function.
The local stack buffer needs increasing by 1 byte, but the resulting code
shrink and speed up is worth it I think.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Modification of print_size to avoid use of divides and especially
long long divides. Keep the binary scale factor in terms of bit
shifts instead. This should be faster, since the previous code
gave the compiler no clues that the divides where always powers
of two, preventing optimisation.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Acked-by: Timur Tabi <timur@freescale.com>
Modify print_size() so that it can accept numbers larger than 4GB on 32-bit
systems.
Add support for display terabyte, petabyte, and exabyte sizes. Change the
output to use International Electrotechnical Commission binary prefix standard.
In print_size(), the math that calculates the fractional remainder of a number
used the same integer size as a physical address. However, the "10 *" factor
of the algorithm means that a large number (e.g. 1.5GB) can overflow the
integer if we're running on a 32-bit system. Therefore, we need to
disassociate this function from the size of a physical address.
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Move the libfdt directory into the common lib/ directory to clean up the
top-level directory.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
