path: root/lib
2019-03-20efi_selftest: fix test_hii_string_get_string()Heinrich Schuchardt
The check testing the string result of get_string() returned the wrong result. The result was ignored. Use efi_st_strcmp_16_8() for the string comparison. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-20efi_loader: superfluous conversion in efi_file_open()Heinrich Schuchardt
printf("%ls", ..) expects u16 * as argument to print. There is not need for a conversion to wchar_t *. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-20efi_loader: remove superfluous check in efi_setup_loaded_image()Heinrich Schuchardt
It does not make any sense to check if a pointer is NULL if we have dereferenced it before. Reported-by: Coverity (CID 185827) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-20efi_loader: missing return in efi_get_next_variable_name()Heinrich Schuchardt
Add a missing return statement in efi_get_next_variable_name(). Reported-by: Coverity (CID 185834) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-20efi_loader: endless loop in add_strings_package()Heinrich Schuchardt
Avoid an endless loop in add_strings_package(). Suggested-by: Takahiro Akashi <takahiro.akashi@linaro.org> Reported-by: Coverity (CID 185833) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-20efi_loader: correct parameter size in efi_allocate_poolHeinrich Schuchardt
efi_allocate_pages() expects a (uint64_t *) pointer to pass the address of the assigned memory. If we pass the address of a pointer here, an illegal memory access occurs on 32bit systems. Fixes: 282a06cbcae8 ("efi_loader: Expose U-Boot addresses in memory map for sandbox") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-14efi_loader: fix build error for freestanding.oHeinrich Schuchardt
Since commit f51a226436a87 ("efi_loader: provide freestanding library") in parallel builds errors lib/efi_selftest/../efi_loader/efi_freestanding.o: file not recognized: File truncated occur. Obviously make cannot correctly sequence parallel builds with a dependency like ../efi_loader/efi_freestanding.o. Fixes: f51a226436a87 ("efi_loader: provide freestanding library") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-10efi_loader: Fix serial console size detectionMatthias Brugger
Function term_read_reply tries to read from the serial console until the end_char was read. This can hang forever if we are, for some reason, not able to read the full response (e.g. serial buffer too small, frame error). This patch moves the timeout detection into term_read_reply() to assure we will make progress. Fixes: 6bb591f704 ("efi_loader: query serial console size reliably") Signed-off-by: Matthias Brugger <mbrugger@suse.com> Throw missing error when an incomplete reply for the cursor position is received. Change type of argument of term_get_char() *s32. This renders the function reusable in efi_cin_read_key(). Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-02efi_loader: HII protocols: debug messagesHeinrich Schuchardt
When package types are not supported by our implementation of the HII database protocol supported error messages are displayed. Essentially the output is only needed for debugging. By using EFI_PRINT() the messages are only written for in debug mode and with correct indentation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-02efi_loader: HII protocols: fix new_package_list()Heinrich Schuchardt
In new_package_list() we call new_packagelist() to create a new package list. Next we try to add the packages which fails for form packages. Due to this error we call free_packagelist(). Now in free_packagelist() list_del() is called for an uninitialized field hii->link. This leads to changing random memory addresses. To solve the problem move the initialization of hii->link to new_packagelist(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-03-02efi_loader: do not add \ in efi_fs_from_name()Heinrich Schuchardt
In the `efidebug boot add` command we do not want an unsolicited leading backslash added to the file name. There is no good reason to mark a loaded file with a backslash as absolute. Anyway when reading files the file name will be interpreted as relative to root directory of the device. So let's get rid of this backslash. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25efi_loader: define load option attributesAKASHI Takahiro
See UEFI specification v2.7a, section 3.1.3, "Load Option Processing." Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25efi_loader: fix entry count in bootmgrHeinrich Schuchardt
Since commit 914df75b0c97 ("efi_loader: fix EFI entry counting") entry_count is already set to 1 before efi_bootmgr_load() is called. So we should not increment it when entering the function. Without the patch an assert error occurs in efi_get_variable() if DEBUG is defined. Fixes: 914df75b0c97 ("efi_loader: fix EFI entry counting") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25efi_loader: error message if BootOrder not definedHeinrich Schuchardt
For booting via `bootefi bootmgr` it is necessary that the EFI variable BootOrder is defined. Provide a diagnostic message if the variable is missing. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-19tpm: simplify: tpm_set_global_lock()Heinrich Schuchardt
When in pack_byte_string() memcpy() is called for size 0 the source buffer address has no relevance. So we can use NULL here. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-16efi_loader: do not miss last relocation blockHeinrich Schuchardt
If the last block in the relocation table contains only a single relocation, the current coding ignores it. Fix the determination of the end of the relocation table. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: documentation of image loaderHeinrich Schuchardt
- Add missing function descriptions. - Update existing function descriptions to match Sphinx style. - Add lib/efi_loader/efi_image_loader.c to the input files for Sphinx generated documentation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: fix EFI entry countingHeinrich Schuchardt
`bootefi selftest` fails on qemu-x86_defconfig if efi_selftest() is not invoked using EFI_CALL(). Likewise we call the entry point of EFI payloads with EFI_CALL(efi_start_image()). entry_count indicates if we are in U-Boot (1) or in EFI payload code (0). As we start in U-Boot code the initial value has to be 1. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: use efi_start_image() for bootefiHeinrich Schuchardt
Remove the duplicate code in efi_do_enter() and use efi_start_image() to start the image invoked by the bootefi command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: set entry point in efi_load_pe()Heinrich Schuchardt
Up to now efi_load_pe() returns the entry point or NULL in case of an error. This does not allow to return correct error codes from LoadImage(). Let efi_load_pe() return a status code and fill in the entry point in the corresponding field of the image object. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: LoadImage: always allocate new pagesHeinrich Schuchardt
If we want to properly unload images in Exit() the memory should always be allocated in the same way. As we allocate memory when reading from file we should do the same when the original image is in memory. A further patch will be needed to free the memory when Exit() is called. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: error handling in efi_setup_loaded_image()Heinrich Schuchardt
In case of an error we should set the returned pointers to NULL. This ensures that an illegal free does not occur even if the caller calls free() for the handles. If protocols cannot be installed, release all resources. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16lib/vsprintf: print '?' for illegal Unicode sequenceHeinrich Schuchardt
Commit 0e66c10a7d80 ("lib: vsprintf: avoid overflow printing UTF16 strings") broke the Unicode unit tests: an illegal UTF16 code point should be printed as '?'. Fixes: 0e66c10a7d80 ("lib: vsprintf: avoid overflow printing UTF16 strings") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_selftest: LoadImage from file device pathHeinrich Schuchardt
Provide a unit test that calls LoadImage() with a file device path and executes the application via StartImage(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: comments for efi_file_from_path()Heinrich Schuchardt
Add more comments for efi_file_from_path(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: efi_dp_split_file_path() error handlingHeinrich Schuchardt
If the path passed to efi_dp_split_file_path() does not contain a reference to a file it returns EFI_OUT_OF_RESOURCES. This does not properly indicate the kind of the problem that occurred. Return EFI_INVALID_PARAMETER instead. Update function description. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_selftest: fix memory allocation in HII testsHeinrich Schuchardt
In efi_selftest we are in EFI land. We cannot call U-Boot library functions malloc() and free() but should use the boot time services instead. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Alexander Graf <agraf@suse.de>
2019-02-16efi_selftest: do not use efi_free_pool()Heinrich Schuchardt
In efi_selftest we are in EFI land. We should not use U-Boot library functions but boot time services for memory management. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: fix EFI_FILE_PROTOCOL.GetInfo()Heinrich Schuchardt
We check the existence of files with fs_exist(). This function calls fs_close(). If we do not set the active block device again fs_opendir() fails and we do not set the flag EFI_FILE_DIRECTORY. Due to this error the `cd` command in the EFI shell fails. So let's add the missing set_blk_dev(fh) call. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13lib: vsprintf: avoid overflow printing UTF16 stringsHeinrich Schuchardt
We have to ensure while printing UTF16 strings that we do not exceed the end of the print buffer. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: Make HII a config optionAlexander Graf
Heinrich ran into issues with HII and iPXE which lead to #SErrors on his Odroid-C2 system. We definitely do not want to regress just yet, so let's not expose the HII protocols by default. Instead, let's make it a config option that people can play with This way, we can stabilize the code in tree without breaking any users. Once someone figures out, why this breaks iPXE (probably a NULL dereference), we can enable it by default. Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de> --- v1 -> v2: - Remove HII selftest as well v2 -> v3: - Make config option
2019-02-13efi_loader: debug output for HII protocolsHeinrich Schuchardt
For correct indention use EFI_PRINT() instead of debug(). For printing efi_uintn_t or size_t use the %zu or %zx format code. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_selftest: fix HII testsHeinrich Schuchardt
efi_st_printf() does not support format code %ld. Anyway the format code for size_t would be %zu which isn't supported either. We do not want any divisions to avoid invalid references to integer arithmetic routines, cf. https://gcc.gnu.org/onlinedocs/gccint/Integer-library-routines.html. As a simple remedy remove the noisy messages from the output. They are not relevant for automated testing. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_selftest: add HII database protocols testAKASHI Takahiro
This efi_selftest tests HII database protocol and HII string protocol. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi: hii: add HII config routing/access protocolsAKASHI Takahiro
This patch is a place holder for HII configuration routing protocol and HII configuration access protocol. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi: hii: add keyboard layout package supportAKASHI Takahiro
Allow for handling keyboard layout package in HII database protocol. A package can be added or deleted in HII database protocol, but we don't set 'current' keyboard layout as there is no driver that requests a keyboard layout. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi: hii: add guid package supportAKASHI Takahiro
Allow for handling GUID package in HII database protocol. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: Initial HII database protocolsLeif Lindholm
This patch provides enough implementation of the following protocols to run EDKII's Shell.efi and UEFI SCT: * EfiHiiDatabaseProtocol * EfiHiiStringProtocol Not implemented are: * ExportPackageLists() * RegisterPackageNotify()/UnregisterPackageNotify() * SetKeyboardLayout() (i.e. *current* keyboard layout) HII database protocol in this patch series can handle only: * GUID package * string package * keyboard layout package (The other packages, except Device path package, will be necessary for interactive and graphical UI.) Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Signed-off-by: Rob Clark <robdclark@gmail.com> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: GetNextVariableName() relies on REGEXHeinrich Schuchardt
Our implementation of GetNextVariableName() relies on CONFIG_REGEX=y. So EFI_LOADER has to select it. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: fix GetNextVariableNameHeinrich Schuchardt
Our current implementation of GetNextVariableName() first collects all EFI variables. If none is found at all hexport_r() returns a zero length string terminated by \0 and the value 1 as number of bytes in the returned buffer. In this case GetNextVariableName() has to return EFI_NOT_FOUND. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: do not use symbolic linksHeinrich Schuchardt
Symbolic links are not supported on all file systems, e.g. not on FAT. So it is not wise to use them in our source tree. Use a qualified path to refer to lib/efi_loader/efi_freestanding.c in scripts/Makefile.lib instead. Reported-by: Alexander Graf <agraf@suse.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: Fix build with O=] Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: use library memcpy() in helloworld.efiHeinrich Schuchardt
Helloworld does not need its own memcpy() implementation anymore. Use the one provided in efi_freestanding.c. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: use freestanding library for efi appsHeinrich Schuchardt
GCC requires that freestanding programs provide memcpy(), memmove(), memset(), and memcmp(). Add the library functions when building a *.efi files. The EFI selftests might use other compilation flags. So use a symbolic link to provide lib/efi_selftest/efi_freestanding.c and compile it separately. Reported-by: Alexander Graf <agraf@suse.de> Fixes: 5be444d14b38 ("efi_loader: consistent build flags for EFI applications") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: provide freestanding libraryHeinrich Schuchardt
GCC requires that freestanding programs provide memcpy(), memmove(), memset(), and memcmp(). Provide the required library functions. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_selftest: fix variables test for GetNextVariableName()AKASHI Takahiro
There is a bug in efi variables test. Fix it with some cosmetic improvements. Please note that efi variables test still fails at QueryVariableInfo() and GetVariable(), but this is not due to a change in this patch. ==8<== Testing EFI API implementation Selected test: 'variables' Setting up 'variables' Setting up 'variables' succeeded Executing 'variables' .../u-boot/lib/efi_selftest/efi_selftest_variables.c(60): TODO: QueryVariableInfo failed .../u-boot/lib/efi_selftest/efi_selftest_variables.c(131): TODO: GetVariable returned wrong length 7 .../u-boot/lib/efi_selftest/efi_selftest_variables.c(133): TODO: GetVariable returned wrong value Executing 'variables' succeeded Boot services terminated Summary: 0 failures ==>8== Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: implement GetNextVariableName()AKASHI Takahiro
The current GetNextVariableName() is a placeholder. With this patch, it works well as expected. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> rebased on efi-next Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: comments for variable servicesHeinrich Schuchardt
Comment the functions implementing the runtime variable services. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: remove duplicate function mem2hex()Heinrich Schuchardt
Replace duplicate function mem2hex() by inline function bin2hex(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: eliminate duplicate function hex2mem()Heinrich Schuchardt
Use existing inline function hex2bin() instead of defining a new one. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2019-02-13efi_loader: consistent build flags for EFI applicationsHeinrich Schuchardt
At the same time adding and removing the -Os flag does not make any sense. Actually it leads to -Os not being used. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
