path: root/lib
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-28lib/display_options: Fix print_freqSuriyan Ramasami
Build without CONFIG_SPL_SERIAL_SUPPORT does not print the cpu freq. I have seen this in the odroid U3 board, where on boot one sees this: CPU: Exynos4412 @ GHz instead of: CPU: Exynos4412 @ 1 GHz I am assuming that this change was done to get rid of compiler warnings related to unused variables when building with CONFIG_SPL_SERIAL_SUPPORT not being defined in an SPL build. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-26fdtdec: Fix possible infinite loop in fdtdec_get_pci_vendev()Bin Meng
When there is no valid compatible string in current list, we should advance to next one in the compatible string list. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-14Revert "fdt: Fix fdtdec_get_addr_size() for 64-bit"Simon Glass
This reverts commit 5b34436035fc862b5e8d0d2c3eab74ba36f1a7f4. This function has a few problems. It calls fdt_parent_offset() which as mentioned in code review is very slow. https://patchwork.ozlabs.org/patch/499482/ https://patchwork.ozlabs.org/patch/452604/ It also happens to break SPI flash on Minnowboard max which is how I noticed that this was applied. I can send a patch to tidy that up, but in any case I think we should consider a revert until the function is better implemented. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-14x86: baytrail: Configure FSP UPD from device treeAndrew Bradford
Allow for configuration of FSP UPD from the device tree which will override any settings which the FSP was built with itself. Modify the MinnowMax and BayleyBay boards to transfer sensible UPD settings from the Intel FSPv4 Gold release to the respective dts files, with the condition that the memory-down parameters for MinnowMax are also used. Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Removed fsp,mrc-debug-msg and fsp,enable-xhci for minnowmax, bayleybay Fixed lines >80col Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-08arm: socfpga: misc: Reset ethernet from OFMarek Vasut
Reset the GMAC ethernets based on the "resets" OF node instead of ad-hoc hardcoded values in the U-Boot code. Since we don't have a proper reset framework in place yet, we have to do this slightly ad-hoc parsing of the OF tree instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-08-05dts: Drop unused compatible ID for the NXP video bridgeSimon Glass
This has moved to driver model so we can drop the fdtdec support. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05video: Remove the old parade driverSimon Glass
We have a new one which uses driver model and device tree configuration. Remove the old one. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05power: Remove old TPS65090 driversSimon Glass
Remove the old drivers (both the normal one and the cros_ec one) now that we have new drivers that use driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Add functions for decoding the EFI tablesSimon Glass
The EFI stub can pass a table to U-Boot with information about the memory map Potentially other things will follow. Add a way to access this table. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add 64-bit payload supportSimon Glass
Most EFI implementations use 64-bit. Add a way to build U-Boot as a 64-bit EFI payload. The payload unpacks a (32-bit) U-Boot and starts it. This can be enabled for x86 boards at present. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Display the correct initcall pre-relocation valuesSimon Glass
With EFI the start address of U-Boot is specified differently. We could consider just setting GD_FLG_RELOC and then setting up reloc_off. But that flag has other implementations and we are not able to use U-Boot relocation which this flag implies. Instead, just add a special case for EFI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05lib: fdt: fix indent of #ifdef..#endif conditionalMasahiro Yamada
Match the depth of indentation between #ifdef and #endif for better readability. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28ARM: Tegra210: Add support to common Tegra source/config filesTom Warren
Derived from Tegra124, modified as appropriate during T210 board bringup. Cleaned up debug statements to conserve string space, too. This also adds misc 64-bit changes from Thierry Reding/Stephen Warren. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-07-28fdt: Fix fdtdec_get_addr_size() for 64-bitThierry Reding
Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-07-22linux_compat: handle __GFP_ZERO in kmalloc()Masahiro Yamada
Currently, kzalloc() returns zero-filled memory, while kmalloc() simply ignores the second argument and never fills the memory area with zeros. I want kmalloc(size, __GFP_ZERO) to behave as kzalloc() does, which will make it easier to add more memory allocator variants. With the introduction of __GFP_ZERO flag, going forward, kzmalloc() variants can fall back to kmalloc() enabling the __GFP_ZERO flag. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-07-22linux_compat: move vzalloc() to header file as an inline functionMasahiro Yamada
The vzalloc(size) is equivalent to kzalloc(size, 0). Move it to include/linux/compat.h as an inline function in order to avoid the function call overhead. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-21fdt: Provide debug info when a device tree cannot be foundSimon Glass
It can be quite confusing with a new platform to figure out why the device tree cannot be located. Add some debug information for this case. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21lib: Add function to extract a number from the end of a stringSimon Glass
Split out the code in fdtdec which finds a number at the end of a string. It can be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Add rivest cipher 4 (rc4) implementationSimon Glass
Add an implementation of RC4. This will be used by Rockchip booting but may be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Drop CONFIG_ERRNO_STR from SPLSimon Glass
This bloats the code size quite a bit and is less useful in SPL where there is no command line. Avoid including this code in SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21fdt: Add fdt_first/next_region() functionsSimon Glass
These have been sent upstream but not accepted to libfdt. For now, bring these into U-Boot to enable fdtgrep to operate. We will use fdtgrep to cut device tree files down for SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21fdt: Add a function to remove unused strings from a device treeSimon Glass
Property names are stored in a string table. When a node property is removed, the string table is not updated since other nodes may have a property with the same name. Thus it is possible for the string table to build up a number of unused strings. Add a function to remove these. This works by building a new device tree from the old one, adding strings one by one as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Add a dhrystone benchmark commandSimon Glass
Drystone provides a convenient sanity check that the CPU is running at full speed. Add this as a command which can be enabled as needed. Note: I investigated using Coremark for this but there was a license agreement and I could not work out if it was GPL-compatible. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-20libfdt: fix error code of fdt_count_strings()Masahiro Yamada
Currently, this function returns a positive value on error, so we never know whether this function has succeeded or failed. For example, if the given property is not found, fdt_getprop() returns -FDT_ERR_NOTFOUND, and then this function inverts it, i.e., returns FDT_ERR_NOTFOUND (=1). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Fixes: bc4147ab2d69 ("fdt: Add a function to count strings") Acked-by: Simon Glass <sjg@chromium.org>
2015-07-20libfdt: fix error code of fdt_get_string_index()Masahiro Yamada
As mentioned in the comment block in include/libfdt.h, fdt_get_string_index() is supposed to return a negative value on error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Fixes: 5094eb408a5d ("fdt: Add functions to retrieve strings") Acked-by: Simon Glass <sjg@chromium.org>
2015-07-20fdt: armv8: Fix build warnings on armv8Haikun Wang
Fix below build warnings on armv8, drivers/spi/fsl_dspi.c: In function ‘fsl_dspi_ofdata_to_platdata’: drivers/spi/fsl_dspi.c:667:2: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘fdt_addr_t’ [-Wformat=] debug("DSPI: regs=0x%x, max-frequency=%d, endianess=%s, num-cs=%d\n", ^ lib/fdtdec.c: In function ‘fdtdec_get_addr_size’: lib/fdtdec.c:105:4: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘fdt_size_t’ [-Wformat=] debug("addr=%08lx, size=%08lx\n", ^ Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-08Allow CONFIG_REGEX to be disabled when CONFIG_NETJoe Hershberger
Instead of selecting REGEX when NET is enabled, make it the default, but allow boards that are tiny to disable it and lose functionality on all but the first Ethernet adapter. cm-bf548, bf538f-ezkit, and bf533-stamp need this. None appear to have more than one Ethernet interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-06-11Merge git://git.denx.de/u-boot-dmTom Rini
2015-06-11blackfin: fix undefined reference to srand and randMasahiro Yamada
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies) accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards. Prior to that commit, those boards defined CONFIG_LIB_RAND, but not CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have touched them, but in fact it ripped CONFIG_LIB_RAND off from all the header files, which caused undefined reference to srand and rand. CONFIG_LIB_RAND=y must be revived for such boards. BTW, this commit indeed makes it better, but even with this fix, three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not build due to region 'ram' overflowed error. This was cause by commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs) because CMD_NET selects NET, and NET selects REGEX. Eventually, some boards were newly enabled with CONFIG_REGEX, increasing the memory footprint. A patch is expected to fix the build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-10dm: usb: tegra: Drop legacy USB codeSimon Glass
Drop the code that doesn't use driver model for USB. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: gpio: add pinctrl support from the device treeGabriel Huau
Every pin can be configured now from the device tree. A dt-bindings has been added to describe the different property available. Change-Id: I1668886062655f83700d0e7bbbe3ad09b19ee975 Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Refactor PIRQ routing supportBin Meng
PIRQ routing is pretty much common in Intel chipset. It has several PIRQ links (normally 8) and corresponding registers (either in PCI configuration space or memory-mapped IBASE) to configure the legacy 8259 IRQ vector mapping. Refactor current Queensbay PIRQ routing support using device tree and move it to a common place, so that we can easily add PIRQ routing support on a new platform. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-01net: Fix NET_RANDOM_ETHADDR dependenciesMichal Simek
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to Kconfig to ensure that library is also compiled. Remove the definitions from Blackfin boards' include/configs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-14pmic: max77686 set the same compatible as in the kernelPrzemyslaw Marczak
This commit also updates the proper dts files. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14lib: Kconfig: add entry for errno_str() functionPrzemyslaw Marczak
2015-05-14sandbox: Fix warning in display_optionsSimon Glass
This fixes a warning in the print_buffer() function with some toolchains. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-14tpm: Rename Infineon TPM to slb9645ttSimon Glass
This name is used in Linux, so use it in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-13tegra: video: Support serial output resource (SOR) on tegra124Simon Glass
The SOR is required for talking to eDP LCD panels. Add a driver for this which will be used by the DisplayPort driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13fdt: Add binding decode function for display-timingsSimon Glass
This is useful for display parameters. Add a simple decode function to read from this device tree node. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-06dm: usb: exynos: Drop legacy USB codeSimon Glass
2015-04-29Add print_freq() to display frequencies nicelySimon Glass
Add a function similar to print_size() that works for frequencies. It can handle from Hz to GHz. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-29Move display_options functions to their own headerSimon Glass
Before adding one more function, create a separate header to help reduce the size of common.h. Add the missing function comments and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
