When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We had two implementations of __assert_failed which were almost identical,
combine them into one.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Now we have a guard for printf, disable it in the build if it's not
selected.
When SPL serial is disabled, callers who need sprintf or strtoul fail
because their inclusion is guarded by CONFIG_SPL_SERIAL_SUPPORT/
CONFIG_TPL_SERIAL_SUPPORT.
Split printf, sprintf and strto into their own entries and then select
all of them if SERIAL_SUPPORT is enabled to match the current behaviour.
Include panic.o unconditionally as it can be called from anywhere which
uses BUG_ON().
RSA_SOFTWARE_EXP and RSA_FREESCALE_EXP are wrapped inside:
if RSA
endif
So, remove the redundant "depends on RSA" from their depends expression.
In addition, move SPL_RSA into the same "if RSA ... endif" block, since
its only direct dependeny is CONFIG_RSA. This tidies up and simplifies
reading of lib/rsa/Kconfig.
No functional change intended.
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
Provide unit tests for the EFI_DEVICE_PATH_UTILITIES_PROTOCOL.
The missing services of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL are
implemented.
Device paths may consist of multiple instances. Up to now we have only
considered the size of the first instance. For the services of the
EFI_DEVICE_PATH_UTILITIES_PROTOCOL in most cases the total length of the
device path is relevant.
So let's rename efi_dp_size() to efi_dp_instance_size() and create a new
function efi_dp_size() that calculates the total device path length.
efi_dp_size() is meant to return the device path length without the end
node.
The length of a device path containing only an end node was incorrectly
reported as 4.
The logic of the AppendDevicePath service of the
EFI_DEVICE_PATH_UTILITIES_PROTOCOL is incorrectly implemented:
* if both paths are NULL an end node has to be returned
* if both paths are not NULL the end node of the second device path has to
be kept
Implement the CreateDeviceNode service of the device path utility protocol.
%s/provice/provide/
Executing a test after failed setup may lead to unexpected behavior like
an illegal memory access. So after a setup failure we should skip to
teardown.
We do not support bootefi booting ARMv7 in non-secure mode.
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c
where it changed the EFI dependency on NET.
Reviewed-by: Duncan Hare <dh@synoia.com>
Patch queue for efi - 2018-04-09
Highlights this time around:
- Lots of minor spec compliance fixes
- Support full range of GOP BLT commands
- More fine grained error checking
- Network fixes (init, DP)
- Lots of other bug fixes...
Check FileHeader.Machine to make sure the EFI executable image is built
for the same architecture. For example, 32-bit U-Boot on x86 will print
an error message instead of loading an x86_64 image and crashing.
Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com>
Add missing network initialization code.
Before the patch the network was only usable if a network command like
dhcp or tftp had beed executed.
This was visible when interrupting the console countdown and executing
bootefi selftest for vexpress_ca15_tc2_defconfig.
Introduce functions to print information about loaded images.
If we want to analyze an exception in an EFI image we need the offset
between the PC and the start of the loaded image.
With efi_print_image_info() we can print the necessary information for a
single image, e.g.
UEFI image [0xbffe6000:0xbffe631f] pc=0x138 '/\snp.efi'
efi_print_image_infos() provides output for all loaded images.
Check that the getinfo() service of the file protocol correctly
returns the partion label.
efi_selftest_disk_image.h contains a disk image. We use it to test the
EFI_FILE_PROTOCOL. The patch sets the partition label to 'U-BOOT TEST'.
Implement the information type EFI_FILE_SYSTEM_INFO in the service
GetInfo() of the EFI_FILE_PROTOCOL.
The volume label is not available in U-Boot. As a work-around use the
partition name instead.
Use const efi_guid_t* when passing GUIDs.
In the EFI_FILE_PROTOCOL buffer sizes and positions are passed as UINTN and
not as u64.
According to the Portable Executable and Common Object File Format
Specification the image size must be a multiple of the alignment
of sections.
For analyzing crash output the relocation address and size are needed.
Save them in the loaded image info.
We generally use efi_uintn_t where the UEFI spec uses UINTN.
Since the backing memory for a new device path can contain stale
data we have to make sure that we zero the buffer. Otherwise some
code paths that don't set all fields in a structure backed by this
device path might contain unwanted stale data.
Signed-off-by: Patrick Wildt <patrick@blueri.se>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
When CONFIG_DM_ETH is set, we assemble the device path properly with a
full device hierarchy. Our helper function dp_fill() even put the MAC
node itself in it for us.
However, for non-DM compatibility we also have code in that added the
MAC node manually. That code now runs on top of the existing MAC node:
Handle 0x3db2f6b0
/HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]
/USBClass(0,0,9,0,0)/USBClass(424,9514,9,0,2)/MacAddr(b8:27:eb:e1:81:47,1)
/MacAddr(b8:27:eb:e1:81:47,57)/EndEntire
We obviously don't need the additional node and in fact, grub chokes on
it and fails to match the DP against the ethernet device node. So this
patch moves the additional MAC node into the non-DM code path:
Handle 0x3db3fde0
/EndEntire
While at it, we also mark the non-DM MAC node as ethernet.
Fixes: b66c60dde9d ("efi_loader: add device-path utils")
The efi_add_runtime_mmio function incorrectly returned the added
address as return value rather than EFI_SUCCESS. Fix it by checking
the return value of efi_add_memory_map properly.
Fixes: f057cfef5dc ("efi_loader: exit status for efi_reset_system_init")
The GOP path was optimized, but still not as fast as it should be. Let's
push it even further by trimming the hot path into simple 32bit load/store
operations for buf->vid 32bpp operations.
We usually try to compile for size, not for speed. Unfortunately with the
more powerful GOP infrastructure to handle all sorts of GOP operations, we
end up slowing down our copying hot path quite a lot.
So this patch moves the 4 possible GOP operation modes into separate
functions which call a common function again. The end result of that is
more optimized code that can properly do constant propagation throughout
its switch() statements and thus removes compares in the hot path.
We optimize for size using -Os so gcc might ignore 'inline'.
Pixel conversions are called so often that we always want to inline them.
When the TPL is lowered queued events may become eligible for execution.
iPXE uses the following pattern to request event execution:
bs->RestoreTPL ( TPL_APPLICATION );
bs->RaiseTPL ( TPL_CALLBACK );
We use a timer to poll the network.
iPXE is used for booting from iSCSI drives. It has been changed to run at
TPL_CALLBACK most of the time (which is not what the UEFI spec
recommends).
By changing our timer to TPL_NOTIFY we can ensure that it is nevertheless
executed.
In the Blt service of the EFI_GRAPHICS_OUTPUT_PROTOCOL the parameter delta
is measured in bytes and not in pixels.
The coding only supports delta being a multiple of four. The UEFI
specification does not explicitly require this but as pixels have a size of
four bytes we should be able to assume four byte alignment.
The corresponding unit test is corrected, too. It can be launched with
setenv efi_selftest block image transfer
bootefi selftest
Supply a unit test for event groups.
Create multiple events in an event group. Signal each event once and check
that all events are notified once in each round.
Include libfdt.h was moved by commit b08c8c487083 ("libfdt: move headers to
<linux/libfdt.h> and <linux/libfdt_env.h>")
Fixes: e236200c7fa6 ("efi_selftest: check installation of the
device tree")
The headers are not in the correct order. Fix this. Also drop libfdt_env.h
since it is not needed.
Rebased
Using the existing predefined constants is less error prone and
makes the code easier to read.
Output the UEFI revision number in helloworld.
Provide a unit test for the EFI_SIMPLE_TEXT_INPUT_PROTOCOL.
The unicode character and the scan code are printed for text
input.
To run the test:
setenv efi_selftest text input
bootefi selftest
EFI_RESET_PLATFORM_SPECIFIC is one of the values that can be used for the
EFI service ResetSystem. The missing definition is added. The value has to
handled in efi_reset_system().
The test checks all block image transfer operations of the graphical output
protocol. An animated submarine is shown.
To run the test:
setenv efi_selftest bock image transfer
bootefi selftest
With the patch all block image transfer operations of the
EFI_GRAPHICS_OUTPUT_PROTOCOL are supported.
If an event of a group event is signaled all other events of the same
group are signaled too.
Function efi_signal_event is renamed to efi_queue_event.
A new function efi_signal_event is introduced that checks if an event
belongs to a group and than signals all events of the group.
Event group notifciation is implemented for ExitBootServices,
InstallConfigurationTable, and ResetSystem.
Event groups are used to signal multiple events at the same time.
They are identified by GUIDs. This patch provided the predefined
GUIDs of UEFI specification 2.7.
Lift the limit on the number of events by using a linked list.
This also allows to have events with type == 0.
This patch is based on Rob's patch
efi_loader: fix events
https://lists.denx.de/pipermail/u-boot/2017-October/309348.html
Suggested-by: Rob Clark <robdclark@gmail.com>
