path: root/lib
2018-07-30Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-07-25 Highlights this time: - Many small fixes to improve spec compatibility (found by SCT) - Almost enough to run with sandbox target - GetTime() improvements - Enable EFI_LOADER and HYP entry on ARMv7 with NONSEC=y
2018-07-26Merge git://git.denx.de/u-boot-dmTom Rini
2018-07-26fdt_support: make FDT_FIXUP_PARTITIONS depend on CMD_MTDPARTSMasahiro Yamada
fdt_fixup_mtdparts() calls mtdparts_init() and device_find(), which are defined in cmd/mtdparts.c The combination of FDT_FIXUP_PARTITIONS=y and CMD_MTDPARTS=n emits the following link error: common/fdt_support.c:903: undefined reference to `mtdparts_init' common/fdt_support.c:914: undefined reference to `device_find' Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-26fdt: fix fdtdec_setup_memory_banksize()Jens Wiklander
Prior to this patch is fdtdec_setup_memory_banksize() incorrectly ignoring the "status" field. This patch fixes that by testing the status with fdtdec_get_is_enabled() before using a memory node. Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-26initialize net_mode.if_typeAndrew Thomas
if_type is not correctly initialized Failure to initialize if_type means that grub2/efinet sends a bogus arp request. It therefore gets no response. On Raspberry Pi 3B+ this leads to a pause at: lan78xx_eth Waiting for PHY auto negotiation to complete....... done lan78xx_eth Waiting for PHY auto negotiation to complete....... done Signed-off-by: Andrew Thomas <andrew.thomas@oracle.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-25efi_selftest: unit test for GetTime()Heinrich Schuchardt
Provide a unit test for the GetTime() runtime service. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: support printing leading zeroesHeinrich Schuchardt
Allow specifying the precision when printing integers, e.g. efi_st_printf("%.4u-%.2u-%.2u\n", year, month, day); Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: complete implementation of GetTime()Heinrich Schuchardt
Implement the missing parts of the GetTime() runtime service. Fill seconds. Fill daylight saving time flag correctly. Provide dummy values for capabilities. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: remove unused efi_get_time_init()Heinrich Schuchardt
Remove unused function efi_get_time_init(). Initialization of the RTC has to be done in board bring up not in the EFI subsystem. There is no RTC device in the UEFI spec. The RTC is only accessed through the runtime services. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: unit test for CalculateCrc32()Heinrich Schuchardt
This unit test checks the CalculateCrc32 bootservice and checks the headers of the system table, the boot services tablle, and the runtime services table before and after ExitBootServices(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: check crc32 for InstallConfigurationTableHeinrich Schuchardt
InstallConfigurationTable() may change the number of installed configuration tables. Check the crc32 of the system table. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: update crc32 in InstallConfigurationTableHeinrich Schuchardt
If the number of installed tables is changed in InstallConfigurationTable() update the crc32 of the system table. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: correct signature of CalculateCrc32()Heinrich Schuchardt
Use const for the buffer. We are not changing the buffer. Use efi_uintn_t where prescribed by the UEFI spec. Prefer u32 over uint32_t. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: test InstallConfigurationTable()Heinrich Schuchardt
Provide a unit test for InstallConfigurationTable(). A table is installed, updated, removed. The table entry and the triggering of events is checked. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: allocate configuration table arrayHeinrich Schuchardt
The system table contains a link to the list of configurations tables. These include the device tree, SMBIOS table, and the ACPI table. This array is currently statically linked. With the patch it is allocated as EFI_RUNTIME_SERVICES_DATA. Due to the structure of the system table we cannot work with a linked list here. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: calculate crc32 for EFI tablesHeinrich Schuchardt
For the boot and runtime services tables and for the system table the crc32 has to be set in the header. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: provide firmware revisionHeinrich Schuchardt
Provide a firmware revision in the system table using the Makefile variables VERSION and PATCHLEVEL, e.g. 0x20180700 for v2018.07. Correct the type of the firmware vendor. It is a u16* pointer. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: correct headersize EFI tablesHeinrich Schuchardt
The headersize field has to be set to the size of the whole table including the header. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: specify UEFI spec revisionHeinrich Schuchardt
Both in the boot and the runtime services tables we have to specify the UEFI spec revision. The same value is already used for the system table. So let's use a common constant. In the boot services table we have to provide the header signature. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: clear screen has to reset cursor positionHeinrich Schuchardt
After clearing the screen the cursor position is row 0, column 0. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: EFI_SIMPLE_TEXT_INPUT_PROTOCOL.Reset()Heinrich Schuchardt
Implement the reset service of the EFI_SIMPLE_TEXT_INPUT_PROTOCOL. This should resolve the error reported by the SCT in Protocol/SimpleTextIn/BlackBoxTest/SimpleTextInBBTestFunction.c:193 Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: set revision in loaded image protocolHeinrich Schuchardt
The revision number has to be set in the loaded image protocol. The problem was detected by running the SCT in Protocol/LoadedImage/BlackBoxTest/LoadedImageBBTestMain.c:890 Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_driver: set DM_FLAG_NAME_ALLOCED flagHeinrich Schuchardt
Set the DM_FLAG_NAME_ALLOCED flag to avoid a memory leak when the block device is removed. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: test writing to fileHeinrich Schuchardt
Provide a unit test for writing to a FAT file system. Add some additional comments in block device unit test. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: check map_key in ExitBootServicesHeinrich Schuchardt
The UEFI spec requires that the memory map key is checked in ExitBootServices(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: check parameters of GetMemoryMapHeinrich Schuchardt
Check the parameters of boottime service GetMemoryMap(). Return EFI_INVALID_PARAMETER where required by the UEFI spec. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: check parameters in memory allocationHeinrich Schuchardt
If no pointer is provided throw an error. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: check parameters of CreateEventHeinrich Schuchardt
Rigorously check the TPL level and the event type. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: Clean up a few comments and messagesSimon Glass
Fix the 'amp' typo, expand on what 'steps' is and fix a few other minor things. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25vsprintf: Handle NULL with %pUSimon Glass
At present a NULL pointer passed to printf for a %pU argument will cause U-Boot to access memory at 0. Fix this by adding a check, and print "(null)" instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexander Graf <agraf@suse.de> [agraf: s/(null)/<NULL>/] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Expose U-Boot addresses in memory map for sandboxAlexander Graf
We currently expose host addresses in the EFI memory map. That can be bad if we ever want to use sandbox to boot strap a real kernel, because then the kernel would fetch its memory table from our host virtual address map. But to make that use case work, we would need to have full control over the address space the EFI application sees. So let's expose only U-Boot addresses to the guest until we get to the point of allocation. EFI's allocation functions are fun - they can take U-Boot addresses as input values for hints and return host addresses as allocation results through the same uint64_t * parameter. So we need to be extra careful on what to pass in when. With this patch I am successfully able to run the efi selftest suite as well as grub.efi on aarch64. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi: sandbox: Adjust memory usage for sandboxSimon Glass
With sandbox the U-Boot code is not mapped into the sandbox memory range so does not need to be excluded when allocating EFI memory. Update the EFI memory init code to take account of that. Signed-off-by: Simon Glass <sjg@chromium.org> [agraf: Remove map_sysmem() call and header reference] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Use common elf.h reloc definesAlexander Graf
Now that elf.h contains relocation defines for all architectures we care about, let's just include it unconditionally and refer to the defines. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Move to compiler based target architecture determinationAlexander Graf
Thanks to CONFIG_SANDBOX, we can not rely on config options to tell us what CPU architecture we're running on. The compiler however does know that, so let's just move the ifdefs over to compiler based defines rather than kconfig based options. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Introduce ms abi vararg helpersAlexander Graf
Varargs differ between sysv and ms abi. On x86_64 we have to follow the ms abi though, so we also need to make sure we use x86_64 varargs helpers. This patch introduces generic efi vararg helpers that adhere to the respective EFI ABI. That way we can deal with them properly from efi loader code and properly interpret variable arguments. This fixes the InstallMultipleProtocolInterfaces tests in the efi selftests on x86_64 for me. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Disable miniapps on sandboxAlexander Graf
In the sandbox environment we can not easily build efi stub binaries right now, so let's disable the respective test cases for the efi selftest suite. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: efi_allocate_pages is too restrictiveHeinrich Schuchardt
When running on the sandbox the stack is not necessarily at a higher memory address than the highest free memory. There is no reason why the checking of the highest memory address should be more restrictive for EFI_ALLOCATE_ANY_PAGES than for EFI_ALLOCATE_MAX_ADDRESS. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: use -1ULL instead] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Allow SMBIOS tables in highmemAlexander Graf
We try hard to make sure that SMBIOS tables live in the lower 32bit. However, when we can not find any space at all there, we should not error out but instead just fall back to map them in the full address space instead. This can for example happen on systems that do not have any RAM mapped in the lower 32bits of address space. In that case having any SMBIOS tables at all is better than having none. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Use compiler constants for image loaderAlexander Graf
The EFI image loader tries to determine which target architecture we're working with to only load PE binaries that match. So far this has worked based on CONFIG defines, because the target CPU was always indicated by a config define. With sandbox however, this is not longer true as all sandbox targets only encompass a single CONFIG option and so we need to use compiler defines to determine the CPU architecture. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25Revert "efi_loader: no support for ARMV7_NONSEC=y"Mark Kettenis
This reverts commit c524997acb3d322e1bbd36c06ad02ef589705e7c. Booting ARMv7 in non-secure mode using bootefi works now. Signed-off-by: Mark Kettenis <kettenis@openbsd.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: update .gitignoreHeinrich Schuchardt
The following generated files should be ignored by git: efi_miniapp_file_image_exit.h efi_miniapp_file_image_return.h *.so files are normally deleted during the build but should be ignored too. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-24hashtable: Fix length calculation in hexport_rZubair Lutfullah Kakakhel
The length returned by hexport_r has a few redundant characters. This appears as NULL characters at the end so seems harmless. Remove the surplus counts in two places totlen += strlen(ep->key) + 2; I'm guessing the +2 here is for = and sep char. But there is another totlen += 2; line that does that. size = totletn + 1; Doesn't make sense and isn't justified with any comment. Signed-off-by: Zubair Lutfullah Kakakhel <zubair@resin.io>
2018-07-23doc: Replace DocBook with sphinx-based docsMario Six
The Linux kernel moved to sphinx-based documentation and got rid of the DocBook based documentation quite a while ago. Hence, the DocBook documentation for U-Boot should be converted as well. To achieve this, import the necessary files from Linux v4.17, and convert the current DocBook documentation (three files altogether) to sphinx/reStructuredText. For now, all old DocBook documentation was merged into a single handbook, tentatively named "U-Boot Hacker Manual". For some source files, the documentation style was changed to comply with kernel-doc; no functional changes were applied. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-07-20Merge git://git.denx.de/u-boot-x86Tom Rini
2018-07-20hashtable: do not recreate whole hash table if vars are passed to himport_rQuentin Schulz
When vars are passed to the himport_r function with H_NOCLEAR flag, those vars will be overridden in the current environment and if one of those vars is not in the imported environment, it'll be deleted in the current environment whatever the flag passed to himport_r. The H_NOCLEAR flag is used to clear the whole environment whether vars are passed to the function or not. This leads to incoherent behaviour. If one passes vars to himport_r with the H_NOCLEAR flag, if a var in vars is not in the imported env, that var will be removed from the current env. If one passes vars to himport_r without the H_NOCLEAR flag, the whole environment will be removed and vars will be imported from the environment in RAM. It makes more sense to keep the variable that is in the current environment but not in the imported environment if the H_NOCLEAR flag is set and remove only that variable if the H_NOCLEAR flag is not set. Let's clear the whole environment only if H_NOCLEAR and vars are not passed to himport_r. Let's remove variables that are in the current environment but not in the imported env only if the H_NOCLEAR flag is not passed. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com>
2018-07-20efi: app: Add a sysreset driverBin Meng
This adds the DM sysreset driver for EFI application support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19lib: fdtdec: Rename routine fdtdec_setup_memory_size()Siva Durga Prasad Paladugu
This patch renames the routine fdtdec_setup_memory_size() to fdtdec_setup_mem_size_base() as it now fills the mem base as well along with size. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-07-19lib: fdtdec: Update ram_base to store ram start adddressSiva Durga Prasad Paladugu
This patch updates the ram_base to store the start address of the first bank DRAM and the use this ram_base to calculate ram_top properly. This patch fixes the erroneous calculation of ram_top incase of non zero ram start address. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-07-19xilinx: zynq: Add support to secure imagesSiva Durga Prasad Paladugu
This patch basically adds two new commands for loadig secure images. 1. zynq rsa adds support to load secure image which can be both authenticated or encrypted or both authenticated and encrypted image in xilinx bootimage(BOOT.bin) format. 2. zynq aes command adds support to decrypt and load encrypted image back to DDR as per destination address. The image has to be encrypted using xilinx bootgen tool and to get only the encrypted image from tool use -split option while invoking bootgen. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
