The UEFI specification requires that when a protocol is opened via
HandleProtocol() the agent handle is the image handle of the EFI firmware
(see chapter on EFI_BOOT_SERVICES.OpenProtocol()).
Let efi_handle_protocol() pass efi_root as agent handle to
efi_open_protocol().
The GetTime() and the SetTime() runtime services are not obligatory. So
let's make them customizable.
If SetTime() is meant to set daylight saving time it will be called with
Time.Daylight == EFI_TIME_ADJUST_DAYLIGHT | EFI_TIME_IN_DAYLIGHT.
Return 0 from GetTime() if time is not in daylight because we cannot
determine if we are in a time zone with daylight saving time.
The UEFI spec prescribes that we check that the timestamp passed to
SetTime() is checked for validity.
When uninstalling a protocol the following steps are needed:
* request all drivers to disconnect
* close protocol for all non-drivers
* check if any open instance of the protocol exists on the handle and
return EFI_ACCESS_DENIED in this case
* remove the protocol interface
By tort we tested for remaining open protocol instances already after
requesting drivers to disconnect.
With this correction the UEFI SCT II tests for UninstallProtocolInterface()
and ReinstallProtocolInterface are passed.
When trying to open a protocol exclusively attached drivers have to be
removed. This removes entries in the open protocol information linked list
over which we are looping. As additionally child controllers may have been
removed the only safe thing to do is to restart the loop over the linked
list when a driver is removed.
By observing the return code of DisconnectController() we can eliminate a
loop.
If a protocol is opened BY_DRIVER it cannot be opened by another agent
BY_DRIVER.
In LocateProtocol() implement searching by the registration key returned by
RegisterNotifyProtocol().
The code to check if a registration key is a valid key returned by
RegisterProtocolNotify() can be reused. So let us factor it out into a new
function efi_check_register_notify_event().
If a user defines BootNext but not BootOrder and loading from BootNext
fails, you will see only a message like this:
BootOrder not defined
This may confuse a user. Adding an error message will be helpful.
An example output looks like this:
=> efidebug boot add 0001 label1 scsi 0:1 "\path1\file1.efi" "--option foo"
=> efidebug boot add 0002 label2 scsi 0:1 "\path2\file2.efi" "--option bar"
=> efidebug boot add 0003 label3 scsi 0:1 "\path3\file3.efi" "--option no"
=> efidebug boot order 0001 0002
=> efidebug boot next 0003
=> bootefi bootmgr
Loading from Boot0003 'label3' failed
Loading from BootNext failed, falling back to BootOrder
Loading from Boot0001 'label1' failed
Loading from Boot0002 'label2' failed
EFI boot manager: Cannot load any image
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Adjust messages.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
When a protocol is installed the handle should be queued for the
registration key of each registered event. LocateHandle() should return the
first handle from the queue for the registration key and delete it from the
queue.
Implement the queueing.
Correct the selftest.
With the patch the UEFI SCT tests for LocateHandle() are passed without
failure.
If a variable already exists, efi_set_variable() should not change
the variable's attributes. This patch enforces it.
The current efi_st_variable() doesn't support EFI_VARIABLE_APPEND_WRITE
attiribute for now, and so should return an error.
Fix typos is commit message.
Add TODO comment.
The error here should be marked *todo*.
According to the FAT32 specification 0x7f (DEL) is not a legal character
for file names.
Since commit 226cddbe32f0 ("efi_loader: check device path in
InstallMultipleProtocolInterfaces") iPXE fails to access the network.
LocateDevicePath() returns EFI_SUCCESS even if a shorter path is found as a
partial match. It returns the remaining path. So to be sure that we found a
complete match we need to check that the remaining path refers to an end
node.
Provide debug output if a device path has already been installed.
Fixes: 226cddbe32f0 ("efi_loader: check device path in
According to the UEFI spec 2.8 the GetTime() runtime service should return
EFI_UNSUPPORTED if the real time clock is not available.
Implement the SetTime() runtime service.
Extend the real time clock selftest to check setting the clock.
U-Boot already defines the {upper,lower}_32_bits() macros that have the
same purpose. Use the existing macros instead of defining new APIs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Check the parameters against NULL.
KeyToggleState is a pointer according to UEFI spec 2.8.
Do not write to address indicated by NULL pointer.
UEFI SCT II 2.6 (2017), 3.6.5 GetNextMonotonicCount(), 5.1.5.5.1
Not checking the parameters may lead reading or writing from NULL.
Implement the parameter checks prescribed in the UEFI spec.
According to the UEFI spec InstallMultipleProtocolInterfaces() must check
if a device path has already been installed. In this case it must return
EFI_ALREADY_STARTED.
Cf. UEFI SCT II 2.6 A (2017),
3.3.16 InstallMultipleProtocolInterfaces(), 5.1.3.16.1.
In EFI 1.10 a version of the Unicode collation protocol using ISO 639-2
language codes existed. This protocol is not part of the UEFI specification
any longer. Unfortunately it is required to run the UEFI Self Certification
Test (SCT) II, version 2.6, 2017. So we implement it here for the sole
purpose of running the SCT. It can be removed once a compliant SCT is
available.
The configuration option defaults to no.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Most of Rob's original patch is already merged. Only the deprecated
protocol is missing. Rebase it and make it configurable.
Rename variables to make it clear they refer to the Unicode collation
protocol identified by the EFI_UNICODE_PROTOCOL2_GUID.
In the implementation of the device path to text protocol join adjacent
sprintf() statements.
Check buffer pointers are not NULL as required by the UEFI 2.7 spec.
Return EFI_UNSUPPORTED instead of EFI_INVALID_PARAMETER when trying to
transmit with non-zero header_size.
UEFI spec 2.7 erratum A leaves it undefined if Attributes should be set if
GetVariable() returns EFI_BUFFER_TOO_SMALL.
UEFI spec 2.8 defines that Attributes should be set if the return value is
either EFI_SUCCESS or EFI_BUFFER_TOO_SMALL.
Set Attributes if the return value is EFI_BUFFER_TOO_SMALL.
The device path to text protocol renders ACPI device nodes incorrectly.
Use capital hexadecimal numbers as shown in the UEFI spec examples.
Always output the optional UID. This matches what UEFI SCT expects and
saves us an `if`.
UEFI SCT uses this call sequence to determine the current TPL level inside
notification functions:
OldTpl = BS->RaiseTPL(TPL_HIGH_LEVEL);
BS->RestoreTPL(OldTpl);
In RestoreTPL() we trigger the notification function of queued events. If
we do not mark the event as non-queued before calling the notification
function, this results in an infinite recursive call sequence.
Mark the event as non-queued before entering the notification function.
Replace unnecessary control structures by using return statements.
If AllocatePages() is called with AllocateAddress, the UEFI spec requires
to return EFI_NOT_FOUND in case the memory page does not exist.
The UEFI SCT II 2017 spec additionally requires to return EFI_NOT_FOUND if
the page is already allocated.
Check that *Memory refers to an unallocated page.
UEFI SCT II (2017): AllocatePages(), 5.1.2.1.9 - 5.1.2.1.10
According to the UEFI AllocatePages() has to return EFI_OUT_OF_RESOURCES if
sufficient memory is not available.
Change the return value.
UEFI SCT II (2017): 3.2.1 AllocatePages(), 5.1.2.1.8
When we call FreePages() we essentially add memory to our memory map. We
shouldn't do this for memory that does not exit.
Check if the memory that is to be freed via FreePages() or FreePool() is in
our memory map and is not EFI_CONVENTIONAL_MEMORY.
This check is mandated by the UEFI specification.
Cf. UEFI SCT II (2017), 3.2.2 FreePages(), 5.1.2.1 - 5.1.2.2
According to the UEFI specification UninstallProtocolInteface() has to
return EFI_NOT_FOUND if the interface is not found.
Correct the return value.
Cf. UEFI SCT II spec (2017), 3.3.2 UninstallProtocolInterface(), 5.1.3.2.4
efi_search_protocol() already checks that the GUID matches. Don't check
a second time.
A parameter check in LocateDevicePath() does not match the requirements of
the UEFI spec.
If device is NULL, only return EFI_INVALID_PARAMETER if a matching handle
is found.
Cf. UEFI SCT II specification (2017)3.3.7 LocateDevicePath(), 5.1.3.7.3
%s/not buffer/no buffer/
The device path to text protocol is not needed for EBBR compliance. So
let's make it a customizable option.
The Unicode collation protocol is not needed for EBBR compliance. So let's
The Unicode capitalization table is only needed by this protocol. So let it
depend on the Unicode collation protocol.
No need to mention U-Boot in brief description.
Fix several typos, mention iPXE.
Use if/endif for dependencies to give structure to the configuration menu.
Sort important settings to the top.
Abbreviate the short description of EFI_LOADER_HII.
If EFI_LOADER_HII is not set, do not unnecessarily compile files for HII
protocols.
Consistently use efi_uintn_t as type of memory keys.
Reviewed-by: Alexander Graf <graf@amazon.com>
If the size of the source buffer is 0, return EFI_LOAD_ERROR.
(UEFI SCT II 2017: 3.4.1 LoadImage() - 5.1.4.1.6)
If the parent image handle does not refer to a loaded image return
EFI_INVALID_PARAMETER.
(UEFI SCT II 2017: 3.4.1 LoadImage() - 5.1.4.1.1)
Mark our root node as a loaded image to avoid an error when using it as
parent image.
HandleProtocol() and OpenProtocol() have to return EFI_UNSUPPORTED if the
protocol is not installed on the handle.
For correct indentation of messages in the UEFI API implementation use
EFI_PRINT() instead of debug().
Return EFI_INVALID_PARAMETER from CloseProtcol() if the agent handle is not
valid.
Return EFI_INVALID_PARAMETER if the optional controller handle is not
valid.
Return immediately from efi_search_obj if the handle is NULL.
