path: root/lib
2016-06-09tiny-printf: Correct the snprintf() implementationSimon Glass
This current code passes the variable arguments list to sprintf(). This is not correct. Fix it by calling _vprintf() directly. This makes firefly-rk3288 boot again. Fixes: abeb272 ("tiny-printf: Support snprintf()") Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-06Merge http://git.denx.de/u-boot-samsungTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/peach-pi_defconfig configs/peach-pit_defconfig
2016-06-06lib: make strmhz available in SPLChris Packham
When setting up a DDR controller it is useful to be able to display frequencies in a readable form. Make the strmhz() function available in SPL builds provided there is full vsprintf available. Reviewed-by: Tony O'Brien <tony.obrien@alliedtelesis.co.nz> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-06-06Remove unneeded remnants of bcopy().Robert P. J. Day
Since bcopy() is no longer used, delete all remaining references to it. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-06-06efi_loader: Add DM_VIDEO supportAlexander Graf
Some systems are starting to shift to support DM_VIDEO which exposes the frame buffer through a slightly different interface. This is a poor man's effort to support the dm video interface instead of the lcd one. We still only support a single display device. Signed-off-by: Alexander Graf <agraf@suse.de> [trini: Remove fb_size / fb_base as they were not used] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06efi_loader: Don't allocate from memory holesAlexander Graf
When a payload calls our memory allocator with the exact address hint, we happily allocate memory from completely unpopulated regions. Payloads however expect this to only succeed if they would be allocating from free conventional memory. This patch makes the logic behind those checks a bit more obvious and ensures that we always allocate from known good free conventional memory regions if we want to allocate ram. Reported-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06efi_loader: Move to normal debug infrastructureAlexander Graf
We introduced special "DEBUG_EFI" defines when the efi loader support was new. After giving it a bit of thought, turns out we really didn't have to - the normal #define DEBUG infrastructure works well enough for efi loader as well. So this patch switches to the common debug() and #define DEBUG way of printing debug information. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-06efi_loader: Add exit supportAlexander Graf
Some times you may want to exit an EFI payload again, for example to default boot into a PXE installation and decide that you would rather want to boot from the local disk instead. This patch adds exit functionality to the EFI implementation, allowing EFI payloads to exit. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-06-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2016-06-02lib: Enable private libgcc by defaultMarek Vasut
This patch decouples U-Boot binary from the toolchain on systems where private libgcc is available. Instead of pulling in functions provided by the libgcc from the toolchain, U-Boot will use it's own set of libgcc functions. These functions are usually imported from Linux kernel, which also uses it's own libgcc functions instead of the ones provided by the toolchain. This patch solves a rather common problem. The toolchain can usually generate code for many variants of target architecture and often even different endianness. The libgcc on the other hand is usually compiled for one particular configuration and the functions provided by it may or may not be suited for use in U-Boot. This can manifest in two ways, either the U-Boot fails to compile altogether and linker will complain or, in the much worse case, the resulting U-Boot will build, but will misbehave in very subtle and hard to debug ways. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-02tiny-printf: Support sprintf()Marek Vasut
Add a simple version of this function for SPL. It does not check the buffer size as this would add to the code size. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: lesne@alse-fr.com Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Sylvain Lesne <lesne@alse-fr.com> Tested-by: Sylvain Lesne <lesne@alse-fr.com>
2016-05-31mmc: tegra: add basic Tegra186 supportStephen Warren
Tegra186's MMC controller needs to be explicitly identified. Add another compatible value for it. Tegra186 will use an entirely different clock/reset control mechanism to existing chips, and will use standard clock/reset APIs rather than the existing Tegra-specific custom APIs. The driver support for that isn't ready yet, so simply disable all clock/reset usage if compiling for Tegra186. This must happen at compile time rather than run-time since the custom APIs won't even be compiled in on Tegra186. In the long term, the plan would be to convert the existing custom APIs to standard APIs and get rid of the ifdefs completely. The system's main eMMC will work without any clock/reset support, since the firmware will have already initialized the controller in order to load U-Boot. Hence the driver is useful even in this apparently crippled state. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-27Merge git://git.denx.de/u-boot-dmTom Rini
For odroid-c2 (arch-meson) for now disable designware eth as meson now needs to do some harder GPIO work. Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: lib/efi_loader/efi_disk.c Modified: configs/odroid-c2_defconfig
2016-05-27efi_loader: gop: Don't expose fb addressAlexander Graf
Recently Linux is gaining support for efifb on AArch64 and that support actually tries to make use of the frame buffer address we expose to it via gop. While this wouldn't be bad in theory, in practice it means a few bad things 1) We expose 16bit frame buffers as 32bit today 2) Linux can't deal with overlapping non-PCI regions between efifb and a different frame buffer driver For now, let's just disable exposure of the frame buffer address. Most OSs that get booted will have a native driver for the GPU anyway. Signed-off-by: Alexander Graf <agraf@suse.de> [trini: Remove line_len entirely] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27efi_loader: Clean up system table on exitAlexander Graf
We put the system table into our runtime services data section so that payloads may still access it after exit_boot_services. However, most fields in it are quite useless once we're in that state, so let's just patch them out. With this patch we don't get spurious warnings when running EFI binaries anymore. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27efi_loader: Add bounce buffer supportAlexander Graf
Some hardware that is supported by U-Boot can not handle DMA above 32bits. For these systems, we need to come up with a way to expose the disk interface in a safe way. This patch implements EFI specific bounce buffers. For non-EFI cases, this apparently was no issue so far, since we can just define our environment variables conveniently. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27dm: efi: Update for CONFIG_BLKSimon Glass
This code does not currently build with driver model enabled for block devices. Update it to correct this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-05-27efi_loader: Add network access supportAlexander Graf
We can now successfully boot EFI applications from disk, but users may want to also run them from a PXE setup. This patch implements rudimentary network support, allowing a payload to send and receive network packets. With this patch, I was able to successfully run grub2 with network access inside of QEMU's -M xlnx-ep108. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-26tiny-printf: Support snprintf()Simon Glass
Add a simple version of this function for SPL. It does not check the buffer size as this would add to the code size. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-05-26tiny-printf: Tidy up a few nitsSimon Glass
- Rename 'w' to 'width' to make it more obvious what it is used for - Use bool and int types instead of char to avoid register-masking on 32-bit machines Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-05-25exynos: Allow tizen to be built without an LCDSimon Glass
This file currently requires an LCD. Adjust it to work without one. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-05-17dm: part: Drop the block_drvr tableSimon Glass
This is not needed since we can use the functions provided by the legacy block device support. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-04-18efi_loader: Handle memory overflowsAndreas Färber
jetson-tk1 has 2 GB of RAM at 0x80000000, causing gd->ram_top to be zero. Handle this by either avoiding ram_top or by using the same type as ram_top to reverse the overflow effect. Cc: Alexander Graf <agraf@suse.de> Signed-off-by: Andreas Färber <afaerber@suse.de> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-04-18gunzip.c: use block layer for writesEric Nelson
Call blk_dwrite to ensure that the block cache is notified if enabled and remove build breakage when CONFIG_BLK is enabled. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2016-04-18efi_loader: Expose ascending efi memory mapAlexander Graf
The EFI memory map does not need to be in a strict order, but 32bit grub2 does expect it to be ascending. If it's not, it may try to allocate memory inside the U-Boot data memory region. We already sort the memory map in descending order, so let's just reverse it when we pass it to a payload. Signed-off-by: Alexander Graf <agraf@suse.de> Tested-by: Andreas Färber <afaerber@suse.de>
2016-04-18efi_loader: Always flush in cache line size granularityAlexander Graf
The cache line flush helpers only work properly when they get aligned start and end addresses. Round our flush range to cache line size. It's safe because we're guaranteed to flush within a single page which has the same cache attributes. Reported-by: Marek Vasut <marex@denx.de> Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Andreas Färber <afaerber@suse.de> Tested-by: Andreas Färber <afaerber@suse.de>
2016-04-18efi_loader: Increase path string to 32 charactersAlexander Graf
Whenever we want to tell our payload about a path, we limit ourselves to a reasonable amount of characters. So far we only passed in device names - exceeding 16 chars was unlikely there. However by now we also pass real file path information, so let's increase the limit to 32 characters. That way common paths like "boot/efi/bootaa64.efi" fit just fine. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18efi_loader: Add el torito supportAlexander Graf
When loading an el torito image, uEFI exposes said image as a raw block device to the payload. Let's do the same by creating new block devices with added offsets for the respective el torito partitions. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-18efi_loader: Split drive add into functionAlexander Graf
The snippet of code to add a drive to our drive list needs to get called from 2 places in the future. Split it into a separate function. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-11lib/crc8: Add crc start valueStefan Roese
To make the usage of this function more flexible, lets add the CRC start value as parameter to this function. This way it can be used by other functions requiring different start values than 0 as well. For non-zero CRC start values to work, I've reworked the function a bit. The new implementation is copied from the Linux version in drivers/i2c/i2c-core.c / i2c_smbus_pec(). Which supports non-zero CRC stating values. I've double-checked that the results for zero starting values are identical to the results from the original version of this function. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01efi_loader: Always allocate the highest available addressAlexander Graf
Some EFI applications (grub2) expect that an allocation always returns the highest available memory address for the given size. Without this, we may run into situations where the initrd gets allocated at a lower address than the kernel. This patch fixes booting in such situations for me. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-04-01lib/physmem.c: Switch to __weak for arch_phys_memsetTom Rini
We normally use __weak rather than calling it out directly as an alias. Update this function to the normal method. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-01cosmetic: Fix typos "privide"Masahiro Yamada
2016-03-27efi_loader: Fix some entry/exit pointsAlexander Graf
When switching between EFI context and U-Boot context we need to swap the register that "gd" resides in. Some functions slipped through here, with efi_allocate_pool / efi_free_pool not doing the switch correctly and efi_return_handle switching too often. Fix them all up to make sure we always have consistent register state. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-27efi_stub: Move carriage return before line feed in putc()Bin Meng
A carriage return needs to execute before a line feed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27efi_loader: Add GOP supportAlexander Graf
The EFI standard defines a simple boot protocol that an EFI payload can use to access video output. This patch adds support to expose exactly that one (and the mode already in use) as possible graphical configuration to an EFI payload. With this, I can successfully run grub2 with graphical output. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-17cmd_dhry.c: Use lldiv for vax_mips calculation as wellTom Rini
Since dhry_per_sec is a u64 we must also use lldiv here when working with it. Otherwise: ../lib/dhry/cmd_dhry.c:(.text.do_dhry+0xd8): undefined reference to `__udivdi3' On some platforms. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-17x86: dts: Drop memory SPD compatible stringSimon Glass
This is not needed now that the memory controller driver has the SPD data in its own node. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17dhry: Correct dhrystone calculation for fast machinesSimon Glass
At present samus reports about 5600 DMIPS. With the default iteration count this is OK, but if 10 million runs are performed it overflows. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-15efi_loader: Pass proper device path in on bootAlexander Graf
EFI payloads can query for the device they were booted from. Because we have a disconnect between loading binaries and running binaries, we passed in a dummy device path so far. Unfortunately that breaks grub2's logic to find its configuration file from the same device it was booted from. This patch adds logic to have the "load" command call into our efi code to set the device path to the one we last loaded a binary from. With this grub2 properly detects where we got booted from and can find its configuration file, even when searching by-partition. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15efi_loader: hook up in build environmentAlexander Graf
Now that we have all the bits and pieces ready for EFI payload loading support, hook them up in Makefiles and KConfigs so that we can build. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [trini: Enable only when we of OF_LIBFDT, disable on kwb and colibri_pxa270] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15efi_loader: Implement memory allocation and mapAlexander Graf
The EFI loader needs to maintain views of memory - general system memory windows as well as used locations inside those and potential runtime service MMIO windows. To manage all of these, add a few helpers that maintain an internal representation of the map the similar to how the EFI API later on reports it to the application. For allocations, the scheme is very simple. We basically allow allocations to replace chunks of previously done maps, so that a new LOADER_DATA allocation for example can remove a piece of the RAM map. When no specific address is given, we just take the highest possible address in the lowest RAM map that fits the allocation size. Signed-off-by: Alexander Graf <agraf@suse.de> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add disk interfacesAlexander Graf
A EFI applications usually want to access storage devices to load data from. This patch adds support for EFI disk interfaces. It loops through all block storage interfaces known to U-Boot and creates an EFI object for each existing one. EFI applications can then through these objects call U-Boot's read and write functions. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [trini: Update for various DM changes since posting] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15efi_loader: Add runtime servicesAlexander Graf
After booting has finished, EFI allows firmware to still interact with the OS using the "runtime services". These callbacks live in a separate address space, since they are available long after U-Boot has been overwritten by the OS. This patch adds enough framework for arbitrary code inside of U-Boot to become a runtime service with the right section attributes set. For now, we don't make use of it yet though. We could maybe in the future map U-boot environment variables to EFI variables here. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add console interfaceAlexander Graf
One of the basic EFI interfaces is the console interface. Using it an EFI application can interface with the user. This patch implements an EFI console interface using getc() and putc(). Today, we only implement text based consoles. We also convert the EFI Unicode characters to UTF-8 on the fly, hoping that everyone managed to jump on the train by now. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add boot time servicesAlexander Graf
When an EFI application runs, it has access to a few descriptor and callback tables to instruct the EFI compliant firmware to do things for it. The bulk of those interfaces are "boot time services". They handle all object management, and memory allocation. This patch adds support for the boot time services and also exposes a system table, which is the point of entry descriptor table for EFI payloads. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-15efi_loader: Add PE image loaderAlexander Graf
EFI uses the PE binary format for its application images. Add support to EFI PE binaries as well as all necessary bits for the "EFI image loader" interfaces. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-14Merge git://git.denx.de/u-boot-dmTom Rini
