path: root/lib
2020-02-05dm: pci: Update a few more interfaces for const udevice *Simon Glass
Tidy up a few places where const * should be used. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-30libfdt: Revert 6dcb8ba4 from upstream libfdtTom Rini
In upstream libfdt, 6dcb8ba4 "libfdt: Add helpers for accessing unaligned words" introduced changes to support unaligned reads for ARM platforms and 11738cf01f15 "libfdt: Don't use memcpy to handle unaligned reads on ARM" improved the performance of these helpers. In practice however, this only occurs when the user has forced the device tree to be placed in memory in a non-aligned way, which in turn violates both our rules and the Linux Kernel rules for how things must reside in memory to function. This "in practice" part is important as handling these other cases adds visible (1 second or more) delay to boot in what would be considered the fast path of the code. Cc: Patrice CHOTARD <patrice.chotard@st.com> Cc: Patrick DELAUNAY <patrick.delaunay@st.com> Link: https://www.spinics.net/lists/devicetree-compiler/msg02972.html Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Patrice Chotard <patrice.chotard@st.com>
2020-01-30optee: Replace uninitialized return variable by proper one.Christoph Müllner
As hinted by GCC 9, there is a return statement that returns an uninitialized variable in optee_copy_firmware_node(). This patch addresses this. Signed-off-by: Christoph Müllner <christoph.muellner@theobroma-systems.com> Reviewed-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
2020-01-25lib: Kconfig dependencies for pseudo-random libraryHeinrich Schuchardt
drivers/rng/sandbox_rng.c requires rand() to be defined but configuration option CONFIG_CONFIG_LIB_RAND selected in drivers/rng/Kconfig does not exist. test/lib/test_aes.c requires rand() to be defined. Fix the selection criteria for choice "Pseudo-random library support type". Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-25lib: rsa: consider CONFIG_SPL_RSAHeinrich Schuchardt
CONFIG_SPL_RSA is meant to control if lib/rsa/* is used for SPL. Adjust lib/Makefile to consider this setting. This was correctly setup with commit 51c14cd128f4 ("verified-boot: Minimal support for booting U-Boot proper from SPL") and got lost with commit 089df18bfe9d ("lib: move hash CONFIG options to Kconfig"). Fixes: 089df18bfe9d ("lib: move hash CONFIG options to Kconfig") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-22trace: provide Sphinx style commentsHeinrich Schuchardt
Correct some function comments. Convert to Sphinx style. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-22lib: ignore oid_registry_data.c fileDario Binacchi
The file is generated by scripts/build_OID_registry based on the include/linux/oid_registry.h file. Signed-off-by: Dario Binacchi <dariobin@libero.it>
2020-01-17common: Move and rename CONFIG_SYS_SUPPORT_64BIT_DATASimon Glass
This is not really a CONFIG since it is not intended to be set by boards. Move it into the compiler header with other similar defines, and rename it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move RAM-sizing functions to init.hSimon Glass
These functions relate to memory init so move them into the init header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move the image globals into image.hSimon Glass
These three globals relate to image handling. Move them to the image header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17u-boot: fit: add support to decrypt fit with aesPhilippe Reynes
This commit add to u-boot the support to decrypt fit image encrypted with aes. The FIT image contains the key name and the IV name. Then u-boot look for the key and IV in his device tree and decrypt images before moving to the next stage. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-17mkimage: fit: add support to encrypt image with aesPhilippe Reynes
This commit add the support of encrypting image with aes in mkimage. To enable the ciphering, a node cipher with a reference to a key and IV (Initialization Vector) must be added to the its file. Then mkimage add the encrypted image to the FIT and add the key and IV to the u-boot device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-17aes: add support of aes192 and aes256Philippe Reynes
Until now, we only support aes128. This commit add the support of aes192 and aes256. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-17aes: add a define for the size of a blockPhilippe Reynes
In the code, we use the size of the key for the size of the block. It's true when the key is 128 bits, but it become false for key of 192 bits and 256 bits. So to prepare the support of aes192 and 256, we introduce a constant for the iaes block size. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-15efi_loader: imply VIDEO_ANSIHeinrich Schuchardt
UEFI programs like GRUB make change terminal colors which requires support for ANSI escape sequences. Let CONFIG_EFI_LOADER=y imply CONFIG_VIDEO_ANSI. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-15efi_driver: debug output efi_uc_start, efi_uc_stopHeinrich Schuchardt
Use the correct printf codes for the debug output in efi_uc_start() and efi_uc_stop(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-15efi_driver: fix efi_uc_stop()Heinrich Schuchardt
Use the correct protocol in efi_uc_stop() when detaching the driver from the controller. Change the block IO unit test for the block device driver to throw an error instead of a todo if teardown fails. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-15efi_selftest: enable CONFIG_CMD_POWEROFFHeinrich Schuchardt
For automating testing we should be able to power off the test system. The implementation of EFI_RESET_SHUTDOWN requires the do_poweroff() function which is only available if CONFIG_CMD_POWEROFF=y. Enable CONFIG_CMD_POWEROFF if PSCI reset is available. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-15efi_loader: describe returning of controlHeinrich Schuchardt
Provide a sober description of how control can be returned by a UEFI binary. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-15efi_loader: document functions in efi_rng.cHeinrich Schuchardt
Add the missing Sphinx documentation. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_selftest: unit test for EFI_RNG_PROTOCOLHeinrich Schuchardt
Provide a unit test for the EFI_RNG_PROTOCOL. The list of algorithms is read. Two random numbers are generated. The test checks that the two numbers differ. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_rng_protocol: Install the efi_rng_protocol on the root nodeSughosh Ganu
Install the EFI_RNG_PROTOCOL implementation for it's subsequent use by the kernel for features like kaslr. Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi: qemu: arm64: Add efi_rng_protocol implementation for the platformSughosh Ganu
Add support for the EFI_RNG_PROTOCOL routines for the qemu arm64 platform. EFI_RNG_PROTOCOL is an uefi boottime service which is invoked by the efi stub in the kernel for getting random seed for kaslr. The routines are platform specific, and use the virtio-rng device on the platform to get random data. The feature can be enabled through the following config CONFIG_EFI_RNG_PROTOCOL Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Changed SPDX header to use /* instead of //. Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: Add guidcpy functionSughosh Ganu
Add guidcpy function to copy the source guid to the destination guid. Use this function instead of memcpy for copying to the destination guid. Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Use void * instead of efi_guid_t * for arguments to allow copying unaligned GUIDs. The GUIDs of configuration tables are __packed. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: __cyg_profile_func_enter/_exitHeinrich Schuchardt
U-Boot can be compiled with function tracing enabled. When compiling with FTRACE __cyg_profile_func_enter() is called when a function is entered and __cyg_profile_func_exit() when the function is left. To avoid a crash we have to define these function for the free-standing UEFI binaries. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: clear screen should move cursor to homeHeinrich Schuchardt
On a VT100 terminal <ESC>[2J should be enough to both clear the whole screen and set the cursor to position (1, 1). But the Linux console does not behave like this. So send an extra <ESC>[H. For reference see the console_codes(4) man page. Add a function description. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: git ignore helloworld_efi.SHeinrich Schuchardt
Add *.S to .gitignore. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_selftest: Update .gitignoreSughosh Ganu
Add the following file to .gitignore efi_miniapp_file_image_exception.h Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Use efi_miniapp_*.h instead of file enumeration. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: adjust file system infoHeinrich Schuchardt
When the GetInfo() method of the EFI_FILE_PROTOCOL is called to retrieve the file system info we claim that the volume is read only and has no free space. This leads to failures in programs that check this information before writing to the volume like SCT's InstallSct.efi. Currently there is no function to determine these parameters in U-Boot. So let's return optimistic values: Return that the volume is writable. Return the volume size as free space. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-07efi_loader: imply USB_KEYBOARD_FN_KEYSHeinrich Schuchardt
UEFI applications like GRUB and SCT assume that function keys are enabled on the keyboard. Let EFI_LOADER imply USB_KEYBOARD_FN_KEYS. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-15x86: timer: use a timer base of 0Simon Glass
On x86 platforms the timer is reset to 0 when the SoC is reset. Having this as the timer base is useful since it provides an indication of how long it takes before U-Boot is running. When U-Boot sets the timer base to something else, time is lost and we no-longer have an accurate account of the time since reset. This particularly affects bootstage. Change the default to not read the timer base, leaving it at 0. Add an option for when U-Boot is the secondary bootloader. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15net: Move the checksum functions to lib/Simon Glass
These functions are used by code outside the network support, so move them to lib/ to be more accessible. Without this, the functions are only accessible in SPL/TPL only if CONFIG_SPL/TPL_NET are defined. Many boards do not enable those option but still want to do checksums in this format. Fix up a few code-style nits while we are here. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15binman: Add a library to access binman entriesSimon Glass
SPL and TPL can access information about binman entries using link-time symbols but this is not available in U-Boot proper. Of course it could be made available, but the intention is to just read the device tree. Add support for this, so that U-Boot can locate entries. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-09lib: Always build support for formatting MAC and IP addressJoe Hershberger
Even if not communicating over the network in U-Boot, code may be manipulating and storing IP or MAC addresses to pass to Linux, etc. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2019-12-09net: Always build the string_to_enetaddr() helperJoe Hershberger
Part of the env cleanup moved this out of the environment code and into the net code. However, this helper is sometimes needed even when the net stack isn't included. Move the helper to lib/net_utils.c like it's similarly-purposed string_to_ip(). Also rename the moved function to similar naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Ondrej Jirman <megous@megous.com>
2019-12-06lib: crypto: add pkcs7 message parserAKASHI Takahiro
Imported from linux kernel v5.3: pkcs7.asn1 without changes pkcs7.h with changes marked as __UBOOT__ pkcs7_parser.h without changes pkcs7_parser.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: crypto: add x509 parserAKASHI Takahiro
Imported from linux kernel v5.3: x509.asn1 without changes x509_akid.asn1 without changes x509_parser.h without changes x509_cert_parser.c with changes marked as __UBOOT__ x509_public_key.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: crypto: add rsa public key parserAKASHI Takahiro
Imported from linux kernel v5.3: rsapubkey.asn1 without changes rsa.h without changes rsa_helper.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: crypto: add public key utilityAKASHI Takahiro
Imported from linux kernel v5.3: asymmetric-type.h with changes marked as __UBOOT__ asymmetric_type.c with changes marked as __UBOOT__ public_key.h with changes marked as __UBOOT__ public_key.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: add oid registry utilityAKASHI Takahiro
Imported from linux kernel v5.3: build_OID_registry without changes oid_registry.h without changes oid_registry.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: add asn1 decoderAKASHI Takahiro
Imported from linux kernel v5.3: lib/asn1_decoder.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06cmd: add asn1_compilerAKASHI Takahiro
Imported from linux kernel v5.3: asn1.h without changes asn1_ber_bytecode.h without changes asn1_decoder.h without changes asn1_compiler.c without changes This host command will be used to create a ASN1 parser, for example, for pkcs7 messages or x509 certificates. More specifically, it will generate *byte code* which will be interpreted by asn1 decoder library. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-06lib: add mktime64() for linux compatibilityAKASHI Takahiro
This function will be used in lib/crypto/x509_cert_parser.c, which will also be imported from linux code in a later commit. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06rtc: move date.c from drivers/rtc/ to lib/AKASHI Takahiro
In the next commit, rtc_mktime(), for compatibility with linux, will be implemented using rtc_mktime(), which is no longer drivers/rtc specific. So move this file under lib/. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06linux_compat: move kmemdup() from ubifs.c to linux_compat.cAKASHI Takahiro
linux_compat.c is the best place for kmemdup(), which is currenly used only in ubifs.c, but will also be used when other kernel files (in my case, lib/crypto/x509_cert_parser.c and pkcs7_parser.c) will be imported. So just move it. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-03Kconfig: disambiguate config names for tiny printfThomas Hebb
27084c03d36a ("spl: Allow tiny printf() to be controlled in SPL and TPL") split this option in two for TPL and SPL, but didn't change the Kconfig names, making them hard to set quickly. Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
2019-12-02common: Move board_get_usable_ram_top() out of common.hSimon Glass
Move this function into init.h which seems to be designed for this sort of thing. Also update the header to declare struct global_data so that it can be included without global_data.h being needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
