Add this dependency to avoid a build error if FIT_SIGNATURE is not
enabled.
This should use a const pointer for the input stream. Fix this and also
add a proper comment.
We don't use an appended tree for sandbox and the required symbols are
not present. Add a condition to avoid a build error.
This may have different settings for SPL and TPL. Correct the condition.
If the buffer is empty and not allocated, then abuf_realloc() tries to
copy invalid data. This happens because an incorrect change to use
memdup() was added after the original code was written.
This commit adds the option SPL_RSA_VERIFY_WITH_PKEY.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
This commit adds the options:
- SPL_ASYMMETRIC_KEY_TYPE
- SPL_ASYMMETRIC_PUBLIC_KEY_SUBTYPE
- SPL_RSA_PUBLIC_KEY_PARSER
- SPL_ASN1_DECODER
- SPL_OID_REGISTRY
Enhance the help for the config OID_REGISTRY.
Enhance the help for configs ASN1_COMPILER
and ASN1_decoder.
It seems a copy'n'paste typo when tool had been introduced.
It has never had the 'exit' suffix in the file name. Hence,
the custom CFLAGS never been applied and, for example, BFD
linker complains:
LD lib/efi_loader/initrddump_efi.so
ld.bfd: lib/efi_loader/initrddump.o: warning: relocation in read-only section `.text.efi_main'
ld.bfd: warning: creating DT_TEXTREL in a shared object
Remove wrong 'exit' suffix from the custom CFLAGS variable.
Fixes: 65ab48d69ddb ("efi_selftest: provide initrddump test tool")
Fixes: 9c045a49a9c9 ("efi_loader: move dtbdump.c, initrddump.c to lib/efi_loader")
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Drop the Kconfigs which are not used and all references to them. In
particular, this drops CONFIG_VIDEO to avoid confusion and allow us to
eventually rename CONFIG_DM_VIDEO to CONFIG_VIDEO.
Also drop the prototype for video_get_info_str() which is no-longer used.
Acked-by: Jason Liu <jason.hui.liu@nxp.com>
Prepare v2022.04-rc5
Up to now the initrddump.efi application has drained the input after
showing the prompt. This works for humans but leads to problems when
automating testing. If the input is drained, this should be done before
showing the prompt.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
initrddump.efi uses colored output and clear the screen. This is not
helpful for integration into Python tests. Allow specifying 'nocolor' in
the load option data to suppress color output and clearing the screen.
%s/devie-path/device-path/
Reported-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
The tools dtbdump.efi and initrddump.efi are useful for Python testing even
if CONFIG_EFI_SELFTEST=n.
Don't clear the screen as it is incompatible with Python testing.
The block IO protocol may be installed on any handle. We should make
no assumption about the structure the handle points to.
efi_disk_is_system_part() makes an illegal widening cast from a handle
to a struct efi_disk_obj. Remove the function.
Fixes: Fixes: 41fd506842c2 ("efi_loader: disk: add efi_disk_is_system_part()")
The boot manager must support loading from boot options using a short-form
device-path, e.g. one where the first element is a hard drive media path.
See '3.1.2 Load Options Processing' in UEFI specification version 2.9.
Fixes: 0e074d12393b ("efi_loader: carve out efi_load_image_from_file()")
Let function efi_dp_find_obj() additionally check if a given protocol is
installed on the handle relating to the device-path.
efi_dp_find_obj() should not return any handle with a partially matching
device path but the handle with the maximum matching device path.
Rename function shorten_path() to efi_dp_shorten() and export it.
Starting UEFI Spec 2.8 we must fill in the variable attributes when
GetVariable() returns EFI_BUFFER_TOO_SMALL and Attributes is non-NULL.
This code was written with 2.7 in mind so let's move the code around a
bit and fill in the attributes EFI_BUFFER_TOO_SMALL is returned
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Update the LZ4 compression module based on LZ4 v1.8.3 in order to
use the newest LZ4_decompress_safe_partial() which can now decode
exactly the nb of bytes requested.
Signed-off-by: Huang Jianan <jnhuang95@gmail.com>
InstallProtocolInterface() is called with a pointer to the protocol GUID.
There is not guarantee that the memory used by the caller for the protocol
GUID stays allocated. To play it safe the GUID should be copied to U-Boot's
internal structures.
Reported-by: Joerie de Gram <j.de.gram@gmail.com>
Since OpenSSL 1.1.0, EVP_MD_CTX_create() is EVP_MD_CTX_new()
EVP_MD_CTX_destroy() is EVP_MD_CTX_free()
EVP_MD_CTX_init() is EVP_MD_CTX_reset()
As there's no need to reset a newly created EVP_MD_CTX, moreover
EVP_DigestSignInit() does the reset, thus call to EVP_MD_CTX_init()
can be dropped.
As there's no need to reset an EVP_MD_CTX before it's destroyed,
as it will be reset by EVP_MD_CTX_free(), call to EVP_MD_CTX_reset()
is not needed and can be dropped.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
UEFI specification requires that 5 minutes watchdog timer is
armed before the firmware's boot manager invokes an EFI boot option.
This watchdog timer is updated as follows, according to the
UEFI specification.
1) The EFI Image may reset or disable the watchdog timer as needed.
2) If control is returned to the firmware's boot manager,
the watchdog timer must be disabled.
3) On successful completion of EFI_BOOT_SERVICES.ExitBootServices()
the watchdog timer is disabled.
1) is up to the EFI image, and 3) is already implemented in U-Boot.
This patch implements 2), the watchdog is disabled when control is
returned to U-Boot.
In addition, current implementation arms the EFI watchdog at only
the first "bootefi" invocation. The EFI watchdog must be armed
in every EFI boot option invocation.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Add a cold reset soon after processing capsule update on disk.
This is required in UEFI specification 2.9 Section 8.5.5
"Delivery of Capsules via file on Mass Storage device" as;
In all cases that a capsule is identified for processing the system is
restarted after capsule processing is completed.
This also reports the result of each capsule update so that the user can
notice that the capsule update has been succeeded or not from console log.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Since the efi_update_capsule() represents the UpdateCapsule() runtime
service, it has to handle the capsule flags and update ESRT. However
the capsule-on-disk doesn't need to care about such things.
Thus, the capsule-on-disk should use the efi_capsule_update_firmware()
directly instead of calling efi_update_capsule().
This means the roles of the efi_update_capsule() and capsule-on-disk
are different. We have to keep the efi_update_capsule() for providing
runtime service API at boot time.
Suggested-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
The general rule of accepting or rejecting an image is
1. Is the sha256 of the image in dbx
2. Is the image signed with a certificate that's found in db and
not in dbx
3. The image carries a cert which is signed by a cert in db (and
not in dbx) and the image can be verified against the former
4. Is the sha256 of the image in db
For example SHIM is signed by "CN=Microsoft Windows UEFI Driver Publisher",
which is issued by "CN=Microsoft Corporation UEFI CA 2011", which in it's
turn is issued by "CN=Microsoft Corporation Third Party Marketplace Root".
The latter is a self-signed CA certificate and with our current implementation
allows shim to execute if we insert it in db.
However it's the CA cert in the middle of the chain which usually ends up
in the system's db. pkcs7_verify_one() might or might not return the root
certificate for a given chain. But when verifying executables in UEFI, the
trust anchor can be in the middle of the chain, as long as that certificate
is present in db. Currently we only allow this check on self-signed
certificates, so let's remove that check and allow all certs to try a
match an entry in db.
Open questions:
- Does this break any aspect of variable authentication since
efi_signature_verify() is used on those as well?
The EFI spec allows for images to carry multiple signatures. Currently
we don't adhere to the verification process for such images.
The spec says:
"Multiple signatures are allowed to exist in the binary's certificate
table (as per PE/COFF Section "Attribute Certificate Table"). Only one
hash or signature is required to be present in db in order to pass
validation, so long as neither the SHA-256 hash of the binary nor any
present signature is reflected in dbx."
With our current implementation signing the image with two certificates
and inserting both of them in db and one of them dbx doesn't always reject
the image. The rejection depends on the order that the image was signed
and the order the certificates are read (and checked) in db.
While at it move the sha256 hash verification outside the signature
checking loop, since it only needs to run once per image and get simplify
the logic for authenticating an unsigned imahe using sha256 hashes.
MCFG tables are used on multiple arches. Move to common ACPI lib.
Signed-off-by: Moritz Fischer <moritzf@google.com>
Use sizeof(*mcfg) instead of sizeof(*header)
When we have the block descriptor we can simply access the device. Drop
the unnecessary function call.
Use this function rather than following the pointers, since it is there
for this purpose.
Add the uclass name to the debug call at the end of dp_fill() since it is
quite useful.
When loading an EFI binary via the UART we assign a UART device path to it.
But we lack a handle with that device path.
The UEFI specification concerning Uart() device path nodes has been
clarified:
Parity and stop bits can either both use keywords or both use
numbers but numbers and keywords should not be mixed.
Let's go for keywords as this is what EDK II does. For illegal
values fall back to numbers.
For printing an unsigned value we should use %u and not %d.
efi_uintnt_t is an unsigned type. We should avoid showing negative numbers.
The printing of a file path node must properly handle:
* odd length of the device path node
* UTF-16 character only partially contained in device path node
* buffer overflow due to very long file path
snprintf() must return the required buffer length.
The test for the RISCV_EFI_BOOT_PROTOCOL retrieves the boot hart id via the
protocol and compares it to the value of the boot hart id in the device
tree. The boot hart id is already retrieved from the device tree in the FDT
test.
Merge the two tests to avoid code duplication.
Add a test for the RISCV_EFI_BOOT_PROTOCOL.
Signed-off-by: Sunil V L <sunilvl@ventanamicro.com>
At present we use wide characters for Unicode but this is not necessary.
Change the code to use the 'u' literal instead. This helps to fix build
warnings for sandbox on the Raspberry Pi.
At present we use wide characters for unicode but this is not necessary.
warnings for sandbox on rpi.
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2022-04-rc1-3
Documentation:
* update Nokia RX-51 documentation and move it to rst
* describe boot switch settings for HiFive Unmatched board
UEFI:
* fix the checking of images hashes and signatures
* provide the RISCV_EFI_BOOT_PROTOCOL
We don't have to recalculate the image hash every time we check against a
new db/dbx entry. So let's add a flag forcing it to run once since we only
support sha256 hashes
Suggested-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
A mix of signatures and hashes in db doesn't always work as intended.
Currently if the digest algorithm is not explicitly set to sha256 we
stop walking the security database and reject the image.
That's problematic in case we find and try to check a signature before
inspecting the sha256 hash. If the image is unsigned we will reject it
even if the digest matches.
Since we no longer reject the image on unknown algorithms add an explicit
check and reject the image if any other hash algorithm apart from sha256
is detected on dbx.
On RISC-V a new UEFI protocol has been introduced. Support printing
its GUID using %pUs.
This adds support for new RISCV_EFI_BOOT_PROTOCOL to
communicate the boot hart ID to bootloader/kernel on RISC-V
UEFI platforms.
The specification of the protocol is hosted at:
https://github.com/riscv-non-isa/riscv-uefi
