path: root/lib/zlib
2020-04-27lib: zlib: fix formatting, referenceHeinrich Schuchardt
Provide a valid reference for the deflate format. Reformat the ALGORITHM and REFERENCES comments. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-09-11Move malloc_cache_aligned() to its own headerSimon Glass
At present malloc.h is included everywhere since it recently was added to common.h in this commit: 4519668 mtd/nand/ubi: assortment of alignment fixes This seems wasteful and unnecessary. We have been trying to trim down common.h and put separate functions into separate header files and that change goes in the opposite direction. Move malloc_cache_aligned() to a new header so that this can be avoided. The header would perhaps be better named as alignmem.h but it needs to be included after common.h and people might be confused by this. With the name memalign.h it fits nicely after malloc() in most cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-12-08Replace <compiler.h> with <linux/compiler.h>Masahiro Yamada
Including <linux/compiler.h> is enough for general use. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17lib: descend into sub directories only when it is necessaryMasahiro Yamada
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2012-11-04lib/zlib: sparse fixesKim Phillips
define Z_NULL to (void *)0 include/u-boot/zlib.h to get rid of most of the NULL pointer warnings. inflate.c:942:1: warning: non-ANSI definition of function 'inflateEnd' inflate.c:9:1: warning: non-ANSI definition of function 'inflateReset' inflate.c:12:17: warning: Using plain integer as NULL pointer inflate.c:12:42: warning: Using plain integer as NULL pointer inflate.c:15:17: warning: Using plain integer as NULL pointer inflate.c:21:19: warning: Using plain integer as NULL pointer inflate.c:35:1: warning: non-ANSI definition of function 'inflateInit2_' inflate.c:38:20: warning: Using plain integer as NULL pointer inflate.c:41:17: warning: Using plain integer as NULL pointer inflate.c:42:17: warning: Using plain integer as NULL pointer inflate.c:50:18: warning: Using plain integer as NULL pointer inflate.c:65:23: warning: Using plain integer as NULL pointer inflate.c:69:21: warning: Using plain integer as NULL pointer inflate.c:78:1: warning: non-ANSI definition of function 'inflateInit_' inflate.c:86:1: warning: non-ANSI definition of function 'fixedtables' inflate.c:108:26: warning: Using plain integer as NULL pointer inflate.c:109:1: warning: non-ANSI definition of function 'updatewindow' inflate.c:112:30: warning: Using plain integer as NULL pointer inflate.c:339:1: warning: non-ANSI definition of function 'inflate' inflate.c:349:17: warning: Using plain integer as NULL pointer inflate.c:349:42: warning: Using plain integer as NULL pointer inflate.c:350:27: warning: Using plain integer as NULL pointer inflate.c:369:42: warning: Using plain integer as NULL pointer inflate.c:376:32: warning: Using plain integer as NULL pointer inflate.c:401:54: warning: Using plain integer as NULL pointer inflate.c:419:32: warning: Using plain integer as NULL pointer inflate.c:426:32: warning: Using plain integer as NULL pointer inflate.c:433:32: warning: Using plain integer as NULL pointer inflate.c:444:36: warning: Using plain integer as NULL pointer inflate.c:449:37: warning: Using plain integer as NULL pointer inflate.c:450:38: warning: Using plain integer as NULL pointer inflate.c:457:40: warning: Using plain integer as NULL pointer inflate.c:458:47: warning: Using plain integer as NULL pointer inflate.c:480:40: warning: Using plain integer as NULL pointer inflate.c:481:50: warning: Using plain integer as NULL pointer inflate.c:491:37: warning: Using plain integer as NULL pointer inflate.c:492:37: warning: Using plain integer as NULL pointer inflate.c:501:40: warning: Using plain integer as NULL pointer inflate.c:502:53: warning: Using plain integer as NULL pointer inflate.c:512:37: warning: Using plain integer as NULL pointer inflate.c:513:40: warning: Using plain integer as NULL pointer inflate.c:525:32: warning: Using plain integer as NULL pointer inflate.c:529:52: warning: Using plain integer as NULL pointer inflate.c:543:54: warning: Using plain integer as NULL pointer inflate.c:932:17: warning: Using plain integer as NULL pointer inflate.c:932:42: warning: Using plain integer as NULL pointer inflate.c:935:26: warning: Using plain integer as NULL pointer inflate.c:940:19: warning: Using plain integer as NULL pointer adler32.c:58:5: warning: non-ANSI definition of function 'adler32' adler32.c:81:16: warning: Using plain integer as NULL pointer zutil.c:53:9: warning: non-ANSI definition of function 'zcalloc' zutil.c:64:9: warning: non-ANSI definition of function 'zcfree' inffast.c:70:1: warning: non-ANSI definition of function 'inflate_fast' inftrees.c:33:1: warning: non-ANSI definition of function 'inflate_table' Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-29lib: zlib: remove the limitation for cannot using 0 as startLei Wen
We often need the requirement that compressing those memory range start from 0, but the default deflate code in zlib prevent us to do this. Considering the special case of uboot, that it could access all memory range, it is reasonable to be able to also take the address space from 0 into compression. Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-09-29lib: zlib: include deflate into zlib buildLei Wen
Add a new config CONFIG_GZIP_ENABLED, if enabled, the uboot bin would include zlib's deflate method which could be used for compressing. Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-09-29lib: zlib: import trees file from 1.2.5Lei Wen
2012-09-29lib: zlib: import deflate source file from 1.2.5Lei Wen
2011-10-28zlib: Fix integer cast of pointerSimon Glass
Fix to cast an integer to a pointer using uintptr_t. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17zlib: handle overflow while calculating available stream input sizeAnatolij Gustschin
If compressed data is located in sectors at the end of the flash and it's offset + input stream size > 0xFFFFFFFF, the uncompressing time is very long, since processing of the stream is done bytewise (and not blockwise) due to overflow in inflate_fast() while calculation and checking for enough input available. Check for this overflow condition and limit the available stream input size to the actually max. possible input size. This fixes the problem. The issue is easily reproduceable by placing a gziped bitmap in flash, e.g. at FFF80000, and running 'bmp' commands like 'bmp info FFF80000' or 'bmp display FFF80000'. The uncompressing can take up to 3 sec. whereas it should normaly take a fraction of a second. If the 'splashimage' environment variable points to this address, the booting time also increases significantly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-05-12zlib: fix DEBUG buildMike Frysinger
The previous commit imported a little too much from upstream. We need to disable stdio.h when using U-Boot. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
