path: root/lib/vsprintf.c
2018-01-28vsprintf.c: correct printing of a NULL device pathHeinrich Schuchardt
When printing '%pD' with a value of NULL we want to output '<NULL>'. But this requires copying to buf. Leave this to string16. A unit test is supplied which relies on EFI support in the sandbox. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 and adding 256060e4257a2 and this patch the test is executed successfully. Fixes: 256060e4257a2 (vsprintf.c: add EFI device path printing) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22vsprintf.c: add EFI device path printingHeinrich Schuchardt
For debugging efi_loader we need the capability to print EFI device paths. With this patch we can write: debug("device path: %pD", dp); A possible output would be device path: /MemoryMapped(0x0,0x3ff93a82,0x3ff93a82) This enhancement is not available when building without EFI support and neither in the SPL nor in the API example. A test is provided. It can be executed in the sandbox with command ut_print. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch currently lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 the test is executed successfully. Without EFI support in the sandbox the test is simply skipped. Suggested-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-12vsprintf.c: add GUID printingRob Clark
This works (roughly) the same way as linux's, but we currently always print lower-case (ie. we just keep %pUB and %pUL for compat with linux), mostly just because that is what uuid_bin_to_str() supports. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 It will be used by a later efi_loader paths for efi variables and for device-path-to-text protocol, and also quite useful for debug prints of protocol GUIDs. Signed-off-by: Rob Clark <robdclark@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-12vsprintf.c: add UTF-16 string (%ls) supportRob Clark
This is convenient for efi_loader which deals a lot with UTF-16. Only enabled with CC_SHORT_WCHAR, leaving room to add a UTF-32 version when CC_SHORT_WCHAR is not enabled. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-13lib: split out strtoxxxx functions out of vsprintf.cSjoerd Simons
To allow the various string to number conversion functions to be used when using tiny-printf,split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-12-13lib: Split panic functions out of vsprintf.cSjoerd Simons
To allow panic and panic_str to still be used when using tiny-printf, split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-11-23lib/tiny-printf.c: Add tiny printf function for space limited environmentsStefan Roese
This patch adds a small printf() version that supports all basic formats. Its intented to be used in U-Boot SPL versions on platforms with very limited internal RAM sizes. To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This will result in the SPL using this tiny function and the main U-Boot still using the full-blown printf() function. This code was copied from: http://www.sparetimelabs.com/printfrevisited With mostly only coding style related changes so that its checkpatch clean. The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp (Marvell AXP) SPL: Without this patch: 58963 18536 1928 79427 13643 ./spl/u-boot-spl With this patch: 56542 18536 1956 77034 12cea ./spl/u-boot-spl Note: To make it possible to compile tiny-printf.c instead of vsprintf.c when CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are moved from common/console.c into vsprintf.c in this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2015-07-21lib: Add function to extract a number from the end of a stringSimon Glass
Split out the code in fdtdec which finds a number at the end of a string. It can be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-04-23dm: Add a panic_str() function to reduce code sizeSimon Glass
The printf() in panic() adds about 1.5KB of code size to SPL when compiled with Thumb-2. Provide a smaller version that does not support printf()-style arguments and use it in two commonly compiled places. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23vsprintf: Add modifier for phys_addr_tThierry Reding
Provide a new modifier to vsprintf() to print phys_addr_t variables to avoid having to cast or #ifdef when printing them out. The %pa modifier is used for this purpose, so phys_addr_t variables need to be passed by reference, like so: phys_addr_t start = 0; printf("start: %pa\n", &start); Depending on the size of phys_addr_t this will print out the address with 8 or 16 hexadecimal digits following a 0x prefix. Signed-off-by: Thierry Reding <treding@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Use uint64_t instead of u64 in put_dec()Simon Glass
Use the correct type required by do_div(). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-18lib:vsprintf: reduce scope of pack_hex_byteJeroen Hofstee
pack_hex_byte is only used when CONFIG_CMD_NET is defined so limit it to that scope. This prevents a clang warning. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-01-24lib: fix return codes when CONFIG_SYS_VSNPRINTF is enabledDarwin Rambo
When CONFIG_SYS_VSNPRINTF is enabled, it protects print operations such as sprintf, snprintf, vsnprintf, etc., from buffer overflows. But vsnprintf_internal includes the terminating NULL character in the calculation of number of characters written. This affects sprintf and snprintf return values. Fix this issue by setting pointer 'str' back to the location of the '\0'. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com>
2013-06-26Add function to print a number with grouped digitsSimon Glass
Move bootstage's numbering printing code into a generic place so that it can be used by tracing also. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-19vsprintf: add ustrtoll functionPiotr Wilczek
Add 'ustrtoull' function to convert size from string (ex: 1GiB) to unsigned long long type Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-13vsprintf:fix: Change type returned by ustrtoulLukasz Majewski
The ustrtoul shall convert string defined size (e.g. 1GiB) to unsigned long type (as its name implies). Up till now it had returned int, which might cause problems with large numbers (GiB range), when interpreted as U2 signed numbers. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-11-04lib/vsprintf.c: sparse fixesKim Phillips
vsprintf.c:31:12: warning: symbol 'hex_asc' was not declared. Should it be static? vsprintf.c:398:18: warning: Using plain integer as NULL pointer Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-02lib/vsprintf.c: don't special-case pointers to address nullWolfgang Denk
The %p format of printf() would print a pointer to address null as "(null)". This makes sense in a real OS where a NULL pointer must never be dereferenced, but this is a bootloader, and there are cases where accessing the data at address null makes perfect sense. Remove the special case in lib/vsprintf.c using "#if 0" with a comment to make clear this was an intentional change and to stop re-adding this code. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15lib: vsprintf.c: replace NUM_TYPE with s64/u64 typesDaniel Schwierzeck
This fixes warnings when compiling with ELDK-5.2.1 for MIPS64: vsprintf.c: In function 'put_dec': vsprintf.c:258:9: warning: comparison of distinct pointer types lacks a cast [enabled by default] vsprintf.c:258:3: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-10-15lib: vsprintf.c: fix checkpath.pl warningsDaniel Schwierzeck
2011-12-17vsprintf: Move function documentation into header fileSimon Glass
Now that this is not in common.h, perhaps it is acceptable to move this documentation into the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17Add safe vsnprintf and snprintf library functionsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> These functions are useful in U-Boot because they allow a graceful failure rather than an unpredictable stack overflow when printf() buffers are exceeded. Mostly copied from the Linux kernel. I copied vscnprintf and scnprintf so we can change printf and vprintf to use the safe implementation but still return the correct values. (Simon Glass <sjg@chromium.org> modified this commit a little) Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-10-26Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-09-10Add assert() for debug assertionsSimon Glass
assert() is like BUG_ON() but compiles to nothing unless DEBUG is defined. This is useful when a condition is an error but a board reset is unlikely to fix it, so it is better to soldier on in hope. Assertion failures should be caught during development/test. It turns out that assert() is defined separately in a few places in U-Boot with various meanings. This patch cleans up some of these. Build errors exposed by this change (and defining DEBUG) are also fixed in this patch. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-28panic: remove warning "'noreturn' function does return"Heiko Schocher
since commit commit d2e8b911c0a0661d395ccac72156040702ac842d Author: Mike Frysinger <vapier@gentoo.org> Date: Wed Jun 29 11:58:04 2011 +0000 panic: add noreturn attribute I see the following warnings: vsprintf.c: In function 'panic': vsprintf.c:730: warning: 'noreturn' function does return for nearly all boards. This patch fixes this warning. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12lib, vsprintf: introduce strict_strtoulHeiko Schocher
as checkpatch proposes to use strict_strtoul instead of simple_strtoul, introduce it. Ported this function from Linux 2.6.38 commit ID: 521cb40b0c44418a4fd36dc633f575813d59a43d Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
