path: root/lib/tpm-utils.h
2018-05-25tpm: add macros to enhance TPM commands readabilityMiquel Raynal
TPM commands are much easier to read/write with these macros that will transform words or integers into byte strings. This way, there is no need to call pack_byte_string() while all variable length in a command are known (and at must 4 bytes, which is a lot of them). Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: disociate TPMv1.x specific and generic codeMiquel Raynal
There are no changes in this commit but a new organization of the code as follow. * cmd/ directory: > move existing code from cmd/tpm.c in cmd/tpm-common.c > move specific code in cmd/tpm-v1.c > create a specific header file with generic definitions for commands only called cmd/tpm-user-utils.h * lib/ directory: > move existing code from lib/tpm.c in lib/tpm-common.c > move specific code in lib/tpm-v1.c > create a specific header file with generic definitions for the library itself called lib/tpm-utils.h * include/ directory: > move existing code from include/tpm.h in include/tpm-common.h > move specific code in include/tpm-v1.h Code designated as 'common' is compiled if TPM are used. Code designated as 'specific' is compiled only if the right specification has been selected. All files include tpm-common.h. Files in cmd/ include tpm-user-utils.h. Files in lib/ include tpm-utils.h. Depending on the specification, files may include either (not both) tpm-v1.h or tpm-v2.h. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
