path: root/lib/tpm-utils.h
2018-11-29tpm: Convert to use a device parameterSimon Glass
At present many TPM calls assume there is only one TPM in the system and look up this TPM themselves. This is inconsistent with driver model, which expects all driver methods to have a device parameter. Update the code to correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29tpm: Export the open/close functionsSimon Glass
At present these functions are not accessible outside the TPM library, but in some cases we need to call them. Export them in the header file and add a define for the SHA1 digest size. Also adjust tpm_open() to call tpm_close() first so that the TPM is in a known state before opening (e.g. by a previous phase of U-Boot). Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: add macros to enhance TPM commands readabilityMiquel Raynal
TPM commands are much easier to read/write with these macros that will transform words or integers into byte strings. This way, there is no need to call pack_byte_string() while all variable length in a command are known (and at must 4 bytes, which is a lot of them). Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: disociate TPMv1.x specific and generic codeMiquel Raynal
There are no changes in this commit but a new organization of the code as follow. * cmd/ directory: > move existing code from cmd/tpm.c in cmd/tpm-common.c > move specific code in cmd/tpm-v1.c > create a specific header file with generic definitions for commands only called cmd/tpm-user-utils.h * lib/ directory: > move existing code from lib/tpm.c in lib/tpm-common.c > move specific code in lib/tpm-v1.c > create a specific header file with generic definitions for the library itself called lib/tpm-utils.h * include/ directory: > move existing code from include/tpm.h in include/tpm-common.h > move specific code in include/tpm-v1.h Code designated as 'common' is compiled if TPM are used. Code designated as 'specific' is compiled only if the right specification has been selected. All files include tpm-common.h. Files in cmd/ include tpm-user-utils.h. Files in lib/ include tpm-utils.h. Depending on the specification, files may include either (not both) tpm-v1.h or tpm-v2.h. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
