path: root/lib/strmhz.c
2014-11-20replace DIV_ROUND with DIV_ROUND_CLOSESTMasahiro Yamada
The Linux-compatible macro DIV_ROUND_CLOSEST is a bit more flexible and safer than DIV_ROUND. For example, foo = DIV_ROUND_CLOSEST(x, y++) works expectedly, but foo = DIV_ROUND(x, y++) does not. (y is incremented twice.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2011-03-22strmhz: Make hz unsigned to support greater than 2146 MHz clockEd Swarthout
For example, an input of 0x80000000 should print: 2147.484 instead of -2147.-483. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
