path: root/lib/string.c
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-12-13Make linux kernel string funcs available to toolsJoe Hershberger
isspace() and strim() are not in the typical user-mode string.h, so put them in a separate compilation unit so that they can be built into tools that need them independent of the other common string functions. This allows code shared by u-boot and the linux user-mode tools to link. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-11Add strcasecmp() and strncasecmp()Simon Glass
strncasecmp() is present as strnicmp() but disabled. Make it available and define strcasecmp() also. There is a only a small performance penalty to having strcasecmp() call strncasecmp(), so do this instead of a standalone function, to save code space. Update the prototype in arch-specific headers as needed to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-01-26nand: Sanitize ONFI strings.Christian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This is part of the synchronization with the nand driver to the Linux 3.0 state. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-07-26memcpy/memmove: Do not copy to same addressMatthias Weisser
In some cases (e.g. bootm with a elf payload which is already at the right position) there is a in place copy of data to the same address. Catching this saves some ms while booting. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
