path: root/lib/smbios.c
2018-12-02sandbox: smbios: Update to support sandboxSimon Glass
At present this code casts addresses to pointers so cannot be used with sandbox. Update it to use mapmem instead. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-08-10smbios: fix checkstyle warningChristian Gmeiner
Fixes the following checkstyle warning: WARNING: Missing a blank line after declarations + int tmp = smbios_write_funcs[i]((ulong *)&addr, handle++); + max_struct_size = max(max_struct_size, tmp); Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-10smbios: fix checkstyle errorChristian Gmeiner
Fixes the following chechpatch -f error: ERROR: "(foo*)" should be "(foo *)" + strncpy((char*)t->uuid, serial_str, sizeof(t->uuid)); Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-06x86: Use unsigned long for address in table generationSimon Glass
We should use unsigned long rather than u32 for addresses. Update this so that the table-generation code builds correctly on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-19smbios: Provide serial numberAlexander Graf
If the system has a valid "serial#" environment variable set (which boards that can find it out programatically set automatically), use that as input for the serial number and UUID fields in the SMBIOS tables. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19smbios: Expose in efi_loader as tableAlexander Graf
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This patch adds enablement for that case. While at it, we also enable SMBIOS generation for ARM systems, since they support EFI_LOADER. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19smbios: Generate type 4 on non-x86 systemsAlexander Graf
The type 4 table generation code is very x86 centric today. Refactor things out into the device model cpu class to allow the tables to get generated for other architectures as well. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-19smbios: Allow compilation on 64bit systemsAlexander Graf
The SMBIOS generation code passes pointers as u32. That causes the compiler to warn on casts to pointers. This patch moves all address pointers to uintptr_t instead. Technically u32 would be enough for the current SMBIOS2 style tables, but we may want to extend the code to SMBIOS3 in the future which is 64bit address capable. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19x86: Move smbios generation into arch independent directoryAlexander Graf
We will need the SMBIOS generation function on ARM as well going forward, so let's move it into a non arch specific location. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
