path: root/lib/sha1.c
2016-11-21rsa: Verify RSA padding programaticallyAndrew Duda
Padding verification was done against static SHA/RSA pair arrays which take up a lot of static memory, are mostly 0xff, and cannot be reused for additional SHA/RSA pairings. The padding can be easily computed according to PKCS#1v2.1 as: EM = 0x00 || 0x01 || PS || 0x00 || T where PS is (emLen - tLen - 3) octets of 0xff and T is DER encoding of the hash. Store DER prefix in checksum_algo and create rsa_verify_padding function to handle verification of a message for any SHA/RSA pairing. Signed-off-by: Andrew Duda <aduda@meraki.com> Signed-off-by: aduda <aduda@meraki.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2014-07-18lib:sha1: remove unused constantJeroen Hofstee
This prevents a clang warning. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2012-12-11sha1: Use const where possible, and unsigned for input lenSimon Glass
In preparation for making the hash function common, we may as well use const where we can. Also the input length cannot be negative, but may be very large, so use unsigned. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
