add initialization of variable 'node',this can aviod the building
warning:
'node' may be used uninitialized [-Wmaybe-uninitialized]
Signed-off-by: Haijun Qin <qinhaijun@eswincomputing.com>
While we do not want to use CONFIG_RSA_VERIFY_WITH_PKEY on the host, we
cannot undef the symbol in this manner. As this ends up being a test
within another function we can use !tools_build() as a test here.
Cc: AKASHI Takahiro <takahiro.akashi@linaro.org>
Check the that the hash length is shorter than the message length. This
avoids:
./tools/../lib/rsa/rsa-verify.c:275:11: warning:
‘*db’ may be used uninitialized [-Wmaybe-uninitialized]
275 | db[0] &= 0xff >> leftmost_bits;
Fixes: 061daa0b61f0 ("rsa: add support of padding pss")
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Tighten up symbol dependencies in a number of places. Ensure that a SPL
specific option has at least a direct dependency on SPL. In places
where it's clear that we depend on something more specific, use that
dependency instead. This means in a very small number of places we can
drop redundant dependencies.
Reported-by: Pali Rohár <pali@kernel.org>
Modify function to support any salt length instead of max
length only. Function now detects salt length by parsing
the content of db buffer. Note that it works with (but is
not limited to) zero-length, digest-length and max-length
Signed-off-by: SESA644425 <gioja.hermann@non.se.com>
Prior to introduction of modifications in rsassa_pss functions
related to padding verification, doing a pass to reduce memory
consumption of function by replacing memory copies of parts of
const buffer by pointers to the original buffer (masked_db and
h are subparts of msg buffer which is declared const, salt is a
subpart of db which is a working buffer, unmodified after being
filled). New pointers scope is limited to the function where
they are declared (not returned to caller by any mean), zeroing
risk of memory fault related to the change.
related to padding verification, doing a pass to update
const-correctness in targeted functions to comply with
coding-rules and avoid const-cast
This commit adds the option SPL_RSA_VERIFY_WITH_PKEY.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Since OpenSSL 1.1.0, EVP_MD_CTX_create() is EVP_MD_CTX_new()
EVP_MD_CTX_destroy() is EVP_MD_CTX_free()
EVP_MD_CTX_init() is EVP_MD_CTX_reset()
As there's no need to reset a newly created EVP_MD_CTX, moreover
EVP_DigestSignInit() does the reset, thus call to EVP_MD_CTX_init()
can be dropped.
As there's no need to reset an EVP_MD_CTX before it's destroyed,
as it will be reset by EVP_MD_CTX_free(), call to EVP_MD_CTX_reset()
is not needed and can be dropped.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Add to support rsa 3072 bits algorithm in tools
for image sign at host side and adds rsa 3072 bits
verification in the image binary.
Add test case in vboot for sha384 with rsa3072 algorithm testing.
Signed-off-by: Jamin Lin <jamin_lin@aspeedtech.com>
It is useful to know where the verification data was written. Update the
API to return this.
Add some more debugging to make it easier to see what is being tried and
what fails. Fix a few comment styles while here.
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
The return type of EVP_PKEY_get0_RSA() is const struct rsa_st *.
Our code drops the const qualifier leading to
In file included from tools/lib/rsa/rsa-sign.c:1:
./tools/../lib/rsa/rsa-sign.c: In function ‘rsa_add_verify_data’:
./tools/../lib/rsa/rsa-sign.c:631:13: warning:
assignment discards ‘const’ qualifier from pointer target type
[-Wdiscarded-qualifiers]
631 | rsa = EVP_PKEY_get0_RSA(pkey);
Add a type conversion.
https://source.denx.de/u-boot/custodians/u-boot-amlogic into next
- disable CONFIG_NET_RANDOM_ETHADDR when unnecessary on amlogic based configs
- meson64_android: add board specific env settings, in order to support VIM3/L for android
- add changes to support VIM3/L android boot by using meson64_android.h config
Our Gitlab CI buildsystem is set up to treat warnings as errors.
With OpenSSL 3.0 a lot of deprecation warnings occur.
With the patch compatibility with OpenSSL 1.1.1 is declared.
In the long run we should upgrade our code to use the current API.
A -Wdiscarded-qualifiers warning is muted by casting.
ACRY is designed to accelerate ECC/RSA digital signature
generation and verification.
Signed-off-by: Chia-Wei Wang <chiawei_wang@aspeedtech.com>
This commit adds a check on the padding in the function rsa_verify_key
to avoid using a NULL pointer.
https://source.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20211020
First PR from u-boot-imx for 2022.01
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/9535
- new board: kontron-sl-mx8mm
- imx8m:
- fix secure boot
- imx ESDHC: fixes
- i.MX53: Support thum2, bmode and fixes for Menlo board
usbarmory switch to Ethernet driver model
- imx6 :
- DDR calibration for Toradex boards
- imx7:
- Fixes
- Updated gateworks boards (ventana / venice)
# gpg verification failed.
Add a host Kconfig for FIT_RSASSA_PSS. With this we can use
CONFIG_IS_ENABLED(FIT_RSASSA_PSS) directly in the host build, so drop the
forcing of this in the image.h header.
Drop the #ifdef around padding_pss_verify() too since it is not needed.
Use the compiler to check the config where possible, instead of the
preprocessor.
Reviewed-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
The CAAM on IMX7ULP doesn't support public key hardware acceleration
(PKHA), as in other NXP parts. Disable RSA_FREESCALE_EXP for IMX7ULP
too.
Fixed: f4e9ff7135 ("Kconfig: Don't use RSA_FREESCALE_EXP on IMX")
Signed-off-by: Ricardo Salveti <ricardo@foundries.io>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
SPL_RSA_VERIFY requires SPL_RSA to be enabled. Add correct
dependency.
Prepare v2021.10-rc4
# gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# board/Arcturus/ucp1020/spl.c
# cmd/mvebu/Kconfig
# common/Kconfig.boot
# common/image-fit.c
# configs/UCP1020_defconfig
# configs/sifive_unmatched_defconfig
# drivers/pci/Kconfig
# include/configs/UCP1020.h
# include/configs/sifive-unmatched.h
# lib/Makefile
# scripts/config_whitelist.txt
We are not guaranteed to have the padding_pkcs_15_verify symbol since
commit 92c960bc1d ("lib: rsa: Remove #ifdefs from rsa.h"), and
commit 61416fe9df ("Kconfig: FIT_SIGNATURE should not select RSA_VERIFY")
The padding_algos only make sense with RSA verification, which can now
be disabled in lieu of ECDSA. In fact this will lead to build failures
because of the missing symbol mentioned earlier.
To resolve this, move the padding_algos to a linker list, with
declarations moved to rsa_verify.c. This is consistent with commit
6909edb4ce ("image: rsa: Move verification algorithm to a linker list")
One could argue that the added #ifdef USE_HOSTCC is ugly, and should
be hidden within the U_BOOT_PADDING_ALGO() macro. However, this would
be inconsistent with the "cryptos" list. This logic for was not
previously explored:
Without knowledge of the U_BOOT_PADDING_ALGO() macro, its use is
similar to something being declared. However, should #ifndef
USE_HOSTCC be part of the macro, it would not be obvious that it
behaves differently on host code and target code. Having the #ifndef
outside the macro makes this obvious.
Also, the #ifdef is not always necessary. For example ecda-verify
makes use of U_BOOT_CRYPTO_ALGO() without any accompanying #ifdefs.
The fundamental issue is a lack of separation of host and target code
in rsa_verify. Therefore, the declaration of a padding algo with the
external #ifdef is more readable and consistent.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
If keydir is not provided but name is we want to use name as key_id.
But with the current coding name is only used on its own if it is NULL
and keydir is provided which never occurs.
Fixes: 824ee745fbca ("lib/rsa: Use the 'keyfile' argument from mkimage")
With glibc 2.33 (Ubuntu package glibc6 2.33-0ubuntu9) building
sifive_unmatched_defconfig results in:
In file included from /usr/include/stdio.h:866,
from ././include/compiler.h:26,
from <command-line>:
In function ‘snprintf’,
inlined from ‘rsa_engine_get_priv_key’ at ./tools/../^:273:4:
/usr/include/riscv64-linux-gnu/bits/stdio2.h:71:10: warning:
‘%s’ directive argument is null [-Wformat-truncation=]
71 | return __builtin___snprintf_chk (__s, __n,
__USE_FORTIFY_LEVEL - 1,
72 | __glibc_objsize (__s), __fmt,
73 | __va_arg_pack ());
Avoid passing a NULL string.
Older OpenSSL and libressl versions have a slightly different API.
This require #ifdefs to support. However, we still can't support it
because the ECDSA path does not compile with these older versions.
These #ifdefs are truly a vestigial appendage.
Alternatively, the ECDSA path could be updated for older libraries,
but this requires significant extra code, and #ifdefs. Those libraries
are over three years old, and there concerns whether it makes sense to
build modern software for real world use against such old libraries.
Thusly, remove #ifdefs and code for old OpenSSL and LibreSSL support.
This patch adds the possibility to pass the PIN the OpenSSL Engine
used during signing via the environment variable MKIMAGE_SIGN_PIN.
This follows the approach used during kernel module
signing ("KBUILD_SIGN_PIN") or UBIFS image
signing ("MKIMAGE_SIGN_PIN").
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
*sig_size isn't set until later so use the correct variables.
Signed-off-by: Donald Chan <hoiho@lab126.com>
Signed-off-by: Thomas Perrot <thomas.perrot@bootlin.com>
Move the RSA verification crytpo_algo structure out of the
crypto_algos array, and into a linker list.
Although it appears we are adding an #ifdef to rsa-verify.c, the gains
outweigh this small inconvenience. This is because rsa_verify() is
defined differently based on #ifdefs. This change allows us to have
a single definition of rsa_verify().
Drop the ENABLE and SUPPORT parts of this, which are redundant.
Most modern OpenSSL engines have methods overridden at the EVP level rather
than at RSA level, to make these engines work properly with mkimage, the RSA
signing code needs to switch to using EVP_* APIs as much as possible.
[trini: Rebase on top of keyfile changes]
Keys can be derived from keydir, and the "key-name-hint" property of
the FIT. They can also be specified ad-literam via 'keyfile'. Update
the RSA signing path to use the appropriate one.
fdt_add_bignum() is useful for algorithms other than just RSA. To
allow its use for ECDSA, move it to a common file under lib/.
The new file is suffixed with '-libcrypto' because it has a direct
dependency on openssl. This is due to the use of the "BIGNUM *" type.
rsa-checksum.c sontains the hash_calculate() implementations. Despite
the "rsa-" file prefix, this function is useful for other algorithms.
To prevent confusion, move this file to lib/, and rename it to
hash-checksum.c, to give it a more "generic" feel.
Currently we fail silently if there is an algorithm mismatch. To help
distinguish this failure condition.
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
In the function rsa_verify_hash, if the "main" key doesn't
work, u-boot try others keys. But it searches those keys
in the FIT image instead of the u-boot device tree.
Change parameter type to avoid compilation error:
In file included from ./tools/../lib/rsa/rsa-verify.c:23:0,
from tools/lib/rsa/rsa-verify.c:1:
include/u-boot/rsa-mod-exp.h:69:18: error: unknown type name ‘u32’; did you mean ‘__u32’?
int zynq_pow_mod(u32 *keyptr, u32 *inout);
__u32
include/u-boot/rsa-mod-exp.h:69:31: error: unknown type name ‘u32’; did you mean ‘__u32’?
__u32
Fixes: 37e3a36a5475 ("xilinx: zynq: Add support to secure images")
Remove initialization of ret with unused value.
Commit fdf0819afb (rsa: fix alignment issue when getting public
exponent) changed the logic to avoid doing an 8-byte access to a
possibly-not-8-byte-aligned address.
However, using rsa_convert_big_endian is wrong: That function converts
an array of big-endian (32-bit) words with the most significant word
first (aka a BE byte array) to an array of cpu-endian words with the
least significant word first. While the exponent is indeed _stored_ as
a big-endian 64-bit word (two BE words with MSW first), we want to
extract it as a cpu-endian 64 bit word. On a little-endian host,
swapping the words and byte-swapping each 32-bit word works, because
that's the same as byte-swapping the whole 64 bit word. But on a
big-endian host, the fdt32_to_cpu are no-ops, but
rsa_convert_big_endian() still does the word-swapping, breaking
verified boot.
To fix that, while still ensuring we don't do unaligned accesses, add
a little helper that first memcpy's the bytes to a local fdt64_t, then
applies fdt64_to_cpu(). [The name is chosen based on the
[bl]eXX_to_cpup in linux/byteorder/generic.h].
Fixes: fdf0819afb ("rsa: fix alignment issue when getting public exponent")
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
The algo name should match between the FIT's signature node and the
U-Boot's control FDT.
If we do not check it, U-Boot's control FDT can expect sha512 hash but
nothing will prevent to accept image with sha1 hash if the signature is correct.
Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
Fixes problem for unaligned 32bit big-endian access in
lib/rsa/rsa-keyprop.c.
Exchanges br_i32_decode() with get_unaligned_be32().
This will keep the unaligned access for architectures capable and will do
some byte-shift magic for the not so capable ones.
Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-by: Robert Reither <robert.reither@external.thalesgroup.com>
Remove unused include.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
After allocating to pointer ctx we should check that pointer and not
another pointer already checked above.
This function will be used to implement public_key_verify_signature()
in a later patch. rsa_verify() is not suitable here because calculation
of message digest is not necessary.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
rsa_verify() expects a memory region and wants to do the hashing itself,
but there may be cases where the hashing is done via other means,
like hashing a squashfs rootfs.
So add rsa_verify_hash() to allow verifiying a signature against
an existing hash. As this entails the same verification routines
we can just move the relevant code over from rsa_verify() and also
call rsa_verify_hash() from there.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
padding_pss_verify only works with the default pss salt setting of -2
(length to be automatically determined based on the PSS block structure)
not -1 (salt length set to the maximum permissible value), which makes
verifications of signatures with that saltlen fail.
Until this gets implemented at least document this behaviour.
n, rr and rrtmp are used for internal calculations, but in the end
the results are copied into separately allocated elements of the
actual key_prop, so the n, rr and rrtmp elements are not used anymore
when returning from the function and should of course be freed.
When calculating rrtmp/rr rsa_gen_key_prop() tries to make
(((rlen + 31) >> 5) + 1) steps in the rr uint32_t array and
(((rlen + 7) >> 3) + 1) / 4 steps in uint32_t rrtmp[]
with rlen being num_bits * 2
On a 4096bit key this comes down to to 257 uint32_t elements
in rr and 256 elements in rrtmp but with the current allocation
rr and rrtmp only have 129 uint32_t elements.
On 2048bit keys this works by chance as the defined max_rsa_size=4096
allocates a suitable number of elements, but with an actual 4096bit key
this results in other memory parts getting overwritten.
So as suggested by Heinrich Schuchardt just use the actual bit-size
of the key as base for the size calculation, in turn making the code
compatible to any future keysizes.
Suggested-by: Heinrich Schuchardt <xypron.debian@gmx.de>
rrtmp needs 2 + (((*prop)->num_bits * 2) >> 5) array elements.
