path: root/lib/physmem.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-05sandbox: physmem: Use mapping to support sandboxSimon Glass
Replace the raw cast with a map_sysmem() call so this code works with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-01lib/physmem.c: Switch to __weak for arch_phys_memsetTom Rini
We normally use __weak rather than calling it out directly as an alias. Update this function to the normal method. Signed-off-by: Tom Rini <trini@konsulko.com>
2012-12-06Introduce arch_phys_memset which works like memset but on physical memoryGabe Black
The default implementation of this function is just memset, but other implementations will be needed when physical memory isn't accessible by U-Boot using normal addressing mechanisms. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
