path: root/lib/lzo
2013-11-17lib: descend into sub directories only when it is necessaryMasahiro Yamada
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2013-09-03lzo: correctly bounds-check output bufferKees Cook
This checks the size of the output buffer and fails if it was going to overflow the buffer during lzo decompression. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-01GCC4.6: Squash warning in lzo1x_decompress.cMarek Vasut
lzo1x_decompress.c: In function ‘parse_header’: lzo1x_decompress.c:35:5: warning: variable ‘level’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
