path: root/lib/libfdt
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-28libfdt: migrate libfdt.h to a wrapper + U-Boot own codeMasahiro Yamada
There is tons of code duplication between lib/libfdt/libfdt.h and scripts/dtc/libfdt/libfdt.h. Evacuate the U-Boot own code to include/libfdt.h and remove lib/libfdt/libfdt.h. For host tools, <libfdt.h> should include scripts/dtc/libfdt/libfdt.h, which is already suitable for user-space. For compiling U-Boot, <linux/libfdt.h> should be included because we need a different libfdt_env.h . Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-28libfdt: migrate fdt_rw.c to a wrapper of scripts/dtc/libfdt/fdt_rw.cMasahiro Yamada
The only difference between scripts/dtc/libfdt/fdt_rw.c and lib/libfdt/fdt_rw.c is fdt_remove_unused_strings(). It is only used by fdtgrep, so we do not need to compile it for U-Boot image. Move it to tools/libfdt/fdw_rw.c so that lib/libfdt/fdt_rw.c can be a wrapper of scripts/dtc/libfdt/fdt_rw.c. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-04libfdt: migrate fdt_wip.c to a wrapper of scripts/dtc/libfdt/fdt_wip.cMasahiro Yamada
Now, lib/libfdt/fdt_wip.c is the same as scripts/dtc/libfdt/fdt_wip.c Change the former to a wrapper of the latter. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-04libfdt: move fdt_find_regions() to fdt_region.c from fdt_wip.cMasahiro Yamada
All the other fdt_*_region() functions are located in fdt_region.c, while only fdt_find_regions() was added to fdt_wip.c, strangely. Move it to the suitable place. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-17lib: libfdt: wrap scripts/dtc/libfdt/* where possibleMasahiro Yamada
lib/libfdt/ and scripts/dtc/libfdt have the same copies for the followings 6 files: fdt.c fdt_addresses.c fdt_empty_tree.c fdt_overlay.c fdt_strerr.c fdt_sw.c Make them a wrapper of scripts/dtc/libfdt/*. This is exactly what Linux does to sync libfdt. In order to make is possible, import <linux/libfdt.h> and <linux/libfdt_env.h> from Linux 4.14-rc5. Unfortunately, U-Boot locally modified the following 3 files: fdt_ro.c fdt_wip.c fdt_rw.c The fdt_region.c is U-Boot own file. I did not touch them in order to avoid unpredictable impact. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-17libfdt: change libfdt_internal.h to a wrapper of scripts/dtc/libfdt/*Masahiro Yamada
Fortunately, U-Boot did not modify libfdt_internal.h locally. Change it to a wrapper of scripts/dtc/libfdt/fdt.h, which will be periodically synced with the upstream DTC (or kernel). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-17libfdt: change fdt.h to a wrapper of scripts/dtc/libfdt/*Masahiro Yamada
Fortunately, U-Boot did not modify fdt.h locally. Change it to a wrapper of scripts/dtc/libfdt/fdt.h, which will be periodically synced with the upstream DTC (or kernel). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-17pylibfdt: move pylibfdt to scripts/dtc/pylibfdt and refactor makefileMasahiro Yamada
The pylibfdt is used by dtoc (and, indirectly by binman), but there is no reason why it must be generated in the tools/ directory. Recently, U-Boot switched over to the bundled DTC, and the directory structure under scripts/dtc/ now mirrors the upstream DTC project. So, scripts/dtc/pylibfdt is the best location. I also rewrote the Makefile in a cleaner Kbuild style. The scripts from the upstream have been moved as follows: lib/libfdt/pylibfdt/setup.py -> scripts/dtc/pylibfdt/setup.py lib/libfdt/pylibfdt/libfdt.i -> scripts/dtc/pylibfdt/libfdt.i_shipped The .i_shipped is coped to .i during building because the .i must be located in the objtree when we build it out of tree. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-15fdt: Allow stacked overlays phandle referencesPantelis Antoniou
This patch enables an overlay to refer to a previous overlay's labels by performing a merge of symbol information at application time. In a nutshell it allows an overlay to refer to a symbol that a previous overlay has defined. It requires both the base and all the overlays to be compiled with the -@ command line switch so that symbol information is included. base.dts -------- /dts-v1/; / { foo: foonode { foo-property; }; }; $ dtc -@ -I dts -O dtb -o base.dtb base.dts bar.dts ------- /dts-v1/; /plugin/; / { fragment@1 { target = <&foo>; __overlay__ { overlay-1-property; bar: barnode { bar-property; }; }; }; }; $ dtc -@ -I dts -O dtb -o bar.dtb bar.dts baz.dts ------- /dts-v1/; /plugin/; / { fragment@1 { target = <&bar>; __overlay__ { overlay-2-property; baz: baznode { baz-property; }; }; }; }; $ dtc -@ -I dts -O dtb -o baz.dtb baz.dts Applying the overlays: $ fdtoverlay -i base.dtb -o target.dtb bar.dtb baz.dtb Dumping: $ fdtdump target.dtb / { foonode { overlay-1-property; foo-property; linux,phandle = <0x00000001>; phandle = <0x00000001>; barnode { overlay-2-property; phandle = <0x00000002>; linux,phandle = <0x00000002>; bar-property; baznode { phandle = <0x00000003>; linux,phandle = <0x00000003>; baz-property; }; }; }; __symbols__ { baz = "/foonode/barnode/baznode"; bar = "/foonode/barnode"; foo = "/foonode"; }; }; Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Simon Glass <sjg@chromium.org>
2017-09-15libfdt: Initialize the stack variableTien Fong Chee
Report Coverity log: The code uses a variable that has not been initialized, leading to unpredictable or unintended results. Reported-by: Coverity (CID: 60519) Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2017-09-15fdt: Sync libfdt up to upstreamSimon Glass
Add upstream changes to U-Boot: - new pylibfdt functions - fdt_setprop_placeholder() Signed-off-by: Simon Glass <sjg@chromium.org>
2017-09-11moveconfig: Use fd.write() instead of print >>Simon Glass
Adjust this code so that it can work with Python 2 and 3. Fixes: d73fcb1 (moveconfig: Support building a simple config database) Reported-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-10libfdt: Drop -FDT_ERR_TOODEEPSimon Glass
This error code has not been upstreamed and is not really needed since it is unlikely to be triggered. Drop it to maintain compatability with upstream. Reported-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Peter Robinson <pbrobinson@gmail.com>
2017-06-02fdt: Stop building the old python libfdt moduleSimon Glass
This is no-longer needed, so stop building it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-02fdt: Rename existing python libfdt moduleSimon Glass
Now that this module has been accepted upstream we should stop using the local U-Boot one. In preparation for this, rename it to indicate it is for legacy use. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-02fdt: Allow swig options to be provided by MakefileSimon Glass
U-Boot needs to provide some swig include directories. Add this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-02fdt: Move header files into lib/libfdtSimon Glass
These header files are actually part of libfdt. Move them there to make it easier to build pylibfdt and easier to merge changes from upstream. Update the license header to use SPDX at the same time. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-02fdt: Add Python bindingsSimon Glass
An early version of this is available upstream. Bring it in as a starting point. This is from dtc upstream commit e56f2b0. Future work will plumb it into dtoc and remove the now-unnecessary local libraries. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-13fdtgrep: Cope with the /aliases node being lastSimon Glass
With skeleton.dtsi being dropped it is more likely that the /aliases node will be last in the device tree. Update fdtgrep to handle this. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-10libfdt: fix build with Python 3Stefan Agner
For some reason Python 3 seems to think it does not need to build the library. Using the --force parameter makes sure that the library gets built always. This is especially important since we move the library in the next step of the Makefile, hence forcing a rebuild every time the higher level Makefile triggers a rebuild is required to make sure the library is always there. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-10fdt: Bring in changes from v1.4.4Simon Glass
This a few minor changes down from upstream since the last sync. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-13libfdt: Correct fdt handling of overlays without fixups and base trees ↵David Gibson
without symbols The fdt_overlay_apply() function purports to support the edge cases where an overlay has no fixups to be applied, or a base tree which has no symbols (the latter can only work if the former is also true). However it gets it wrong in a couple of small ways: * In the no fixups case, it doesn't fail immediately, but will attempt fdt_for_each_property_offset() giving -FDT_ERR_NOTFOUND as the node offset, which will fail. Instead it should succeed immediately, since there's nothing to do. * In the case of no symbols, it again doesn't fail immediately. However if there is an actual fixup it will fail with an unexpected error, because -FDT_ERR_NOTFOUND is passed to fdt_getprop() when attempting to look up the symbols. We should instead return -FDT_ERR_NOTFOUND directly. Both of these errors lead to the code returning misleading error codes in failing cases. [ DTC commit: 7d8ef6e1db9794f72805a0855f4f7f12fadd03d3 ] Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-24libfdt: fix fdt_stringlist_search()Masahiro Yamada
If fdt_getprop() fails, negative error code should be returned. [ DTC commit: daa75e8fa5942caa8e97931aed3a1ee0b7edd74b ] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2016-10-24libfdt: fix fdt_stringlist_count()Masahiro Yamada
If fdt_getprop() fails, negative error code should be returned. [ DTC commit: e28eff5b787adb3f461d1653598818b2f1f25a73 ] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2016-10-23libfdt: Sync overlay with upstreamMaxime Ripard
Now that the overlay code has been merge upstream, update our copy to what's been merged, since a significant number of issues have been fixed during the merge process. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Drop inlining of fdt_path_offset()Simon Glass
The fdt_path_offset() function is not inlined in upstream libfdt. Adjust U-Boot's version to match. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Sync up with upstreamSimon Glass
This includes small changes to the following functions, from upstream commit 6d1832c: - fdt_get_max_phandle() (upstream commit 84e0e134) - fdt_node_check_compatible (upstream commit 53bf130b) - fdt_setprop_inplace_namelen_partial() to remove useless brackets and use idx instead of index - _fdt_resize_property() to use idx instead of index - _fdt_splice() (upstream commit d4c7c25c) It also includes various typo fixes in libfdt.h Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Fix undefined behaviour in fdt_offset_ptr()David Gibson
Using pointer arithmetic to generate a pointer outside a known object is, technically, undefined behaviour in C. Unfortunately, we were using that in fdt_offset_ptr() to detect overflows. To fix this we need to do our bounds / overflow checking on the offsets before constructing pointers from them. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-23libfdt: simplify fdt_del_mem_rsv()Masahiro Yamada
The variable "err" is unneeded. [ Device Tree Compiler commit: 36fd7331fb11276c09a6affc0d8cd4977f2fe100 ] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support finding the offset of a propertySimon Glass
Add a way to find the byte offset of a property within the device tree. This is only supported with the normal libfdt implementation since fdtget does not provide this information. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support packing the device treeSimon Glass
After any node/property deletion the device tree can be packed to remove spare space. Add a way to perform this operation. Note that for fdt_fallback, fdtput automatically packs the device tree after deletion, so no action is required here. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Support deleting device tree propertiesSimon Glass
Add support for deleting a device tree property. With the fallback implementation this uses fdtput. With libfdt it uses the API call and updates the offsets afterwards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-18dtoc: Move to using bytearraySimon Glass
Since we want to be able to change the in-memory device tree using libfdt, use a bytearray instead of a string. This makes interfacing from Python easier. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20cmd: fdt: add fdt overlay application subcommandMaxime Ripard
The device tree overlays are a good way to deal with user-modifyable boards or boards with some kind of an expansion mechanism where we can easily plug new board in (like the BBB or the raspberry pi). However, so far, the usual mechanism to deal with it was to have in Linux some driver detecting the expansion boards plugged in and then request these overlays using the firmware interface. That works in most cases, but in some cases, you might want to have the overlays applied before the userspace comes in. Either because the new board requires some kind of an early initialization, or because your root filesystem is accessed through that expansion board. The easiest solution in such a case is to simply have the component before Linux applying that overlay, removing all these drawbacks. Reviewed-by: Stefan Agner <stefan@agner.ch> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20libfdt: Add overlay application functionMaxime Ripard
The device tree overlays are a good way to deal with user-modifyable boards or boards with some kind of an expansion mechanism where we can easily plug new board in (like the BBB, the Raspberry Pi or the CHIP). Add a new function to merge overlays with a base device tree. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20libfdt: Add fdt_setprop_inplace_namelen_partialMaxime Ripard
Add a function to modify inplace only a portion of a property.. This is especially useful when the property is an array of values, and you want to update one of them without changing the DT size. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-20libfdt: Add fdt_path_offset_namelenMaxime Ripard
Add a namelen variant of fdt_path_offset to retrieve the node offset using only a fixed number of characters. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20libfdt: Fix separator spellingMaxime Ripard
The function fdt_path_next_seperator had an obvious mispell. Fix it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20libfdt: Add max phandle retrieval functionMaxime Ripard
Add a function to retrieve the highest phandle in a given device tree. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: Add a more efficient libfdt librarySimon Glass
Add a Python version of the libfdt library which contains enough features to support the dtoc tool. This is only a very bare-bones implementation. It requires the 'swig' to build. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-19lib/libfdt/: General aesthetic/style fixes.Robert P. J. Day
A number of style fixes across the files in this directory, including: * Correct invalid kernel-doc content. * Tidy up massive comment in fdt_region.c. * Use correct spelling of "U-Boot". * Replace tests of "! <var>" with "!<var>". * Replace "libfdt_env.h" with <libfdt_env.h>. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14libfdt: Add a function to write a property placeholderSimon Glass
The existing function to add a new property to a tree being built requires that the entire contents of the new property be passed in. For some applications it is more convenient to be able to add the property contents later, perhaps by reading from a file. This avoids double-buffering of the contents. Add a new function to support this and adust the existing fdt_property() to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-04fdt: Correct handling of alias regionsSimon Glass
At present the last four bytes of the alias region are dropped in the case where the last alias is included. This results in a corrupted device tree. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-21fdt: Add fdt_first/next_region() functionsSimon Glass
These have been sent upstream but not accepted to libfdt. For now, bring these into U-Boot to enable fdtgrep to operate. We will use fdtgrep to cut device tree files down for SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21fdt: Add a function to remove unused strings from a device treeSimon Glass
Property names are stored in a string table. When a node property is removed, the string table is not updated since other nodes may have a property with the same name. Thus it is possible for the string table to build up a number of unused strings. Add a function to remove these. This works by building a new device tree from the old one, adding strings one by one as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-20libfdt: fix error code of fdt_count_strings()Masahiro Yamada
Currently, this function returns a positive value on error, so we never know whether this function has succeeded or failed. For example, if the given property is not found, fdt_getprop() returns -FDT_ERR_NOTFOUND, and then this function inverts it, i.e., returns FDT_ERR_NOTFOUND (=1). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Fixes: bc4147ab2d69 ("fdt: Add a function to count strings") Acked-by: Simon Glass <sjg@chromium.org>
