path: root/lib/libfdt
2015-07-21fdt: Add fdt_first/next_region() functionsSimon Glass
These have been sent upstream but not accepted to libfdt. For now, bring these into U-Boot to enable fdtgrep to operate. We will use fdtgrep to cut device tree files down for SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21fdt: Add a function to remove unused strings from a device treeSimon Glass
Property names are stored in a string table. When a node property is removed, the string table is not updated since other nodes may have a property with the same name. Thus it is possible for the string table to build up a number of unused strings. Add a function to remove these. This works by building a new device tree from the old one, adding strings one by one as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-20libfdt: fix error code of fdt_count_strings()Masahiro Yamada
Currently, this function returns a positive value on error, so we never know whether this function has succeeded or failed. For example, if the given property is not found, fdt_getprop() returns -FDT_ERR_NOTFOUND, and then this function inverts it, i.e., returns FDT_ERR_NOTFOUND (=1). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Fixes: bc4147ab2d69 ("fdt: Add a function to count strings") Acked-by: Simon Glass <sjg@chromium.org>
2015-07-20libfdt: fix error code of fdt_get_string_index()Masahiro Yamada
As mentioned in the comment block in include/libfdt.h, fdt_get_string_index() is supposed to return a negative value on error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Fixes: 5094eb408a5d ("fdt: Add functions to retrieve strings") Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: Fix handling of paths with options in themHans de Goede
After syncing the sunxi dts files with the upstream kernel dm/fdt sunxi builds would no longer boot. The problem is that stdout-path is now set like this in the upstream dts files: stdout-path = "serial0:115200n8". The use of options in of-paths, either after an alias name, or after a full path, e.g. stdout-path = "/soc@01c00000/serial@01c28000:115200", is standard of usage, but something which the u-boot dts code so far did not handle. This commit fixes this, adding support for both path formats. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-08libfdt: move CONFIG_OF_LIBFDT and CONFIG_FIT to lib/MakefileMasahiro Yamada
2014-10-22fdt: Add functions to retrieve stringsThierry Reding
Given a device tree node, a property name and an index, the new function fdt_get_string_index() will return in an output argument a pointer to the index'th string in the property's value. The fdt_get_string() is a shortcut for the above with the index being 0. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add a function to get the index of a stringThierry Reding
Given a device tree node and a property name, the new fdt_find_string() function will look up a given string in the string list contained in the property's value and return its index. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22fdt: Add a function to count stringsThierry Reding
Given a device tree node and a property name, the fdt_count_strings() function counts the number of strings found in the property value. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-08-09fdt: Sync up with libfdtSimon Glass
This brings in changes up to commit f9e91a48 in the libfdt repo. Mostly this is whitespace/minor changes. But there are a few new features: - fdt_size_cells() and fdt_address_cells() - fdt_resize() Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19libfdt: Fix segfault when calling fit_check_format() on corrupt FIT imagesJon Nalley
It has been observed that fit_check_format() will fail when passed a corrupt FIT image. This was tracked down to _fdt_string_eq(): return (strlen(p) == len) && (memcmp(p, s, len) == 0); In the case of a corrupt FIT image one can't depend on 'p' being NULL terminated. I changed it to use strnlen() to fix the issue. Signed-off-by: Tom Rini <trini@ti.com>
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-08-10libfdt: SPDX-License-Identifier: GPL-2.0+ BSD-2-ClauseRoger Meier
Signed-off-by: Roger Meier <roger@bufferoverflow.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-06-26libfdt: Add fdt_find_regions()Simon Glass
Add a function to find regions in device tree given a list of nodes to include and properties to exclude. See the header file for full documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14libfdt: Add fdt_next_subnode() to permit easy subnode iterationSimon Glass
Iterating through subnodes with libfdt is a little painful to write as we need something like this: for (depth = 0, count = 0, offset = fdt_next_node(fdt, parent_offset, &depth); (offset >= 0) && (depth > 0); offset = fdt_next_node(fdt, offset, &depth)) { if (depth == 1) { /* code body */ } } Using fdt_next_subnode() we can instead write this, which is shorter and easier to get right: for (offset = fdt_first_subnode(fdt, parent_offset); offset >= 0; offset = fdt_next_subnode(fdt, offset)) { /* code body */ } Also, it doesn't require two levels of indentation for the loop body. Signed-off-by: Simon Glass <sjg@chromium.org> (Cherry-picked from dtc commit 4e76ec79) Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2013-05-10Export fdt_stringlist_contains()Simon Glass
This function is useful outside libfdt, so export it. Ref: DTC commit b7aa300e Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2013-02-07libfdt: update from upstream dtc commit 142419eKim Phillips
commit 142419e "dtc/libfdt: sparse fixes", for u-boot's libfdt copy. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2012-10-15libfdt: Add helper function to create a trivial, empty treeGerald Van Baren
The libfdt read/write functions are now usable enough that it's become a moderately common pattern to use them to build and manipulate a device tree from scratch. For example, we do so ourself in our rw_tree1 testcase, and qemu is starting to use this model when building device trees for some targets such as e500. However, the read/write functions require some sort of valid tree to begin with, so this necessitates either having a trivial canned dtb to begin with or, more commonly, creating an empty tree using the serial-write functions first. This patch adds a helper function which uses the serial-write functions to create a trivial, empty but complete and valid tree in a supplied buffer, ready for manipulation with the read/write functions. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> From git://git.jdl.com/software/dtc.git patch hash be6026838 with adaptations to include/libfdt.h and lib/libfdt/Makefile for the U-Boot environment. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2012-10-15libfdt: Add support for appending the values to a existing propertyMinghuan Lian
Some properties may contain multiple values, these values may need to be added to the property respectively. this patch provides this functionality. The main purpose of fdt_append_prop() is to append the values to a existing property, or create a new property if it dose not exist. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2011-07-14libfdt: Implement property iteration functionsDavid Gibson
For ages, we've been talking about adding functions to libfdt to allow iteration through properties. So, finally, here are some. I got bogged down on this for a long time because I didn't want to expose offsets directly to properties to the callers. But without that, attempting to make reasonable iteration functions just became horrible. So eventually, I settled on an interface which does now expose property offsets. fdt_first_property_offset() and fdt_next_property_offset() are used to step through the offsets of the properties starting from a particularly node offset. The details of the property at each offset can then be retrieved with either fdt_get_property_by_offset() or fdt_getprop_by_offset() which have interfaces similar to fdt_get_property() and fdt_getprop() respectively. No explicit testcases are included, but we do use the new functions to reimplement the existing fdt_get_property() function. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: 73dca9ae0b9abe6924ba640164ecce9f8df69c5a Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2011-07-14Support ePAPR compliant phandle propertiesDavid Gibson
Currently, the Linux kernel, libfdt and dtc, when using flattened device trees encode a node's phandle into a property named "linux,phandle". The ePAPR specification, however - aiming as it is to not be a Linux specific spec - requires that phandles be encoded in a property named simply "phandle". This patch adds support for this newer approach to dtc and libfdt. Specifically: - fdt_get_phandle() will now return the correct phandle if it is supplied in either of these properties - fdt_node_offset_by_phandle() will correctly find a node with the given phandle encoded in either property. - By default, when auto-generating phandles, dtc will encode it into both properties for maximum compatibility. A new -H option allows either only old-style or only new-style properties to be generated. - If phandle properties are explicitly supplied in the dts file, dtc will not auto-generate ones in the alternate format. - If both properties are supplied, dtc will check that they have the same value. - Some existing testcases are updated to use a mix of old and new-style phandles, partially testing the changes. - A new phandle_format test further tests the libfdt support, and the -H option. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> This was extracted from the DTC commit: d75b33af676d0beac8398651a7f09037555a550b Mon Sep 17 00:00:00 2001 Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2010-04-13Move libfdt/ into lib/Peter Tyser
Move the libfdt directory into the common lib/ directory to clean up the top-level directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
