When there is no symbols section in the device tree,
overlay_fixup_phandles should return FDT_ERR_NOTFOUND instead of
FDT_ERR_BADOFFSET.
If fdt_getprop() fails, negative error code should be returned.
[ DTC commit: daa75e8fa5942caa8e97931aed3a1ee0b7edd74b ]
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
[ DTC commit: e28eff5b787adb3f461d1653598818b2f1f25a73 ]
Now that the overlay code has been merge upstream, update our copy to
what's been merged, since a significant number of issues have been fixed
during the merge process.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The fdt_path_offset() function is not inlined in upstream libfdt. Adjust
U-Boot's version to match.
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
This includes small changes to the following functions, from upstream
commit 6d1832c:
- fdt_get_max_phandle() (upstream commit 84e0e134)
- fdt_node_check_compatible (upstream commit 53bf130b)
- fdt_setprop_inplace_namelen_partial() to remove useless brackets and
use idx instead of index
- _fdt_resize_property() to use idx instead of index
- _fdt_splice() (upstream commit d4c7c25c)
It also includes various typo fixes in libfdt.h
Using pointer arithmetic to generate a pointer outside a known object is,
technically, undefined behaviour in C. Unfortunately, we were using that
in fdt_offset_ptr() to detect overflows.
To fix this we need to do our bounds / overflow checking on the offsets
before constructing pointers from them.
Reported-by: David Binderman <dcb314@hotmail.com>
The variable "err" is unneeded.
[ Device Tree Compiler commit: 36fd7331fb11276c09a6affc0d8cd4977f2fe100 ]
Add a way to find the byte offset of a property within the device tree. This
is only supported with the normal libfdt implementation since fdtget does
not provide this information.
After any node/property deletion the device tree can be packed to remove
spare space. Add a way to perform this operation.
Note that for fdt_fallback, fdtput automatically packs the device tree after
deletion, so no action is required here.
Add support for deleting a device tree property. With the fallback
implementation this uses fdtput. With libfdt it uses the API call and
updates the offsets afterwards.
Since we want to be able to change the in-memory device tree using libfdt,
use a bytearray instead of a string. This makes interfacing from Python
easier.
This adds a bunch of unit tests for the "fdt apply" command.
They've all been run successfully in the sandbox. However, as you still
require an out-of-tree dtc with overlay support, this is disabled by
default.
Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB or the raspberry pi).
However, so far, the usual mechanism to deal with it was to have in Linux
some driver detecting the expansion boards plugged in and then request
these overlays using the firmware interface.
That works in most cases, but in some cases, you might want to have the
overlays applied before the userspace comes in. Either because the new
board requires some kind of an early initialization, or because your root
filesystem is accessed through that expansion board.
The easiest solution in such a case is to simply have the component before
Linux applying that overlay, removing all these drawbacks.
Reviewed-by: Stefan Agner <stefan@agner.ch>
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Add a namelen variant of fdt_path_offset to retrieve the node offset using
only a fixed number of characters.
The function fdt_path_next_seperator had an obvious mispell. Fix it.
Add a function to retrieve the highest phandle in a given device tree.
Add a Python version of the libfdt library which contains enough features to
support the dtoc tool. This is only a very bare-bones implementation. It
requires the 'swig' to build.
A number of style fixes across the files in this directory, including:
* Correct invalid kernel-doc content.
* Tidy up massive comment in fdt_region.c.
* Use correct spelling of "U-Boot".
* Replace tests of "! <var>" with "!<var>".
* Replace "libfdt_env.h" with <libfdt_env.h>.
The existing function to add a new property to a tree being built requires
that the entire contents of the new property be passed in. For some
applications it is more convenient to be able to add the property contents
later, perhaps by reading from a file. This avoids double-buffering of the
contents.
Add a new function to support this and adust the existing fdt_property() to
use it.
At present the last four bytes of the alias region are dropped in
the case where the last alias is included. This results in a corrupted
device tree. Fix this.
These have been sent upstream but not accepted to libfdt. For now, bring
these into U-Boot to enable fdtgrep to operate. We will use fdtgrep to
cut device tree files down for SPL.
Property names are stored in a string table. When a node property is
removed, the string table is not updated since other nodes may have a
property with the same name.
Thus it is possible for the string table to build up a number of unused
strings. Add a function to remove these. This works by building a new device
tree from the old one, adding strings one by one as needed.
Currently, this function returns a positive value on error,
so we never know whether this function has succeeded or failed.
For example, if the given property is not found, fdt_getprop()
returns -FDT_ERR_NOTFOUND, and then this function inverts it,
i.e., returns FDT_ERR_NOTFOUND (=1).
Fixes: bc4147ab2d69 ("fdt: Add a function to count strings")
As mentioned in the comment block in include/libfdt.h,
fdt_get_string_index() is supposed to return a negative value
on error.
Fixes: 5094eb408a5d ("fdt: Add functions to retrieve strings")
After syncing the sunxi dts files with the upstream kernel dm/fdt sunxi
builds would no longer boot.
The problem is that stdout-path is now set like this in the upstream dts
files: stdout-path = "serial0:115200n8". The use of options in of-paths,
either after an alias name, or after a full path, e.g. stdout-path =
"/soc@01c00000/serial@01c28000:115200", is standard of usage, but something
which the u-boot dts code so far did not handle.
This commit fixes this, adding support for both path formats.
Given a device tree node, a property name and an index, the new function
fdt_get_string_index() will return in an output argument a pointer to
the index'th string in the property's value.
The fdt_get_string() is a shortcut for the above with the index being 0.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Given a device tree node and a property name, the new fdt_find_string()
function will look up a given string in the string list contained in the
property's value and return its index.
Given a device tree node and a property name, the fdt_count_strings()
function counts the number of strings found in the property value.
This brings in changes up to commit f9e91a48 in the libfdt repo.
Mostly this is whitespace/minor changes. But there are a few new
features:
- fdt_size_cells() and fdt_address_cells()
- fdt_resize()
It has been observed that fit_check_format() will fail when passed a
corrupt FIT image. This was tracked down to _fdt_string_eq():
return (strlen(p) == len) && (memcmp(p, s, len) == 0);
In the case of a corrupt FIT image one can't depend on 'p' being NULL
terminated. I changed it to use strnlen() to fix the issue.
Signed-off-by: Roger Meier <roger@bufferoverflow.ch>
Acked-by: Wolfgang Denk <wd@denx.de>
[trini: Fixup common/cmd_io.c]
Add a function to find regions in device tree given a list of nodes to
include and properties to exclude.
See the header file for full documentation.
Iterating through subnodes with libfdt is a little painful to write as we
need something like this:
for (depth = 0, count = 0,
offset = fdt_next_node(fdt, parent_offset, &depth);
(offset >= 0) && (depth > 0);
offset = fdt_next_node(fdt, offset, &depth)) {
if (depth == 1) {
/* code body */
Using fdt_next_subnode() we can instead write this, which is shorter and
easier to get right:
for (offset = fdt_first_subnode(fdt, parent_offset);
offset >= 0;
offset = fdt_next_subnode(fdt, offset)) {
/* code body */
Also, it doesn't require two levels of indentation for the loop body.
(Cherry-picked from dtc commit 4e76ec79)
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This function is useful outside libfdt, so export it.
Ref: DTC commit b7aa300e
Acked-by: David Gibson <david@gibson.dropbear.id.au>
commit 142419e "dtc/libfdt: sparse fixes", for u-boot's libfdt copy.
Cc: Jerry Van Baren <gvb.uboot@gmail.com>
The libfdt read/write functions are now usable enough that it's become a
moderately common pattern to use them to build and manipulate a device
tree from scratch. For example, we do so ourself in our rw_tree1 testcase,
and qemu is starting to use this model when building device trees for some
targets such as e500.
However, the read/write functions require some sort of valid tree to begin
with, so this necessitates either having a trivial canned dtb to begin with
or, more commonly, creating an empty tree using the serial-write functions
first.
This patch adds a helper function which uses the serial-write functions to
create a trivial, empty but complete and valid tree in a supplied buffer,
ready for manipulation with the read/write functions.
From git://git.jdl.com/software/dtc.git patch hash be6026838 with
adaptations to include/libfdt.h and lib/libfdt/Makefile for the U-Boot
environment.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Some properties may contain multiple values, these values may need
to be added to the property respectively. this patch provides this
functionality. The main purpose of fdt_append_prop() is to append
the values to a existing property, or create a new property if it
dose not exist.
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
For ages, we've been talking about adding functions to libfdt to allow
iteration through properties. So, finally, here are some.
I got bogged down on this for a long time because I didn't want to
expose offsets directly to properties to the callers. But without
that, attempting to make reasonable iteration functions just became
horrible. So eventually, I settled on an interface which does now
expose property offsets. fdt_first_property_offset() and
fdt_next_property_offset() are used to step through the offsets of the
properties starting from a particularly node offset. The details of
the property at each offset can then be retrieved with either
fdt_get_property_by_offset() or fdt_getprop_by_offset() which have
interfaces similar to fdt_get_property() and fdt_getprop()
respectively.
No explicit testcases are included, but we do use the new functions to
reimplement the existing fdt_get_property() function.
This was extracted from the DTC commit:
73dca9ae0b9abe6924ba640164ecce9f8df69c5a Mon Sep 17 00:00:00 2001
Currently, the Linux kernel, libfdt and dtc, when using flattened
device trees encode a node's phandle into a property named
"linux,phandle". The ePAPR specification, however - aiming as it is
to not be a Linux specific spec - requires that phandles be encoded in
a property named simply "phandle".
This patch adds support for this newer approach to dtc and libfdt.
Specifically:
- fdt_get_phandle() will now return the correct phandle if it
is supplied in either of these properties
- fdt_node_offset_by_phandle() will correctly find a node with
the given phandle encoded in either property.
- By default, when auto-generating phandles, dtc will encode
it into both properties for maximum compatibility. A new -H
option allows either only old-style or only new-style
properties to be generated.
- If phandle properties are explicitly supplied in the dts
file, dtc will not auto-generate ones in the alternate format.
- If both properties are supplied, dtc will check that they
have the same value.
- Some existing testcases are updated to use a mix of old and
new-style phandles, partially testing the changes.
- A new phandle_format test further tests the libfdt support,
and the -H option.
d75b33af676d0beac8398651a7f09037555a550b Mon Sep 17 00:00:00 2001
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Move the libfdt directory into the common lib/ directory to clean up the
top-level directory.
